I visit http://xxxx:3000/console to manage server and the console prints "Failed to load resource: the server responded with a status of 401 (Unauthorized) http://xxxx:3000/services".
And I don't know how to solve it.
Thanks for your help!
- Tags:
- HTML5
- JavaScript*
In this case, can you still successfully update the room configuration?
Thanks!
Thanks!
I can update the room name successfully but other configurations seem not to work.
Please tell me which one you cannot update, as well the steps to do that together the error message you received.
Thanks!
Thanks!
I set userLimit = 2 ,but the user can join the room without limit.
I set avCoordinated= true and the layout is lecture but the avCoordinated didn't work,the user who last join will be full of main pane.
Our QA engineer just tested the same case, and it turned out to be OK. So, regarding the first item, have you cleared the room and rejoin? Please also help check the value after your logoff and re-login to the management UI.
Regarding the second item, avCoordinated+lecture mode should enable VAD, which will put the speaker into the main pane. Have you tested this case?
Thanks!
Thanks!
1.The configuration does work when I cleared the room.
2.According to the user guide,when I set the avCoordinate as true, the VAD should be enable.Where can I also set it?
Thanks!
Hi Peng,
Let's take this userLimit as an example. After you set userLimit = 2 successfully, how did you clear the room? I mean the steps or API?
Regarding the VAD, avCoordinated+lecture mode should enable it. Click the "object" in the column of "Media Mixing", you will find the setting options there.
Thanks!
