Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
1151 Discussions
Create LocalStream Failed on running p2p 3.5.1 sample
Chen__Eric
Hi there,
I got the following error running p2p 3.5.1 web sample on Chrome and firefox
Create LocalStream failed: {code:1100, msg: "NotFoundError"},
It sounds like that it could not find the camera device. But I am pretty sure I have a working PC camera, and I am able to play video from camera on the web page using the following codes.
if (navigator.mediaDevices && navigator.mediaDevices.getUserMedia) {
  navigator.mediaDevices.getUserMedia({video: true})
    .then(stream => {
      _video.srcObject = stream;
      _video.play();
Any idea what I am missing? Any help will be appreciated.
Thank you!
YanbinZ_Intel
Hi Eric
   Please confirm you audio device can be found e.g microphone is works. In our sample code , audio is set as true, you can set audio:false if your audio device can not be found.
 Woogeen.LocalStream.create({
    audio : true
Chen__Eric
Hi Yanbin,
Yes, that's exactly the problem. I do not have the audio device attached. I am able to play the video after the I set the audio to false.
This post can be closed.
Thank you for your help!
Eric
