Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
1151 Discussions
ERROR: publish failed: Timeout to make rpc to b278b76b-4313-36a0-4b34-975f1982ab81.publish
emilija_n_1
Hi,  we are using Mcu 3.2 update 1 and i have some question about following problem:
in our example we are set rooms to create with (enableMixing: false) and in response from room enableMixing is false. After set this option when try to join conference and make publish to stream is showing following error : ERROR: publish failed: Timeout to make rpc to b278b76b-4313-36a0-4b34-975f1982ab81.publish.
I refresh the page and this time stream is published successfully.
Another problem is with subscribe stream is showing following error:
 - Uncaught TypeError: Cannot read property 'processSignalingMessage' of undefined
 - ERROR: 13264130335301160 subscribe failed: Timeout to make rpc to b278b76b-4313-36a0-4b34-975f1982ab81.subscribe
When refresh the page several times this problem is gone. If set enableMixing: true this problem is gone but at the moment we like to work only in non mixed rooms. Is there any idea why this is happened ?
gellert_h_
i also have this question.
qian_e_
我也遇到了同样的问题
