Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
GLES20 error: 1285
Somnus_Chen
  my android sdk is 3.5.2, error happens when finish a conference:
06-07 17:54:34.982 25234-26238/ I/org.webrtc.Logging: CameraStatistics: Camera fps: 27.
06-07 17:54:35.678 25234-25234/ I/HwPointEventFilter: support AFT
        [ 06-07 17:54:35.681   511:26298 I/         ]
        virtual buffer_md_t *hw::COutMetaSplit::splitOutMeta(hw::CDataTable &, hw::ISensorModuleSpec *), ae_state=2, trigger_id=0, preflash_state=0, need_lcd_compension=0,flash_state=0, capflash_ae_effect=0, resume_ae_doing=0ae_mode=1, ae_precapture=0
06-07 17:54:36.983 25234-26238/ I/org.webrtc.Logging: CameraStatistics: Camera fps: 28.
        [ 06-07 17:54:37.008   511:26298 I/         ]
06-07 17:54:37.036 25234-26563/ W/ApiRequest: request api name:com.eCommTool.callServerApi
06-07 17:54:37.036 25234-25234/ I/DxActivity:  -- .rtc.VideoConferenceActivity@b975a2a | .rtc.VideoConferenceActivity@b975a2a
        [ 06-07 17:54:37.045   511:26298 I/         ]
06-07 17:54:37.070 25234-25234/ I/HwPointEventFilter: support AFT
        [ 06-07 17:54:37.082   511:26298 I/         ]
06-07 17:54:37.672 25234-26563/ I/.rtc.VideoConferenceActivity: 结束视频会议成功...
                                                            [ 06-07 17:54:37.673   511:26298 I/         ]
06-07 17:54:37.674 25234-26563/ I/Client: Channel connect.....1-2
06-07 17:54:37.723  I/org.webrtc.Logging: MediaCodecVideoEncoder: Java releaseEncoder
06-07 17:54:37.724 25234-26573/ I/org.webrtc.Logging: MediaCodecVideoEncoder: Java releaseEncoder on release thread
06-07 17:54:37.778 25234-25234/ I/HwPointEventFilter: support AFT
06-07 17:54:37.780 25234-26573/ I/org.webrtc.Logging: MediaCodecVideoEncoder: Java releaseEncoder on release thread done
06-07 17:54:37.781  I/org.webrtc.Logging: GlShader: Deleting shader.
        [ 06-07 17:54:37.783   511:26298 I/         ]
06-07 17:54:37.807  I/org.webrtc.Logging: MediaCodecVideoEncoder: Java releaseEncoder done
06-07 17:54:37.808  I/org.webrtc.Logging: MediaCodecVideoEncoder: Java initEncode: VIDEO_CODEC_H264 : 640 x 480. @ 662 kbps. Fps: 30. Encode from texture : false
06-07 17:54:37.836 25234-26572/ I/SubmitNotificUtil: success...
06-07 17:54:37.839  I/org.webrtc.Logging: MediaCodecVideoEncoder: Found target encoder for mime video/avc : OMX.hisi.video.encoder.avc. Color: 0x13. Bitrate adjustment: NO_ADJUSTMENT
06-07 17:54:37.839  I/org.webrtc.Logging: MediaCodecVideoEncoder: Color format: 19. Bitrate adjustment: NO_ADJUSTMENT. Key frame interval: 0 . Initial fps: 30
06-07 17:54:37.839  I/org.webrtc.Logging: MediaCodecVideoEncoder:   Format: {width=640, height=480, bitrate=662000, mime=video/avc, frame-rate=30, i-frame-interval=20, bitrate-mode=2, color-format=19}
06-07 17:54:37.850 25234-25234/ I/SendBroadcastPermission: action:qycommonEMOBI_COMMON_BROAD_CAST, mPermissionType:0
06-07 17:54:37.851 25234-26579/ I/OMXClient: MuxOMX ctor
06-07 17:54:37.905 25234-26579/ I/ACodec: In onAllocateComponent create compenent, codec name: OMX.hisi.video.encoder.avc
06-07 17:54:37.907 25234-26579/ W/ACodec: do not know color format 0x7f000001 = 2130706433
06-07 17:54:37.910 25234-26579/ I/ACodec: setupAVCEncoderParameters with [profile: Baseline] [level: Level3]
06-07 17:54:37.910 25234-26579/ I/ACodec: [OMX.hisi.video.encoder.avc] cannot encode color aspects. Ignoring.
06-07 17:54:37.910 25234-26579/ I/ACodec: [OMX.hisi.video.encoder.avc] cannot encode HDR static metadata. Ignoring.
06-07 17:54:37.910 25234-26579/ I/ACodec: setupVideoEncoder succeeded
06-07 17:54:37.926  I/org.webrtc.Logging: MediaCodecVideoEncoder: Output buffers: 5
06-07 17:54:37.926  I/org.webrtc.Logging: MediaCodecVideoEncoder: Input buffers: 4
06-07 17:54:37.927  I/org.webrtc.Logging: MediaCodecVideoEncoder: Java releaseEncoder
        [ 06-07 17:54:37.929   511:26298 I/         ]
06-07 17:54:37.934 25234-26586/ I/org.webrtc.Logging: MediaCodecVideoEncoder: Java releaseEncoder on release thread
06-07 17:54:37.963 25234-26589/ W/.rtc.VideoConferenceActivity: If this event is triggered, it means an error has happened on the published or subscribed stream. Recovering the app status and republishing or resubscribing may be needed.
06-07 17:54:37.963 25234-26589/ E/WooGeen-ConferenceClient: No peerconnection found.
06-07 17:54:37.985 25234-26586/ I/org.webrtc.Logging: MediaCodecVideoEncoder: Java releaseEncoder on release thread done
06-07 17:54:37.985  I/org.webrtc.Logging: MediaCodecVideoEncoder: Java releaseEncoder done
06-07 17:54:37.985  I/org.webrtc.Logging: MediaCodecVideoEncoder: Java initEncode: VIDEO_CODEC_H264 : 480 x 640. @ 662 kbps. Fps: 60. Encode from texture : false
06-07 17:54:37.986 25234-26345/ I/org.webrtc.Logging: MediaCodecVideoDecoder: Java releaseDecoder. Total number of dropped frames: 1
06-07 17:54:37.987 25234-26591/ I/org.webrtc.Logging: MediaCodecVideoDecoder: Java releaseDecoder on release thread
06-07 17:54:37.987  I/org.webrtc.Logging: MediaCodecVideoEncoder: Found target encoder for mime video/avc : OMX.hisi.video.encoder.avc. Color: 0x13. Bitrate adjustment: NO_ADJUSTMENT
06-07 17:54:37.987  I/org.webrtc.Logging: MediaCodecVideoEncoder: Color format: 19. Bitrate adjustment: NO_ADJUSTMENT. Key frame interval: 0 . Initial fps: 30
06-07 17:54:37.987  I/org.webrtc.Logging: MediaCodecVideoEncoder:   Format: {width=480, height=640, bitrate=662000, mime=video/avc, frame-rate=30, i-frame-interval=20, bitrate-mode=2, color-format=19}
06-07 17:54:37.994 25234-26593/ I/OMXClient: MuxOMX ctor
06-07 17:54:38.016 25234-25234/ I/.rtc.VideoConferenceActivity: onDestroy...
06-07 17:54:38.018 25234-26186/ W/System.err: java.lang.RuntimeException: glUseProgram: GLES20 error: 1285
06-07 17:54:38.018 25234-26186/ W/System.err:     at org.webrtc.GlUtil.checkNoGLES2Error(GlUtil.java:29)
06-07 17:54:38.018 25234-26186/ W/System.err:     at org.webrtc.GlShader.useProgram(GlShader.java:110)
06-07 17:54:38.018 25234-26186/ W/System.err:     at org.webrtc.GlRectDrawer.prepareShader(GlRectDrawer.java:225)
06-07 17:54:38.018 25234-26186/ W/System.err:     at org.webrtc.GlRectDrawer.drawYuv(GlRectDrawer.java:169)
06-07 17:54:38.018 25234-26186/ W/System.err:     at .rtc.WoogeenSurfaceRenderer.renderFrameOnRenderThread(WoogeenSurfaceRenderer.java:504)
06-07 17:54:38.018 25234-26186/ W/System.err:     at .rtc.WoogeenSurfaceRenderer.access$000(WoogeenSurfaceRenderer.java:43)
06-07 17:54:38.018 25234-26186/ W/System.err:     at .rtc.WoogeenSurfaceRenderer$1.run(WoogeenSurfaceRenderer.java:116)
06-07 17:54:38.018 25234-26186/ W/System.err:     at android.os.Handler.handleCallback(Handler.java:755)
06-07 17:54:38.018 25234-26186/ W/System.err:     at android.os.Handler.dispatchMessage(Handler.java:95)
06-07 17:54:38.018 25234-26186/ W/System.err:     at android.os.Looper.loop(Looper.java:156)
06-07 17:54:38.018 25234-26186/ W/System.err:     at android.os.HandlerThread.run(HandlerThread.java:61)
06-07 17:54:38.022 25234-26186/ I/art: System.exit called, status: -1
06-07 17:54:38.022 25234-26186/ I/AndroidRuntime: VM exiting with result code -1, cleanup skipped.
Looking forward to your reply, thanks!
