- Tags:
- HTML5
- JavaScript*
Hi
Could you please provide more detail information ?
1. Reproduce steps included expectation and actual result for each steps.
2. Issue detail log information.
Yanbin
Hello Yanbin,
Thank you for your response. Unfortunately I do not have this device on my workplace, the problem described was experienced by a customer of our platform. This limits me from providing a log from the device.
The issue is experienced with every videocall made with ICS WebRTC, Google Hangouts for example, does not have this problem. We think this may relate to Hangouts using VP8 or VP9 as a codec instead of h264.
While calling in a mixed video call room, the entire mix stream is rendered green.
While calling in a non-mixed video call room, only the camera view of the Sony is rendered green, streams that are received from other devices render correctly.
This problem occurs on every call. Unfortunately I am unable to provide you with more information.
