Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
1151 Discussions
How can I change the signaling message server to Openfire(XMPP server) ?
Zhaoyan_Z_Intel
Hi guys,
     I has two question need your help.
    1. How can I use the PeerConnection as a webRTC signaling message server ?
It has been enable at Ubuntu machine,the problem is I don't know how to use the it .
    2.After that,how to change the signaling server as a xmpp server  according to my needs ?
I has know webRTC(google's source code) use libgingle ,but I want use xmpp with Intel CS for WebRTC,
 How do I achieve this ?
Thanks for your patience !
zhaoyan
Chunbo_H_Intel1
Please refer to section "Customize signaling channel" in the user guide of "Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC) Client SDK for JavaScript".
Chunbo_H_Intel1
Hi Zhaoyan,
Please tell us which component you're using. P2P or conference? Gateway or MCU?
And, PeeConnection is not a server in any mean. Also, we support the customized signaling server which you can find the specific steps for in our released user guide.
Thanks!
Zhaoyan_Z_Intel
      I use conference MCU server and I has try sample work well with the browser .So I want integration openfire as the signaling server.
I'm not clear is which server could change it's signaling server as XMPP server, how do that ?
I noticed that CS_WebRTC_Conference_Server_Peer support by Socket.io , does it's Intel CS webRTC support signaling server ?
Thanks!
zhaoyan
Zhaoyan_Z_Intel
Hi ,
   Could you tell me where the specific introduction how to customized signaling server ?
Thanks !
zhaoyan
Chunbo_H_Intel1
Zhaoyan_Z_Intel
Chunbo_H_Intel1
Great to see it work!
