Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
I can't get anything on my public ip
kiziltas__gorkem
Hello there,
I am pretty new on Intel CS. Followed all the steps on the documentation. I run bin/start-all.sh with no any error. But after when I run my public IP with 3004 it does not work. Do you have any idea why this is happening?
Also I checked netstat -lnput and here is my output;
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
tcp        0      0 0.0.0.0:25672           0.0.0.0:*               LISTEN      -
tcp        0      0 127.0.0.1:27017         0.0.0.0:*               LISTEN      -
tcp        0      0 0.0.0.0:4369            0.0.0.0:*               LISTEN      -
tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      -
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      -
tcp6       0      0 :::5672                 :::*                    LISTEN      -
tcp6       0      0 :::4369                 :::*                    LISTEN      -
tcp6       0      0 :::22                   :::*                    LISTEN      -
tcp6       0      0 :::3000                 :::*                    LISTEN      4062/node
tcp6       0      0 :::3001                 :::*                    LISTEN      4608/node
tcp6       0      0 :::3004                 :::*                    LISTEN      4608/node
tcp6       0      0 :::3300                 :::*                    LISTEN      4469/node
udp        0      0 127.0.0.53:53           0.0.0.0:*                           -
udp        0      0 172.31.32.8:68          0.0.0.0:*                           -
Thank you so much!
