Community
cancel
Showing results for
Search instead for
Did you mean:
ICS v4.1: Start rtmp stream is not working
we use the ICS v4.1 server with javascript and REST-API-SDK.
When trying to start a rtmp stream from the mixed room (out), we get the following error message:
"Internal Server Error"
This is the REST-API call:
var startStreamingOut = function (room, outUrl, audioFrom, videoFrom, host) {
    var options = {
        media: {
            audio: {
                format: { channelNum: 2, sampleRate: 48000, codec: "aac" }
            video: {
                format: { codec: "h264", profile: "CB" },
                parameters: {  resolution: { width: 1280, height: 720 }, framerate: 30, bitrate: 1000, keyFrameInterval: 100 }
        url: outUrl
    send('POST', '/rooms/' + room + '/streaming-outs', options, onResponse, host);
The call only works when removing the "parameters" block. But we want to generate a rtmp stream with 1 MBit/s.
Is the "parameters" block not supported or is its structure wrong?
Roland
Tags (2)
Hi, Roland, please set bitrate value to wantedBitrateMultiple like x0.2, x0.4 to control bitrate value, we didn't public bitrate setting in kbps for 4.1 release
@Qiujiao W. (Intel)
4.3  vs     4.1    (new add   protocol,parameters )   how to use it?
I‘m  try
url = 'rtmp://127.0.0.1/live/ttttt'  (rtmp service is ok)
stream = roomId + '-common'
 media = { audio: { from: stream }, video: { from: stream, parameters: { keyFrameInterval: 2 } } }
protocol = 'rtmp'
parameters = {method: 'PUT'}
 error : startStreamingOut  failed  (startStreamingOut  : {"error":{"code":2001,"message":"Error RPC:addServerSideS
ubscription failed"}}
Do you have an example?
Thank you!
