Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
IE Crash
Somnus_Chen
Hi CHUNBO,
    I visit my mcu http://XXXX:3001 or https://XXXX:3004 in Win10 IE11.162 or 11.494, everything is OK. Then,if  I close the IE tab, it works well. But if I close the whole IE window, the IE will be stuck for a long time util the IE crash.
    By the way,it works well in the win7 IE11.0.9600.
   I add the url http://XXXX and https://XXXX to my compatible list so that the compatible mode run with IE 10 with the code '<meta http-equiv="X-UA-Compatible" content="IE=EmulateIE10">', but the problem is still there.
  It seems that the code "localStream.close();" in function onbeforeunload caused it crash.
   Forward to your reply, thankds.
Lei_Z_Intel1
We are scheduling resource to reproduce this issue, will let you know once any progress. Thanks for the patience.
We will release Microsoft Edge browser support soon (without any plugin), to reduce the maintaining effort on legacy IE browser, we decided to stop updating IE plugin.
Chunbo_H_Intel1
你好,请问你用的是哪个版本的IE Plugin?
谢谢。
Somnus_Chen
WoogeenIEPluginSetup_v_3_0_8737_5
Somnus_Chen
你好..请问,您能重现这个问题吗?可有什么解决方案..IE plugin将会在3.2停止更新,是代表plugin很稳定了,不需要维护plugin,还是放弃了对整个IE上运行的支持?
Lei_Z_Intel1
