hi team:
I have a topic to share my screen to others in iOS
And
- (void)processSampleBuffer:(CMSampleBufferRef)sampleBuffer withType:(RPSampleBufferType)sampleBufferType {
我首先将sampleBufferType 转为webrtc中的RTCMediaStream 然后RTCMediaStream转为你们的OWTLocalStream通过initWithMediaStream方法 但是貌似没有起作用 方便问下你们在处理视频的时候是如何转换的,我哪里出了问题
RTCCVPixelBuffer *rtcPixelBuffer = [[RTCCVPixelBuffer alloc] initWithPixelBuffer:CMSampleBufferGetImageBuffer(buffer)];
int64_t timeStampNs = CMTimeGetSeconds(CMSampleBufferGetPresentationTimeStamp(buffer)) * NSEC_PER_SEC;
RTCVideoFrame *videoFrame= [[RTCVideoFrame alloc] initWithBuffer:rtcPixelBuffer rotation:RTCVideoRotation_0 timeStampNs:timeStampNs];
还是我在将sampleBufferType转为RTCMediaStream时出现了问题?
- Tags:
- HTML5
- JavaScript*
Hello team,
We are also having the same issue,
if CMSampleBufferGetNumSamples(samplebuffer) != 1 || !CMSampleBufferIsValid(samplebuffer) || !CMSampleBufferDataIsReady(samplebuffer) {
return
let pixelFormat = CMSampleBufferGetImageBuffer(samplebuffer)
let rtcPixlBuffer = RTCCVPixelBuffer(pixelBuffer: pixelFormat!)
let timeStampNs: Int64 = Int64(CMTimeGetSeconds(CMSampleBufferGetPresentationTimeStamp(samplebuffer)) * 100000)
let rtcVideoFrame = RTCVideoFrame(buffer: rtcPixlBuffer, rotation: ._0, timeStampNs: timeStampNs)
And we are adding RTCVideoCapture.
We stuck here, try to suggest solution for it As Soon As Possible
Thank you
