Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
1151 Discussions
In MCU mode in 2 node cluster the output video stream switches the location of the inputs
Mark_d_10
I've been testing with my cluster setup again, in MCU mode, I have 2 connected input streams from different 2 sources.
In the mixed output stream then the inputs switch of location in the layout randomly.
It is also visible in the recording, but that is because it's the same output stream I guess?
Any ideas on how to fix this?
If needed I can share by mail a short video demonstrating the problem
Lei_Z_Intel1
Hi, Mark
Have you enabled the VAD (Voice Activity Detection) during the room creation? This feature may trigger the input with most active audio occupy the first region of the layout.
Best wishes,
Zhai Lei
Mark_d_10
Hi Zhai,
Thank you, that was it, however this setting is called "avCoordinated" in de management console. So it was a bit of a search.
Lei_Z_Intel1
That's good. Enjoy!
