Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
Intel MCU-v3.5.2 ice failed and browser support issue in both cloud and dedicated platform
Kiran_Raj_RA
Thankyou webrtc team for fixing ice failed issue in aws environment but we are facing some issues in Firefox
mozilla firefox ice candidate failed in dedicated server and aws( intel mcu version 3.5.2 )
firefox 57.0.3 (64-bit)
dedicated ip address no nat (dedicated public ip)
nated aws private ip(172.31.81.14), public ip (54.173.235.254)
chrome to chrome working without any issues
firefox to firefox not working
safari to chrome working
firefox to any not working
please find the attached debug level log of both dedicated and aws servers
Qiujiao_W_Intel
Raj, we cannot reproduce it in our AWS environment,  we tried to connect to https://(54.173.235.254:3004, it seems we cannot connect to it, is it possible for us to connect to your AWS MCU?
Kiran_Raj_RA
Hi, Qiujiao
I terminated the instance that's why you cannot access the URL, Now I launched a new instance please check the below URL https://52.91.35.110:3004/ ; also the server access has mailed to webrtc_support@intel.com
Qiujiao_W_Intel
Raj, we connected to  https://52.91.35.110:3004/ with firefox 56 and 57, they all worked well, we cannot reproduce ice procedure failed issue with your MCU server. BTW, did you add exception for certificate, there would be 2 add exception operations, one is when you open url in tab, the second one will show follow steps in firefox:
Press F12 to open console ->click Network->click socket.io request->copy Request URL and open it in a new tab
Kiran_Raj_RA
Hi, Qiujiao
thanks for the reply,
I have installed SSL in (portal.toml and webrtc agent.toml and in basicserver.js) and also tried without installing our SSL cert in webrtc agent.toml  MCU v 3.5.2(dedicated server ip:45.33.63.190) you can access via URL https://linode-mcu.ofabee.com:3004  but still in my environment the firefox ice failed if you like to troubleshoot you can access our local machine via Teamviewer and dedicated server root access details are has mailed to webrtc_support@intel.com
please find the attached screenshots of browser console and toml files
Nithin_P_
Hi Kiran raj,
               Firefox ice failed issue happening only in some corporate network. But in 3.3 version it is working fine all network.You can varify this by installing both 3.3 version and 3.5.2 in two machine and open default conference pages in mozilla firefox in the same network. Now you can conclude lower version work perfect and higher version not
Somnus_Chen
Where to download 3.5.2?
Kiran_Raj_RA
Somnus_Chen
got it..thanks a lot
Kiran_Raj_RA
Hi, Qiujiao
we are facing the below issues with version 3.5.2 and 3.3 (As tested both we switched to MCUv3.3)
MCU version 3.3 (conference application mcu mixed stream)(tested in both aws environment and dedicated server) the below browsers support are tested in MCU V3.3 almost firefox will work in all kind of broadband and lease line compared to MCUv3.5.2
Major issues facing (1. Round robin webrtc scalability does not support, 2. echo while using sip, 3. Port not Releasing Issue, Safari Support).
Advantages almost works in most browsers and mobile devices ICE Traversal is good comparing to latest releases working 90% broadband and lease line, port leak is less
WINDOWS 10
1. Edge version
Microsoft EdgeHTML 16.16299
Microsoft Edge 41.16299.15.0  (working good no ice issue)
2.chrome Version 62.0.3202.94 (Official Build) (64-bit)   (working good no ice issue)
3.mozilla 57.0.4 (64-bit)  (working good no ice issue)
4.chromium browser (working good)
windows 8 (32-bit)
1.chrome (working good)
2.firefox version 58.0b15 32bit (not working)
MACOS 10
1.chrome  63.0.3239.132 (Official Build) (64-bit) (working good no ice issue)
2.safari Safari Version 11.0.2 (not working)
UBUNTU 14.04
1.chrome Version 61.0.3163.79 (Official Build) (64-bit) (working good no ice issue)
2.mozilla 52.0.2 (64-bit) (working good no ice issue)
UBUNTU 16.04
1.chrome Version 54.0.2840.71 (64-bit) chrome (Official Build) (64-bit)(working good)
2.mozilla 57.0.3 (64-bit)(working good)
mobile browser android 6.0.1
1.chrome version 62.0.3202.84 (working good)
iphone ios 11
1.chrome (not working)
2.safari (not working)
ipad air
1.chrome version 63.0.3239.73 (not working)
MCU version 3.5.2 (conference application  mcu  mixed stream)(tested in both  aws  environment and dedicated server) the below browsers support are tested in MCU V3.5.2  almost firefox ICE failed issue in most of the networks, browser support is limited compared to MCUV3.3
Major issues facing (1. Port not Releasing Issue, 2.most firefox ice issue, 3. less support in mobile browsers, 4. no chromium support).
WINDOWS 10
1. Edge version
3.mozilla 57.0.4 (64-bit)  (not working, ice issue in most broadband and lease line networks, works in some internet providers)
4.chromium browser (not working)
windows 8 (32-bit)
2. firefox version 58.0b15 32bit (not working)
MACOS 10
2.safari Safari Version 11.0.2 (working good no ice issue)
UBUNTU 14.04
2.mozilla 52.0.2 (64-bit) (in same broadband network windows 10 firefox ice failed but ubuntu 14 firefox working good)
UBUNTU 16.04
1.chrome Version 54.0.2840.71 (64-bit) chrome (Official Build) (64-bit) (not working)
2.mozilla 57.0.3 (64-bit)(not working)
1.chrome version 62.0.3202.84 (not working)
iphone ios 11
2.safari  (working good)
ipad air
Please find the attached screenshots for reference
