Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
1152 Discussions
Intel WebRTC Windows 3.4.1 OnStreamAdded后订阅后崩溃
ttom1
您好:
我在使用Intel WebRTC Windows 3.4.1 版本。
在ConferenceClientObserver在ConferenceClientObserver::OnStreamAdded(std::shared_ptr<RemoteMixedStream> stream)中立即调用
Subscribe()订阅混合流,
Debug版本:
有时(比较频繁,大约20-30%的几率)出现崩溃;
Release版本:
不崩溃,但流没有被成功订阅,也没有调用Subscribe()失败回调,此时流既不能重新订阅,也不能取消订阅;
如果在OnStreamAdded时先保存流变量,隔一会再调用,则会好很多,间隔越长,成功的几率越高。
Debug崩溃时的堆栈如下
PhConfOne.exe!issue_debug_notification(const wchar_t * const message) 行 125 C++
  PhConfOne.exe!__acrt_report_runtime_error(const wchar_t * message) 行 142 C++
  PhConfOne.exe!abort() 行 51 C++
  PhConfOne.exe!rtc::FatalMessage::~FatalMessage(void) 未知
  PhConfOne.exe!std::_Vector_const_iterator<class std::_Vector_val<struct std::_Simple_types<class woogeen::conference::ConferenceSocketSignalingChannelObserver *> > >::operator<(class std::_Vector_const_iterator<class std::_Vector_val<struct std::_Simple_types<class woogeen::conference::ConferenceSocketSignalingChannelObserver *> > > const &) 未知
  PhConfOne.exe!std::_Invoker_functor::_Call<class <lambda_32813e9ec8f2e959bd5a05b4d6c1f91c> &,class sio::message::list const &>(class <lambda_32813e9ec8f2e959bd5a05b4d6c1f91c> &,class sio::message::list const &) 未知
  PhConfOne.exe!std::invoke<class <lambda_32813e9ec8f2e959bd5a05b4d6c1f91c> &,class sio::message::list const &>(class <lambda_32813e9ec8f2e959bd5a05b4d6c1f91c> &,class sio::message::list const &) 未知
  PhConfOne.exe!std::_Invoke_ret<void,class <lambda_32813e9ec8f2e959bd5a05b4d6c1f91c> &,class sio::message::list const &>(struct std::_Forced<void,1>,class <lambda_32813e9ec8f2e959bd5a05b4d6c1f91c> &,class sio::message::list const &) 未知
  PhConfOne.exe!std::_Func_impl<class <lambda_32813e9ec8f2e959bd5a05b4d6c1f91c>,class std::allocator<int>,void,class sio::message::list const &>::_Do_call(class sio::message::list const &) 未知
  PhConfOne.exe!std::_Func_class<void,sio::message::list const &>::operator()(const sio::message::list & <_Args_0>) 行 280 C++
  PhConfOne.exe!sio::socket::impl::on_socketio_ack(int msgId, const sio::message::list & message) 行 471 C++
  PhConfOne.exe!sio::socket::impl::on_message_packet(const sio::packet & p) 行 420 C++
  PhConfOne.exe!sio::socket::on_message_packet(const sio::packet & p) 行 601 C++
  PhConfOne.exe!sio::client_impl::on_decode(const sio::packet & p) 行 523 C++
  PhConfOne.exe!boost::_mfi::mf1<void,sio::client_impl,sio::packet const &>::operator()(sio::client_impl * p, const sio::packet & a1) 行 166 C++
  PhConfOne.exe!boost::_bi::list2<boost::_bi::value<sio::client_impl *>,boost::arg<1> >::operator()<boost::_mfi::mf1<void,sio::client_impl,sio::packet const &>,boost::_bi::rrlist1<sio::packet const &> >(boost::_bi::type<void> __formal, boost::_mfi::mf1<void,sio::client_impl,sio::packet const &> & f, boost::_bi::rrlist1<sio::packet const &> & a, int __formal) 行 320 C++
  PhConfOne.exe!boost::_bi::bind_t<void,boost::_mfi::mf1<void,sio::client_impl,sio::packet const &>,boost::_bi::list2<boost::_bi::value<sio::client_impl *>,boost::arg<1> > >::operator()<sio::packet const &>(const sio::packet & a1) 行 1235 C++
  PhConfOne.exe!std::_Invoker_functor::_Call<boost::_bi::bind_t<void,boost::_mfi::mf1<void,sio::client_impl,sio::packet const &>,boost::_bi::list2<boost::_bi::value<sio::client_impl *>,boost::arg<1> > > &,sio::packet const &>(boost::_bi::bind_t<void,boost::_mfi::mf1<void,sio::client_impl,sio::packet const &>,boost::_bi::list2<boost::_bi::value<sio::client_impl *>,boost::arg<1> > > & _Obj, const sio::packet & <_Args_0>) 行 1377 C++
  PhConfOne.exe!std::invoke<boost::_bi::bind_t<void,boost::_mfi::mf1<void,sio::client_impl,sio::packet const &>,boost::_bi::list2<boost::_bi::value<sio::client_impl *>,boost::arg<1> > > &,sio::packet const &>(boost::_bi::bind_t<void,boost::_mfi::mf1<void,sio::client_impl,sio::packet const &>,boost::_bi::list2<boost::_bi::value<sio::client_impl *>,boost::arg<1> > > & _Obj, const sio::packet & <_Args_0>) 行 1443 C++
  PhConfOne.exe!std::_Invoke_ret<void,boost::_bi::bind_t<void,boost::_mfi::mf1<void,sio::client_impl,sio::packet const &>,boost::_bi::list2<boost::_bi::value<sio::client_impl *>,boost::arg<1> > > &,sio::packet const &>(std::_Forced<void,1> __formal, boost::_bi::bind_t<void,boost::_mfi::mf1<void,sio::client_impl,sio::packet const &>,boost::_bi::list2<boost::_bi::value<sio::client_impl *>,boost::arg<1> > > & <_Vals_0>, const sio::packet & <_Vals_1>) 行 1461 C++
  PhConfOne.exe!std::_Func_impl<boost::_bi::bind_t<void,boost::_mfi::mf1<void,sio::client_impl,sio::packet const &>,boost::_bi::list2<boost::_bi::value<sio::client_impl *>,boost::arg<1> > >,std::allocator<int>,void,sio::packet const &>::_Do_call(const sio::packet & <_Args_0>) 行 212 C++
  PhConfOne.exe!std::_Func_class<void,sio::packet const &>::operator()(const sio::packet & <_Args_0>) 行 280 C++
  PhConfOne.exe!sio::packet_manager::put_payload(const std::basic_string<char,std::char_traits<char>,std::allocator<char> > & payload) 行 516 C++
  PhConfOne.exe!sio::client_impl::on_message(std::weak_ptr<void> __formal, std::shared_ptr<websocketpp::message_buffer::message<websocketpp::message_buffer::alloc::con_msg_manager> > msg) 行 459 C++
  PhConfOne.exe!boost::_mfi::mf2<void,sio::client_impl,std::weak_ptr<void>,std::shared_ptr<websocketpp::message_buffer::message<websocketpp::message_buffer::alloc::con_msg_manager> > >::operator()(sio::client_impl * p, std::weak_ptr<void> a1, std::shared_ptr<websocketpp::message_buffer::message<websocketpp::message_buffer::alloc::con_msg_manager> > a2) 行 280 C++
  PhConfOne.exe!boost::_bi::list3<boost::_bi::value<sio::client_impl *>,boost::arg<1>,boost::arg<2> >::operator()<boost::_mfi::mf2<void,sio::client_impl,std::weak_ptr<void>,std::shared_ptr<websocketpp::message_buffer::message<websocketpp::message_buffer::alloc::con_msg_manager> > >,boost::_bi::rrlist2<std::weak_ptr<void>,std::shared_ptr<websocketpp::message_buffer::message<websocketpp::message_buffer::alloc::con_msg_manager> > > >(boost::_bi::type<void> __formal, boost::_mfi::mf2<void,sio::client_impl,std::weak_ptr<void>,std::shared_ptr<websocketpp::message_buffer::message<websocketpp::message_buffer::alloc::con_msg_manager> > > & f, boost::_bi::rrlist2<std::weak_ptr<void>,std::shared_ptr<websocketpp::message_buffer::message<websocketpp::message_buffer::alloc::con_msg_manager> > > & a, int __formal) 行 399 C++
  PhConfOne.exe!boost::_bi::bind_t<void,boost::_mfi::mf2<void,sio::client_impl,std::weak_ptr<void>,std::shared_ptr<websocketpp::message_buffer::message<websocketpp::message_buffer::alloc::con_msg_manager> > >,boost::_bi::list3<boost::_bi::value<sio::client_impl *>,boost::arg<1>,boost::arg<2> > >::operator()<std::weak_ptr<void>,std::shared_ptr<websocketpp::message_buffer::message<websocketpp::message_buffer::alloc::con_msg_manager> > >(std::weak_ptr<void> && a1, std::shared_ptr<websocketpp::message_buffer::message<websocketpp::message_buffer::alloc::con_msg_manager> > && a2) 行 1247 C++
  PhConfOne.exe!boost::detail::function::void_function_obj_invoker2<boost::_bi::bind_t<void,boost::_mfi::mf2<void,sio::client_impl,std::weak_ptr<void>,std::shared_ptr<websocketpp::message_buffer::message<websocketpp::message_buffer::alloc::con_msg_manager> > >,boost::_bi::list3<boost::_bi::value<sio::client_impl *>,boost::arg<1>,boost::arg<2> > >,void,std::weak_ptr<void>,std::shared_ptr<websocketpp::message_buffer::message<websocketpp::message_buffer::alloc::con_msg_manager> > >::invoke(boost::detail::function::function_buffer & function_obj_ptr, std::weak_ptr<void> a0, std::shared_ptr<websocketpp::message_buffer::message<websocketpp::message_buffer::alloc::con_msg_manager> > a1) 行 160 C++
  PhConfOne.exe!boost::function2<void,std::weak_ptr<void>,std::shared_ptr<websocketpp::message_buffer::message<websocketpp::message_buffer::alloc::con_msg_manager> > >::operator()(std::weak_ptr<void> a0, std::shared_ptr<websocketpp::message_buffer::message<websocketpp::message_buffer::alloc::con_msg_manager> > a1) 行 770 C++
  PhConfOne.exe!websocketpp::connection<websocketpp::config::debug_asio_tls>::handle_read_frame(const std::error_code & ec, unsigned int bytes_transferred) 行 1102 C++
  PhConfOne.exe!boost::_mfi::mf2<void,websocketpp::connection<websocketpp::config::debug_asio_tls>,std::error_code const &,unsigned int>::operator()(websocketpp::connection<websocketpp::config::debug_asio_tls> * p, const std::error_code & a1, unsigned int a2) 行 281 C++
  PhConfOne.exe!boost::_bi::list3<boost::_bi::value<websocketpp::connection<websocketpp::config::debug_asio_tls> *>,boost::arg<1>,boost::arg<2> >::operator()<boost::_mfi::mf2<void,websocketpp::connection<websocketpp::config::debug_asio_tls>,std::error_code const &,unsigned int>,boost::_bi::rrlist2<std::error_code const &,unsigned int> >(boost::_bi::type<void> __formal, boost::_mfi::mf2<void,websocketpp::connection<websocketpp::config::debug_asio_tls>,std::error_code const &,unsigned int> & f, boost::_bi::rrlist2<std::error_code const &,unsigned int> & a, int __formal) 行 399 C++
  PhConfOne.exe!boost::_bi::bind_t<void,boost::_mfi::mf2<void,websocketpp::connection<websocketpp::config::debug_asio_tls>,std::error_code const &,unsigned int>,boost::_bi::list3<boost::_bi::value<websocketpp::connection<websocketpp::config::debug_asio_tls> *>,boost::arg<1>,boost::arg<2> > >::operator()<std::error_code const &,unsigned int>(const std::error_code & a1, unsigned int && a2) 行 1247 C++
  PhConfOne.exe!boost::detail::function::void_function_obj_invoker2<boost::_bi::bind_t<void,boost::_mfi::mf2<void,websocketpp::connection<websocketpp::config::debug_asio_tls>,std::error_code const &,unsigned int>,boost::_bi::list3<boost::_bi::value<websocketpp::connection<websocketpp::config::debug_asio_tls> *>,boost::arg<1>,boost::arg<2> > >,void,std::error_code const &,unsigned int>::invoke(boost::detail::function::function_buffer & function_obj_ptr, const std::error_code & a0, unsigned int a1) 行 160 C++
  PhConfOne.exe!boost::function2<void,std::error_code const &,unsigned int>::operator()(const std::error_code & a0, unsigned int a1) 行 770 C++
  PhConfOne.exe!websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>::handle_async_read(boost::function<void __cdecl(std::error_code const &,unsigned int)> handler, const boost::system::error_code & ec, unsigned int bytes_transferred) 行 897 C++
  PhConfOne.exe!boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>::call<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> >,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const ,unsigned int>(std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > & u, const void * __formal, boost::function<void __cdecl(std::error_code const &,unsigned int)> & b1, const boost::system::error_code & b2, unsigned int & b3) 行 385 C++
  PhConfOne.exe!boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>::operator()<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >(std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > & u, boost::function<void __cdecl(std::error_code const &,unsigned int)> a1, const boost::system::error_code & a2, unsigned int a3) 行 399 C++
  PhConfOne.exe!boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> >::operator()<boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::rrlist2<boost::system::error_code &,unsigned int &> >(boost::_bi::type<void> __formal, boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int> & f, boost::_bi::rrlist2<boost::system::error_code &,unsigned int &> & a, int __formal) 行 464 C++
  PhConfOne.exe!boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > >::operator()<boost::system::error_code &,unsigned int &>(boost::system::error_code & a1, unsigned int & a2) 行 1247 C++
  PhConfOne.exe!websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > >::operator()<boost::system::error_code,unsigned int>(boost::system::error_code arg1, unsigned int arg2) 行 107 C++
  PhConfOne.exe!boost::asio::detail::binder2<websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > >,boost::system::error_code,unsigned int>::operator()() 行 129 C++
  PhConfOne.exe!boost::asio::asio_handler_invoke<boost::asio::detail::binder2<websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > >,boost::system::error_code,unsigned int> >(boost::asio::detail::binder2<websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > >,boost::system::error_code,unsigned int> & function, ...) 行 70 C++
  PhConfOne.exe!boost_asio_handler_invoke_helpers::invoke<boost::asio::detail::binder2<websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > >,boost::system::error_code,unsigned int>,websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > > >(boost::asio::detail::binder2<websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > >,boost::system::error_code,unsigned int> & function, websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > > & context) 行 37 C++
  PhConfOne.exe!boost::asio::detail::asio_handler_invoke<boost::asio::detail::binder2<websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > >,boost::system::error_code,unsigned int>,websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > >,boost::system::error_code,unsigned int>(boost::asio::detail::binder2<websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > >,boost::system::error_code,unsigned int> & function, boost::asio::detail::binder2<websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > >,boost::system::error_code,unsigned int> * this_handler) 行 170 C++
  PhConfOne.exe!boost_asio_handler_invoke_helpers::invoke<boost::asio::detail::binder2<websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > >,boost::system::error_code,unsigned int>,boost::asio::detail::binder2<websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > >,boost::system::error_code,unsigned int> >(boost::asio::detail::binder2<websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > >,boost::system::error_code,unsigned int> & function, boost::asio::detail::binder2<websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > >,boost::system::error_code,unsigned int> & context) 行 37 C++
  PhConfOne.exe!boost::asio::detail::strand_service::dispatch<boost::asio::detail::binder2<websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > >,boost::system::error_code,unsigned int> >(boost::asio::detail::strand_service::strand_impl * & impl, boost::asio::detail::binder2<websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > >,boost::system::error_code,unsigned int> & handler) 行 62 C++
  PhConfOne.exe!boost::asio::io_service::strand::dispatch<boost::asio::detail::binder2<websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > >,boost::system::error_code,unsigned int> >(boost::asio::detail::binder2<websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > >,boost::system::error_code,unsigned int> && handler) 行 160 C++
  PhConfOne.exe!boost::asio::detail::wrapped_handler<boost::asio::io_service::strand,websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > >,boost::asio::detail::is_continuation_if_running>::operator()<boost::system::error_code,unsigned int>(const boost::system::error_code & arg1, const unsigned int & arg2) 行 99 C++
  PhConfOne.exe!boost::asio::detail::read_op<boost::asio::ssl::stream<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> > >,boost::asio::mutable_buffers_1,boost::asio::detail::transfer_at_least_t,boost::asio::detail::wrapped_handler<boost::asio::io_service::strand,websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > >,boost::asio::detail::is_continuation_if_running> >::operator()(const boost::system::error_code & ec, unsigned int bytes_transferred, int start) 行 284 C++
  PhConfOne.exe!boost::asio::ssl::detail::read_op<boost::asio::mutable_buffers_1>::call_handler<boost::asio::detail::read_op<boost::asio::ssl::stream<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> > >,boost::asio::mutable_buffers_1,boost::asio::detail::transfer_at_least_t,boost::asio::detail::wrapped_handler<boost::asio::io_service::strand,websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > >,boost::asio::detail::is_continuation_if_running> > >(boost::asio::detail::read_op<boost::asio::ssl::stream<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> > >,boost::asio::mutable_buffers_1,boost::asio::detail::transfer_at_least_t,boost::asio::detail::wrapped_handler<boost::asio::io_service::strand,websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > >,boost::asio::detail::is_continuation_if_running> > & handler, const boost::system::error_code & ec, const unsigned int & bytes_transferred) 行 60 C++
  PhConfOne.exe!boost::asio::ssl::detail::io_op<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> >,boost::asio::ssl::detail::read_op<boost::asio::mutable_buffers_1>,boost::asio::detail::read_op<boost::asio::ssl::stream<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> > >,boost::asio::mutable_buffers_1,boost::asio::detail::transfer_at_least_t,boost::asio::detail::wrapped_handler<boost::asio::io_service::strand,websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > >,boost::asio::detail::is_continuation_if_running> > >::operator()(boost::system::error_code ec, unsigned int bytes_transferred, int start) 行 271 C++
  PhConfOne.exe!boost::asio::detail::binder2<boost::asio::ssl::detail::io_op<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> >,boost::asio::ssl::detail::read_op<boost::asio::mutable_buffers_1>,boost::asio::detail::read_op<boost::asio::ssl::stream<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> > >,boost::asio::mutable_buffers_1,boost::asio::detail::transfer_at_least_t,boost::asio::detail::wrapped_handler<boost::asio::io_service::strand,websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > >,boost::asio::detail::is_continuation_if_running> > >,boost::system::error_code,unsigned int>::operator()() 行 129 C++
  PhConfOne.exe!boost::asio::detail::rewrapped_handler<boost::asio::detail::binder2<boost::asio::ssl::detail::io_op<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> >,boost::asio::ssl::detail::read_op<boost::asio::mutable_buffers_1>,boost::asio::detail::read_op<boost::asio::ssl::stream<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> > >,boost::asio::mutable_buffers_1,boost::asio::detail::transfer_at_least_t,boost::asio::detail::wrapped_handler<boost::asio::io_service::strand,websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > >,boost::asio::detail::is_continuation_if_running> > >,boost::system::error_code,unsigned int>,websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > > >::operator()() 行 192 C++
  PhConfOne.exe!boost::asio::asio_handler_invoke<boost::asio::detail::rewrapped_handler<boost::asio::detail::binder2<boost::asio::ssl::detail::io_op<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> >,boost::asio::ssl::detail::read_op<boost::asio::mutable_buffers_1>,boost::asio::detail::read_op<boost::asio::ssl::stream<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> > >,boost::asio::mutable_buffers_1,boost::asio::detail::transfer_at_least_t,boost::asio::detail::wrapped_handler<boost::asio::io_service::strand,websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > >,boost::asio::detail::is_continuation_if_running> > >,boost::system::error_code,unsigned int>,websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > > > >(boost::asio::detail::rewrapped_handler<boost::asio::detail::binder2<boost::asio::ssl::detail::io_op<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> >,boost::asio::ssl::detail::read_op<boost::asio::mutable_buffers_1>,boost::asio::detail::read_op<boost::asio::ssl::stream<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> > >,boost::asio::mutable_buffers_1,boost::asio::detail::transfer_at_least_t,boost::asio::detail::wrapped_handler<boost::asio::io_service::strand,websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > >,boost::asio::detail::is_continuation_if_running> > >,boost::system::error_code,unsigned int>,websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > > > & function, ...) 行 70 C++
  PhConfOne.exe!??@2c99fe2db5450f04b28f62b9da9ca71b@(boost::asio::detail::rewrapped_handler<boost::asio::detail::binder2<boost::asio::ssl::detail::io_op<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> >,boost::asio::ssl::detail::read_op<boost::asio::mutable_buffers_1>,boost::asio::detail::read_op<boost::asio::ssl::stream<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> > >,boost::asio::mutable_buffers_1,boost::asio::detail::transfer_at_least_t,boost::asio::detail::wrapped_handler<boost::asio::io_service::strand,websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > >,boost::asio::detail::is_continuation_if_running> > >,boost::system::error_code,unsigned int>,websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > > > & function, websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > > & context) 行 37 C++
  PhConfOne.exe!??@cab6e9a1104d934eca60a78c37b326c1@(boost::asio::detail::rewrapped_handler<boost::asio::detail::binder2<boost::asio::ssl::detail::io_op<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> >,boost::asio::ssl::detail::read_op<boost::asio::mutable_buffers_1>,boost::asio::detail::read_op<boost::asio::ssl::stream<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> > >,boost::asio::mutable_buffers_1,boost::asio::detail::transfer_at_least_t,boost::asio::detail::wrapped_handler<boost::asio::io_service::strand,websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > >,boost::asio::detail::is_continuation_if_running> > >,boost::system::error_code,unsigned int>,websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > > > & function, boost::asio::detail::rewrapped_handler<boost::asio::detail::binder2<boost::asio::ssl::detail::io_op<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> >,boost::asio::ssl::detail::read_op<boost::asio::mutable_buffers_1>,boost::asio::detail::read_op<boost::asio::ssl::stream<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> > >,boost::asio::mutable_buffers_1,boost::asio::detail::transfer_at_least_t,boost::asio::detail::wrapped_handler<boost::asio::io_service::strand,websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > >,boost::asio::detail::is_continuation_if_running> > >,boost::system::error_code,unsigned int>,websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > > > * this_handler) 行 275 C++
  PhConfOne.exe!boost_asio_handler_invoke_helpers::invoke<boost::asio::detail::rewrapped_handler<boost::asio::detail::binder2<boost::asio::ssl::detail::io_op<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> >,boost::asio::ssl::detail::read_op<boost::asio::mutable_buffers_1>,boost::asio::detail::read_op<boost::asio::ssl::stream<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> > >,boost::asio::mutable_buffers_1,boost::asio::detail::transfer_at_least_t,boost::asio::detail::wrapped_handler<boost::asio::io_service::strand,websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > >,boost::asio::detail::is_continuation_if_running> > >,boost::system::error_code,unsigned int>,websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > > >,boost::asio::detail::rewrapped_handler<boost::asio::detail::binder2<boost::asio::ssl::detail::io_op<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> >,boost::asio::ssl::detail::read_op<boost::asio::mutable_buffers_1>,boost::asio::detail::read_op<boost::asio::ssl::stream<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> > >,boost::asio::mutable_buffers_1,boost::asio::detail::transfer_at_least_t,boost::asio::detail::wrapped_handler<boost::asio::io_service::strand,websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > >,boost::asio::detail::is_continuation_if_running> > >,boost::system::error_code,unsigned int>,websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > > > >(boost::asio::detail::rewrapped_handler<boost::asio::detail::binder2<boost::asio::ssl::detail::io_op<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> >,boost::asio::ssl::detail::read_op<boost::asio::mutable_buffers_1>,boost::asio::detail::read_op<boost::asio::ssl::stream<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> > >,boost::asio::mutable_buffers_1,boost::asio::detail::transfer_at_least_t,boost::asio::detail::wrapped_handler<boost::asio::io_service::strand,websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > >,boost::asio::detail::is_continuation_if_running> > >,boost::system::error_code,unsigned int>,websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > > > & function, boost::asio::detail::rewrapped_handler<boost::asio::detail::binder2<boost::asio::ssl::detail::io_op<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> >,boost::asio::ssl::detail::read_op<boost::asio::mutable_buffers_1>,boost::asio::detail::read_op<boost::asio::ssl::stream<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> > >,boost::asio::mutable_buffers_1,boost::asio::detail::transfer_at_least_t,boost::asio::detail::wrapped_handler<boost::asio::io_service::strand,websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > >,boost::asio::detail::is_continuation_if_running> > >,boost::system::error_code,unsigned int>,websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > > > & context) 行 37 C++
  PhConfOne.exe!boost::asio::detail::completion_handler<boost::asio::detail::rewrapped_handler<boost::asio::detail::binder2<boost::asio::ssl::detail::io_op<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> >,boost::asio::ssl::detail::read_op<boost::asio::mutable_buffers_1>,boost::asio::detail::read_op<boost::asio::ssl::stream<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> > >,boost::asio::mutable_buffers_1,boost::asio::detail::transfer_at_least_t,boost::asio::detail::wrapped_handler<boost::asio::io_service::strand,websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > >,boost::asio::detail::is_continuation_if_running> > >,boost::system::error_code,unsigned int>,websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > > > >::do_complete(boost::asio::detail::win_iocp_io_service * owner, boost::asio::detail::win_iocp_operation * base, const boost::system::error_code & __formal, unsigned int __formal) 行 68 C++
  PhConfOne.exe!boost::asio::detail::strand_service::dispatch<boost::asio::detail::rewrapped_handler<boost::asio::detail::binder2<boost::asio::ssl::detail::io_op<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> >,boost::asio::ssl::detail::read_op<boost::asio::mutable_buffers_1>,boost::asio::detail::read_op<boost::asio::ssl::stream<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> > >,boost::asio::mutable_buffers_1,boost::asio::detail::transfer_at_least_t,boost::asio::detail::wrapped_handler<boost::asio::io_service::strand,websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > >,boost::asio::detail::is_continuation_if_running> > >,boost::system::error_code,unsigned int>,websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > > > >(boost::asio::detail::strand_service::strand_impl * & impl, boost::asio::detail::rewrapped_handler<boost::asio::detail::binder2<boost::asio::ssl::detail::io_op<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> >,boost::asio::ssl::detail::read_op<boost::asio::mutable_buffers_1>,boost::asio::detail::read_op<boost::asio::ssl::stream<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> > >,boost::asio::mutable_buffers_1,boost::asio::detail::transfer_at_least_t,boost::asio::detail::wrapped_handler<boost::asio::io_service::strand,websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > >,boost::asio::detail::is_continuation_if_running> > >,boost::system::error_code,unsigned int>,websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > > > & handler) 行 88 C++
  PhConfOne.exe!boost::asio::io_service::strand::dispatch<boost::asio::detail::rewrapped_handler<boost::asio::detail::binder2<boost::asio::ssl::detail::io_op<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> >,boost::asio::ssl::detail::read_op<boost::asio::mutable_buffers_1>,boost::asio::detail::read_op<boost::asio::ssl::stream<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> > >,boost::asio::mutable_buffers_1,boost::asio::detail::transfer_at_least_t,boost::asio::detail::wrapped_handler<boost::asio::io_service::strand,websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > >,boost::asio::detail::is_continuation_if_running> > >,boost::system::error_code,unsigned int>,websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > > > >(boost::asio::detail::rewrapped_handler<boost::asio::detail::binder2<boost::asio::ssl::detail::io_op<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> >,boost::asio::ssl::detail::read_op<boost::asio::mutable_buffers_1>,boost::asio::detail::read_op<boost::asio::ssl::stream<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> > >,boost::asio::mutable_buffers_1,boost::asio::detail::transfer_at_least_t,boost::asio::detail::wrapped_handler<boost::asio::io_service::strand,websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > >,boost::asio::detail::is_continuation_if_running> > >,boost::system::error_code,unsigned int>,websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > > > && handler) 行 160 C++
  PhConfOne.exe!boost::asio::detail::asio_handler_invoke<boost::asio::detail::binder2<boost::asio::ssl::detail::io_op<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> >,boost::asio::ssl::detail::read_op<boost::asio::mutable_buffers_1>,boost::asio::detail::read_op<boost::asio::ssl::stream<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> > >,boost::asio::mutable_buffers_1,boost::asio::detail::transfer_at_least_t,boost::asio::detail::wrapped_handler<boost::asio::io_service::strand,websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > >,boost::asio::detail::is_continuation_if_running> > >,boost::system::error_code,unsigned int>,boost::asio::io_service::strand,websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > >,boost::asio::detail::is_continuation_if_running>(boost::asio::detail::binder2<boost::asio::ssl::detail::io_op<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> >,boost::asio::ssl::detail::read_op<boost::asio::mutable_buffers_1>,boost::asio::detail::read_op<boost::asio::ssl::stream<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> > >,boost::asio::mutable_buffers_1,boost::asio::detail::transfer_at_least_t,boost::asio::detail::wrapped_handler<boost::asio::io_service::strand,websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > >,boost::asio::detail::is_continuation_if_running> > >,boost::system::error_code,unsigned int> & function, boost::asio::detail::wrapped_handler<boost::asio::io_service::strand,websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > >,boost::asio::detail::is_continuation_if_running> * this_handler) 行 232 C++
  PhConfOne.exe!boost_asio_handler_invoke_helpers::invoke<boost::asio::detail::binder2<boost::asio::ssl::detail::io_op<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> >,boost::asio::ssl::detail::read_op<boost::asio::mutable_buffers_1>,boost::asio::detail::read_op<boost::asio::ssl::stream<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> > >,boost::asio::mutable_buffers_1,boost::asio::detail::transfer_at_least_t,boost::asio::detail::wrapped_handler<boost::asio::io_service::strand,websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > >,boost::asio::detail::is_continuation_if_running> > >,boost::system::error_code,unsigned int>,boost::asio::detail::wrapped_handler<boost::asio::io_service::strand,websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > >,boost::asio::detail::is_continuation_if_running> >(boost::asio::detail::binder2<boost::asio::ssl::detail::io_op<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> >,boost::asio::ssl::detail::read_op<boost::asio::mutable_buffers_1>,boost::asio::detail::read_op<boost::asio::ssl::stream<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> > >,boost::asio::mutable_buffers_1,boost::asio::detail::transfer_at_least_t,boost::asio::detail::wrapped_handler<boost::asio::io_service::strand,websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > >,boost::asio::detail::is_continuation_if_running> > >,boost::system::error_code,unsigned int> & function, boost::asio::detail::wrapped_handler<boost::asio::io_service::strand,websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > >,boost::asio::detail::is_continuation_if_running> & context) 行 37 C++
  PhConfOne.exe!boost::asio::detail::asio_handler_invoke<boost::asio::detail::binder2<boost::asio::ssl::detail::io_op<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> >,boost::asio::ssl::detail::read_op<boost::asio::mutable_buffers_1>,boost::asio::detail::read_op<boost::asio::ssl::stream<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> > >,boost::asio::mutable_buffers_1,boost::asio::detail::transfer_at_least_t,boost::asio::detail::wrapped_handler<boost::asio::io_service::strand,websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > >,boost::asio::detail::is_continuation_if_running> > >,boost::system::error_code,unsigned int>,boost::asio::ssl::stream<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> > >,boost::asio::mutable_buffers_1,boost::asio::detail::transfer_at_least_t,boost::asio::detail::wrapped_handler<boost::asio::io_service::strand,websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > >,boost::asio::detail::is_continuation_if_running> >(boost::asio::detail::binder2<boost::asio::ssl::detail::io_op<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> >,boost::asio::ssl::detail::read_op<boost::asio::mutable_buffers_1>,boost::asio::detail::read_op<boost::asio::ssl::stream<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> > >,boost::asio::mutable_buffers_1,boost::asio::detail::transfer_at_least_t,boost::asio::detail::wrapped_handler<boost::asio::io_service::strand,websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > >,boost::asio::detail::is_continuation_if_running> > >,boost::system::error_code,unsigned int> & function, boost::asio::detail::read_op<boost::asio::ssl::stream<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> > >,boost::asio::mutable_buffers_1,boost::asio::detail::transfer_at_least_t,boost::asio::detail::wrapped_handler<boost::asio::io_service::strand,websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > >,boost::asio::detail::is_continuation_if_running> > * this_handler) 行 502 C++
  PhConfOne.exe!boost_asio_handler_invoke_helpers::invoke<boost::asio::detail::binder2<boost::asio::ssl::detail::io_op<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> >,boost::asio::ssl::detail::read_op<boost::asio::mutable_buffers_1>,boost::asio::detail::read_op<boost::asio::ssl::stream<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> > >,boost::asio::mutable_buffers_1,boost::asio::detail::transfer_at_least_t,boost::asio::detail::wrapped_handler<boost::asio::io_service::strand,websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > >,boost::asio::detail::is_continuation_if_running> > >,boost::system::error_code,unsigned int>,boost::asio::detail::read_op<boost::asio::ssl::stream<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> > >,boost::asio::mutable_buffers_1,boost::asio::detail::transfer_at_least_t,boost::asio::detail::wrapped_handler<boost::asio::io_service::strand,websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > >,boost::asio::detail::is_continuation_if_running> > >(boost::asio::detail::binder2<boost::asio::ssl::detail::io_op<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> >,boost::asio::ssl::detail::read_op<boost::asio::mutable_buffers_1>,boost::asio::detail::read_op<boost::asio::ssl::stream<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> > >,boost::asio::mutable_buffers_1,boost::asio::detail::transfer_at_least_t,boost::asio::detail::wrapped_handler<boost::asio::io_service::strand,websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > >,boost::asio::detail::is_continuation_if_running> > >,boost::system::error_code,unsigned int> & function, boost::asio::detail::read_op<boost::asio::ssl::stream<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> > >,boost::asio::mutable_buffers_1,boost::asio::detail::transfer_at_least_t,boost::asio::detail::wrapped_handler<boost::asio::io_service::strand,websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > >,boost::asio::detail::is_continuation_if_running> > & context) 行 37 C++
  PhConfOne.exe!boost::asio::ssl::detail::asio_handler_invoke<boost::asio::detail::binder2<boost::asio::ssl::detail::io_op<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> >,boost::asio::ssl::detail::read_op<boost::asio::mutable_buffers_1>,boost::asio::detail::read_op<boost::asio::ssl::stream<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> > >,boost::asio::mutable_buffers_1,boost::asio::detail::transfer_at_least_t,boost::asio::detail::wrapped_handler<boost::asio::io_service::strand,websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > >,boost::asio::detail::is_continuation_if_running> > >,boost::system::error_code,unsigned int>,boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> >,boost::asio::ssl::detail::read_op<boost::asio::mutable_buffers_1>,boost::asio::detail::read_op<boost::asio::ssl::stream<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> > >,boost::asio::mutable_buffers_1,boost::asio::detail::transfer_at_least_t,boost::asio::detail::wrapped_handler<boost::asio::io_service::strand,websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > >,boost::asio::detail::is_continuation_if_running> > >(boost::asio::detail::binder2<boost::asio::ssl::detail::io_op<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> >,boost::asio::ssl::detail::read_op<boost::asio::mutable_buffers_1>,boost::asio::detail::read_op<boost::asio::ssl::stream<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> > >,boost::asio::mutable_buffers_1,boost::asio::detail::transfer_at_least_t,boost::asio::detail::wrapped_handler<boost::asio::io_service::strand,websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > >,boost::asio::detail::is_continuation_if_running> > >,boost::system::error_code,unsigned int> & function, boost::asio::ssl::detail::io_op<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> >,boost::asio::ssl::detail::read_op<boost::asio::mutable_buffers_1>,boost::asio::detail::read_op<boost::asio::ssl::stream<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> > >,boost::asio::mutable_buffers_1,boost::asio::detail::transfer_at_least_t,boost::asio::detail::wrapped_handler<boost::asio::io_service::strand,websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > >,boost::asio::detail::is_continuation_if_running> > > * this_handler) 行 320 C++
  PhConfOne.exe!boost_asio_handler_invoke_helpers::invoke<boost::asio::detail::binder2<boost::asio::ssl::detail::io_op<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> >,boost::asio::ssl::detail::read_op<boost::asio::mutable_buffers_1>,boost::asio::detail::read_op<boost::asio::ssl::stream<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> > >,boost::asio::mutable_buffers_1,boost::asio::detail::transfer_at_least_t,boost::asio::detail::wrapped_handler<boost::asio::io_service::strand,websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > >,boost::asio::detail::is_continuation_if_running> > >,boost::system::error_code,unsigned int>,boost::asio::ssl::detail::io_op<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> >,boost::asio::ssl::detail::read_op<boost::asio::mutable_buffers_1>,boost::asio::detail::read_op<boost::asio::ssl::stream<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> > >,boost::asio::mutable_buffers_1,boost::asio::detail::transfer_at_least_t,boost::asio::detail::wrapped_handler<boost::asio::io_service::strand,websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > >,boost::asio::detail::is_continuation_if_running> > > >(boost::asio::detail::binder2<boost::asio::ssl::detail::io_op<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> >,boost::asio::ssl::detail::read_op<boost::asio::mutable_buffers_1>,boost::asio::detail::read_op<boost::asio::ssl::stream<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> > >,boost::asio::mutable_buffers_1,boost::asio::detail::transfer_at_least_t,boost::asio::detail::wrapped_handler<boost::asio::io_service::strand,websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > >,boost::asio::detail::is_continuation_if_running> > >,boost::system::error_code,unsigned int> & function, boost::asio::ssl::detail::io_op<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> >,boost::asio::ssl::detail::read_op<boost::asio::mutable_buffers_1>,boost::asio::detail::read_op<boost::asio::ssl::stream<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> > >,boost::asio::mutable_buffers_1,boost::asio::detail::transfer_at_least_t,boost::asio::detail::wrapped_handler<boost::asio::io_service::strand,websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > >,boost::asio::detail::is_continuation_if_running> > > & context) 行 37 C++
  PhConfOne.exe!boost::asio::detail::win_iocp_socket_recv_op<boost::asio::mutable_buffers_1,boost::asio::ssl::detail::io_op<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> >,boost::asio::ssl::detail::read_op<boost::asio::mutable_buffers_1>,boost::asio::detail::read_op<boost::asio::ssl::stream<boost::asio::basic_stream_socket<boost::asio::ip::tcp,boost::asio::stream_socket_service<boost::asio::ip::tcp> > >,boost::asio::mutable_buffers_1,boost::asio::detail::transfer_at_least_t,boost::asio::detail::wrapped_handler<boost::asio::io_service::strand,websocketpp::transport::asio::custom_alloc_handler<boost::_bi::bind_t<void,boost::_mfi::mf3<void,websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config>,boost::function<void __cdecl(std::error_code const &,unsigned int)>,boost::system::error_code const &,unsigned int>,boost::_bi::list4<boost::_bi::value<std::shared_ptr<websocketpp::transport::asio::connection<websocketpp::config::debug_asio_tls::transport_config> > >,boost::_bi::value<boost::function<void __cdecl(std::error_code const &,unsigned int)> >,boost::arg<1>,boost::arg<2> > > >,boost::asio::detail::is_continuation_if_running> > > >::do_complete(boost::asio::detail::win_iocp_io_service * owner, boost::asio::detail::win_iocp_operation * base, const boost::system::error_code & result_ec, unsigned int bytes_transferred) 行 97 C++
  PhConfOne.exe!boost::asio::detail::win_iocp_operation::complete(boost::asio::detail::win_iocp_io_service & owner, const boost::system::error_code & ec, unsigned int bytes_transferred) 行 46 C++
  PhConfOne.exe!boost::asio::detail::win_iocp_io_service::do_one(bool block, boost::system::error_code & ec) 行 406 C++
  PhConfOne.exe!boost::asio::detail::win_iocp_io_service::run(boost::system::error_code & ec) 行 164 C++
  PhConfOne.exe!boost::asio::io_service::run() 行 59 C++
  PhConfOne.exe!websocketpp::transport::asio::endpoint<websocketpp::config::debug_asio_tls::transport_config>::run() 行 615 C++
  PhConfOne.exe!sio::client_impl::run_loop() 行 196 C++
  PhConfOne.exe!boost::_mfi::mf0<void,sio::client_impl>::operator()(sio::client_impl * p) 行 50 C++
  PhConfOne.exe!boost::_bi::list1<boost::_bi::value<sio::client_impl *> >::operator()<boost::_mfi::mf0<void,sio::client_impl>,boost::_bi::list0>(boost::_bi::type<void> __formal, boost::_mfi::mf0<void,sio::client_impl> & f, boost::_bi::list0 & a, int __formal) 行 260 C++
  PhConfOne.exe!boost::_bi::bind_t<void,boost::_mfi::mf0<void,sio::client_impl>,boost::_bi::list1<boost::_bi::value<sio::client_impl *> > >::operator()() 行 1223 C++
  PhConfOne.exe!std::_Invoker_functor::_Call<boost::_bi::bind_t<void,boost::_mfi::mf0<void,sio::client_impl>,boost::_bi::list1<boost::_bi::value<sio::client_impl *> > > >(boost::_bi::bind_t<void,boost::_mfi::mf0<void,sio::client_impl>,boost::_bi::list1<boost::_bi::value<sio::client_impl *> > > && _Obj) 行 1377 C++
  PhConfOne.exe!std::invoke<boost::_bi::bind_t<void,boost::_mfi::mf0<void,sio::client_impl>,boost::_bi::list1<boost::_bi::value<sio::client_impl *> > > >(boost::_bi::bind_t<void,boost::_mfi::mf0<void,sio::client_impl>,boost::_bi::list1<boost::_bi::value<sio::client_impl *> > > && _Obj) 行 1443 C++
  PhConfOne.exe!std::_LaunchPad<std::unique_ptr<std::tuple<boost::_bi::bind_t<void,boost::_mfi::mf0<void,sio::client_impl>,boost::_bi::list1<boost::_bi::value<sio::client_impl *> > > >,std::default_delete<std::tuple<boost::_bi::bind_t<void,boost::_mfi::mf0<void,sio::client_impl>,boost::_bi::list1<boost::_bi::value<sio::client_impl *> > > > > > >::_Execute<0>(std::tuple<boost::_bi::bind_t<void,boost::_mfi::mf0<void,sio::client_impl>,boost::_bi::list1<boost::_bi::value<sio::client_impl *> > > > & _Tup, std::integer_sequence<unsigned int,0> __formal) 行 240 C++
  PhConfOne.exe!std::_LaunchPad<std::unique_ptr<std::tuple<boost::_bi::bind_t<void,boost::_mfi::mf0<void,sio::client_impl>,boost::_bi::list1<boost::_bi::value<sio::client_impl *> > > >,std::default_delete<std::tuple<boost::_bi::bind_t<void,boost::_mfi::mf0<void,sio::client_impl>,boost::_bi::list1<boost::_bi::value<sio::client_impl *> > > > > > >::_Run(std::_LaunchPad<std::unique_ptr<std::tuple<boost::_bi::bind_t<void,boost::_mfi::mf0<void,sio::client_impl>,boost::_bi::list1<boost::_bi::value<sio::client_impl *> > > >,std::default_delete<std::tuple<boost::_bi::bind_t<void,boost::_mfi::mf0<void,sio::client_impl>,boost::_bi::list1<boost::_bi::value<sio::client_impl *> > > > > > > * _Ln) 行 247 C++
  PhConfOne.exe!std::_LaunchPad<std::unique_ptr<std::tuple<boost::_bi::bind_t<void,boost::_mfi::mf0<void,sio::client_impl>,boost::_bi::list1<boost::_bi::value<sio::client_impl *> > > >,std::default_delete<std::tuple<boost::_bi::bind_t<void,boost::_mfi::mf0<void,sio::client_impl>,boost::_bi::list1<boost::_bi::value<sio::client_impl *> > > > > > >::_Go() 行 232 C++
  PhConfOne.exe!std::_Pad::_Call_func(void * _Data) 行 210 C++
  PhConfOne.exe!invoke_thread_procedure(unsigned int(__stdcall*)(void *) procedure, void * const context) 行 92 C++
  PhConfOne.exe!thread_start<unsigned int (__stdcall*)(void *)>(void * const parameter) 行 115 C++
YanbinZ_Intel
你好
我们不能重现这个问题, 在我们提供的Windows SDK 就是在OnStreamAdded 函数的成功回调中 subscribe remote stream. 请提供一下server 端配置和client端配置比如说codec, resolution 等 并检查你这边的环境和代码是否正确。
chen__fei
我这边iOS(3.4.0)也遇到订阅流失败,后续无法在操作的问题,请问这是什么原因?
 RTCConferenceSubscribeOptions *option = [[RTCConferenceSubscribeOptions alloc] init];
            option.videoQualityLevel = RTCConferenceVideoQualityLevelStandard;
            if (level >= RTCConferenceVideoQualityLevelBestQuality && level <= RTCConferenceVideoQualityLevelBestSpeed)
                option.videoQualityLevel = (RTCConferenceVideoQualityLevel)level;
