Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
Intermediate certificate
Roland_B_
I have bought a SSL certificate from RapidSSL and copied it as 'certificate.pfx' to the two 'cert' directories.
Chrome accepts the SSL certificate, but Firefox does NOT.
It seems like Firefox needs the intermediate certificate from RapidSSL. Is it possible to supply this intermediate certificate through Intel WebRTC server?
Thank you.
Roland Bürkel
Roland_B_
I have fixed it by myself:
I have "merged" three certificates (root, intermediate, server) into one 'certificate.pfx':
openssl genrsa -out server-key.pem 2048
openssl req -nodes -new -sha256 -key server-key.pem -out server-csr.pem
--> with 'server-csr.pem' buy a SSL certificate at e.g. RapidSSL
--> receive 'server-cert.pem' after buying
--> download root and intermediate certificates from e.g. RapidSSL
--> merge all 3 certificates into one:
cat intermediate.pem rapidSSL_Root_CA.pem > chain.pem
openssl pkcs12 -export -out certificate.pfx -inkey server-key.pem -in server-cert.pem -certfile chain.pem
cp certificate.pfx ~/Release-v3.0.1/cert/
bin/initcert.js all
cp certificate.pfx ~/Release-v3.0.1/extras/basic_example/cert/
node initcert.js
jin_l_1
i built a webrtc application, it works fine on Chrome browser, but not on Firefox. Do i have the same issue with the certificates?
Roland_B_
If you are using the self signed certificates which are created when installing the Intel-WebRTC-Server, then you have to visit the following addresses and confirm these certificates in the browser:
https://<serverIP>:8080
https://<serverIP>:8096
https://<serverIP>:443   ; // e.g. turnserver (?)
https://<serverIP>:3004
You can also try:   http://<serverIP>:3001
See also:   https://software.intel.com/en-us/forums/intel-collaboration-suite-for-webrtc/topic/623756
Chunbo_H_Intel1
Thanks for the sharing.
