Is possible to control remote streams in MIX conference . For example if i am admin i need to get the participant list based on that i can allow or reject the video from participants .
- Tags:
- HTML5
- JavaScript*
Please refer to rest API document for participant and stream control, related API are provided in rest API document
thank you,
we are able to get the participant list and also dropping the participant from the conference room based on the participant id,
but we are not getting how to allow the paricipant as guest to join the the room ,
can u please elaborate..
If you want to prevent participants from getting into mix, you can edit the sample and call mixStream based on your conditions.
For example, you can edit the file extras/basic_example/public/scripts/index.js, find "mixStream" calls and remove them to have a try.
