Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
Issue in Server Recording
shiva_s_
Im doing server recording in FullHD 1920x1080 resolution, After sometime im getting the below error and stoping recording automatically.
2019-09-27 10:22:41.725  - INFO: WorkingNode - pid: 11547
2019-09-27 10:22:41.728  - INFO: WorkingNode - Connecting to rabbitMQ server...
2019-09-27 10:22:41.754  - INFO: AmqpClient - Connecting to rabbitMQ server OK, options: { host: 'localhost', port: 5672 }
2019-09-27 10:22:41.776  - INFO: WorkingNode - recording-fea09f3b4dab811406d7@202.53.87.230_0 as rpc server ready
2019-09-27 10:22:41.782  - INFO: WorkingNode - recording-fea09f3b4dab811406d7@202.53.87.230_0 as monitor ready
2019-09-27 10:24:39,441  - INFO: owt.AVStreamOut - url /home/recordings/384784115175234240.mkv, audio 1, video 1, timeOut 300000
2019-09-27 10:24:39,457  - DEBUG: owt.media.MediaFileOut - onVideoSourceChanged
2019-09-27 10:24:39,467  - INFO: owt.AVStreamOut - Initial audio options format(OPUS), sample rate(48000), channels(2), isRtpPacket(1)
2019-09-27 10:24:39,966  - INFO: owt.AVStreamOut - Initial video options: format(VP8), 1920x1080
2019-09-27 12:13:38,987  - WARN: owt.AVStreamOut - No input frames available
2019-09-27 12:13:39.018  - ERROR: RecordingNode - media recording error: No input frames available( This is the main error)
2019-09-27 12:13:39,038  - INFO: owt.AVStreamOut - Close /home/recordings/384784115175234240.mkv
2019-09-27 12:13:39.073  - WARN: WorkingNode - Exiting on SIGTERM
david_c_1
I'm also experiencing the same error with the ics 4.0.1 version.
the problem also occurs at the same time in the streaming out.
Below the logs
2019-09-30 10:27:12,360  - INFO: woogeen.AVStreamOut - Initial audio options format(OPUS), sample rate(48000), channels(2), isRtpPacket(0)
2019-09-30 10:27:12,419  - INFO: woogeen.AVStreamOut - Initial video options: format(VP8), 1280x720
2019-09-30 10:35:44,783  - WARN: woogeen.AVStreamOut - No input frames available
2019-09-30 10:35:45.705  - ERROR: RecordingNode - media recording error: No input frames available
2019-09-30 10:27:10,300  - INFO: woogeen.AVStreamOut - Initial audio options format(AAC_48000_2), sample rate(48000), channels(2), isRtpPacket(0)
2019-09-30 10:27:10,332  - INFO: woogeen.AVStreamOut - Initial video options: format(H264), 1280x720
2019-09-30 10:35:45,134  - WARN: woogeen.AVStreamOut - No input frames available
2019-09-30 10:35:45.777  - ERROR: StreamingNode - avstream-out fatal error: No input frames available
shiva_s_
Hi Lei,
Can you please help me out.
Li_C_Intel
Can you confirm that source stream is not lost when that error occurs?
shiva_s_
Hi Li,
Yes i confirm the same the VC is happenning continously but recording error is occuring and the MCU is in Public Domain.
shiva_s_
Hi Lei,
It would be very usefull if we fix this recording issue please help me
Li_C_Intel
We cannot confirm this issue by limited logs. If you can reproduce this problem, edit the log4js_configuration file and mark the 'recodingNode' or something similar to 'DEBUG', restart recording-agent and collected the logs when that error occur.
For that error "No input frames available", it will be emitted when recording node does not get frames for a while.
shiva_s_
Dear Li,
Below are the logs we got after doing changes in log4js file.
2020-01-08 16:38:44.356  - INFO: WorkingNode - pid: 18367
2020-01-08 16:38:44.358  - INFO: WorkingNode - Connecting to rabbitMQ server...
2020-01-08 16:38:44.368  - INFO: AmqpClient - Connecting to rabbitMQ server OK, options: { host: 'localhost', port: 5672 }
2020-01-08 16:38:44.427  - INFO: WorkingNode - recording-bb7920df8b1995970877@10.10.10.3_1 as rpc server ready
2020-01-08 16:38:44.431  - INFO: WorkingNode - recording-bb7920df8b1995970877@10.10.10.3_1 as monitor ready
2020-01-09 08:56:42.612  - DEBUG: RecordingNode - subscribe, connectionId: 140652257694504620 connectionType: recording options: { controller: 'conference-673bb661a6be1f211abe@10.10.10.3_1',
  connection: { container: 'mkv' },
  media:
   { audio: { from: '928403785111126900' },
     video: { from: '928403785111126900' } } }
2020-01-09 08:56:42,618  - INFO: owt.AVStreamOut - url /home/recordings/140652257694504620.mkv, audio 1, video 1, timeOut 3000
2020-01-09 08:56:42.648  - DEBUG: RecordingNode - publish, connectionId: 928403785111126900 connectionType: internal options: { controller: 'conference-673bb661a6be1f211abe@10.10.10.3_1',
  publisher: 'KtBm7ZIEoJ07HBurAAAB',
  audio: { codec: 'opus_48000_2' },
  video: { codec: 'vp8' },
  ip: '10.10.10.3',
  port: 0 }
2020-01-09 08:56:42,664  - DEBUG: owt.media.MediaFileOut - onVideoSourceChanged
2020-01-09 08:56:42,679  - INFO: owt.AVStreamOut - Initial audio options format(OPUS), sample rate(48000), channels(2), isRtpPacket(1)
2020-01-09 08:56:42,800  - INFO: owt.AVStreamOut - Initial video options: format(VP8), 1920x1080
2020-01-09 10:09:19,117  - WARN: owt.AVStreamOut - No input frames available
2020-01-09 10:09:19.118  - ERROR: RecordingNode - media recording error: No input frames available
2020-01-09 10:09:19.128  - DEBUG: RecordingNode - unsubscribe, connectionId: 140652257694504620
2020-01-09 10:09:19,129  - INFO: owt.AVStreamOut - Close /home/recordings/140652257694504620.mkv
2020-01-09 10:09:19.133  - DEBUG: RecordingNode - unpublish, connectionId: 928403785111126900
2020-01-09 10:09:19.138  - WARN: WorkingNode - Exiting on SIGTERM
2020-01-09 10:09:19.139  - DEBUG: RecordingNode - close called
shiva_s_
Hi Li,
Any update?
Li_C_Intel
What stream were you recording? The logs only showed that at that time, there were no frames to record, so it stopped.
Can you confirm that the server received the stream continuously?
shiva_s_
Hi Li,
Im recording in farword stream and VC is still going on.
shiva_s_
Hi Li,
Waiting for your valuable response.
