Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
Issues with TURN server
SaiSrinivas_D_1
We are trying something typical.
Usually, when the call happens over webrtc, the ice candidates will take multiple udp ports and get relayed if the client is behind a NAT.
But, what we want is, we would like the candidates to be realyed over tcp only and that too, we want them to use a single tcp port.
Please advise if this is possible or not?
PS: We have already tried everything we could with the TURN server configuration file (like: no-udp, no-udp-relay etc,)
Thanks & Regards,
Srinivas
Chunbo_H_Intel1
One question is that are you having this issue on the client side or server side? Which type of clients if any?
Another thing that I have to confirm is that we do support TURN relay over TCP.
Thanks!
