Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
MCU with VCA card
I installed MCU cluster with a vca card
I have the audio/video agents run on the vca nodes
and the rest on the host system
I want to verify that hardware acceleration is used in vca nodes
video_agent/agent.toml has hardwareAccelerated = true
and I installed Media Server Studio on the node
video conference is working but
cpu time of video_agent is the same no matter if i enable hardware or not
intel_gpu_top it sows 100% all the time, no matter if there is a video conference or not
is it supposed to see videoMixer_hw running when in conference ?
I dont see it and i dont see either videoMixer_sw running
I appreciate any help
Tags (2)
Highlighted
Hi Babis,
Hi Babis,
     Please follow the steps to get GPU usage information:
1.  ssh to your vca node from E5 host server.
2. cd /opt/intel/mediasdk/tools/metrics_monitor/_bin
3. export LD_LIBRARY_PATH=/opt/intel/mediasdk/tools/metrics_monitor/_bin:$LD_LIBRARY_PATH
4. ./metrics_monitor
 You will get the GPU usage like RENDER usage, VIDEO0 usage, VIDEO0_E usage, VIDEO2 usage etc. Thanks. --Wenjie.
Highlighted
Hi Babis,
Hi Babis,
    If you use VCA persistent image, the Media Server Studio is default installed on the image. Thanks. --Wenjie.
Highlighted
Hi Babis,
Hi Babis,
       I installed MCU cluster with a vca card refer to VCA_SoftwareUserGuide_1_3.pdf, but it did't work
     Could you tell me which boot image was you used. Thanks
