I used android app to create a conference chat.But my network is 3G.
Theoretically, I press a join button,program will excute "create room">"get token">"join room">"publish localStream" and so on. But the 3G signal is not stable or strong, the whole proccess takes a long time.I have no patiece, the I press the exit button immediately. Finally,the MCU crash.
woogeen-nuve.stdout.log logs:
2016-09-04 22:30:28.097 - INFO: RoomsResource - Room created: e2fc00e7-5477-4ad3-9a5c-18ed8d421b0d for service sampleService 2016-09-04 22:30:28.423 - INFO: TokensResource - Created token for room 57cc3004b35a3c4ec3a00f61 and service 57be6bcada3b5ff0d64502d4 2016-09-04 22:30:30.011 - INFO: RoomResource - Preparing deleting room 57cc3004b35a3c4ec3a00f61 2016-09-04 22:30:30.017 - INFO: RoomResource - Room 57cc3004b35a3c4ec3a00f61 deleted for service 57be6bcada3b5ff0d64502d4 2016-09-04 22:30:31.679 - INFO: RPCPublic - Consumed token 57cc3004b35a3c4ec3a00f62 from room 57cc3004b35a3c4ec3a00f61 of service 57be6bcada3b5ff0d64502d4 /opt/Release-v3.1.1/nuve/node_modules/mongojs/node_modules/mongodb/lib/utils.js:98 process.nextTick(function() { throw err; }); ^ TypeError: Cannot read property 'mediaMixing' of null at /opt/Release-v3.1.1/nuve/rpc/rpcPublic.js:1:719 at /opt/Release-v3.1.1/nuve/mdb/roomRegistry.js:1:329 at /opt/Release-v3.1.1/nuve/node_modules/mongojs/lib/collection.js:50:5 at handleCallback (/opt/Release-v3.1.1/nuve/node_modules/mongojs/node_modules/mongodb/lib/utils.js:96:12) at /opt/Release-v3.1.1/nuve/node_modules/mongojs/node_modules/mongodb/lib/cursor.js:669:5 at handleCallback (/opt/Release-v3.1.1/nuve/node_modules/mongojs/node_modules/mongodb/node_modules/mongodb-core/lib/cursor.js:159:5) at setCursorNotified (/opt/Release-v3.1.1/nuve/node_modules/mongojs/node_modules/mongodb/node_modules/mongodb-core/lib/cursor.js:483:3) at /opt/Release-v3.1.1/nuve/node_modules/mongojs/node_modules/mongodb/node_modules/mongodb-core/lib/cursor.js:549:16 at queryCallback (/opt/Release-v3.1.1/nuve/node_modules/mongojs/node_modules/mongodb/node_modules/mongodb-core/lib/cursor.js:237:5) at Callbacks.emit (/opt/Release-v3.1.1/nuve/node_modules/mongojs/node_modules/mongodb/node_modules/mongodb-core/lib/topologies/server.js:116:3)
Look forward to replies.Thanks.
- Tags:
- HTML5
- JavaScript*
ConferenceClient void | join (string token, function onSuccess, function onFailure) |
If I got a valid token to join in an empty(deleted) room.It will cause this situation.
Thanks for reporting this, we will try to reproduce that.
Yes, this is the product defect for this corner case. Try the attached patch file to replace Release-v3.1.1/nuve/rpc/rpcPublic.js, it should fix your issue.
Thanks a lot.
