Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
1147 Discussions
NAT environment not working all the time
Naresh_R_1
Dear Team,
We have installed Intel MCUv5 CentOS 7.2 Software accelerated in a Natted Environment  in a single machine
Type of NAT: Static
No of Network Interfaces: 1
No of ports opened: TCP: 443 , 80, 3000-3004, 8080, 27017 , 5672,  UDP Range: 49152-65535
1. when we configure public IP under webrtc_agent.toml file stream from local network wont publish at all, but when we changed it to default[] it works from local network with out any issues
from the above scenario(1) from public network stream sometimes get publishes but most of time it wont publish, we also configure stun/turn servers also on public network directly with no restrictions
2. what ever the configuration we give in webrtc_agent/agent.toml server just takes and it is not working from public network
Please let us know the best configuration which works under NAT Environment
Naresh
Naresh_R_1
Hi Qiujiao,
That solution which you have provided is for MCU version 3.5, we are using 3.3 version since there are multiple issues with 3.5 like port release issues, ice issues and room gets fails when there is a traffic on single room.
Any solution for version 3.3?
Naresh
Qiujiao_W_Intel
For 3.3, currently no solution for this case. We will have a new release recently which will fix ice and room gets fail issue, for port issue, we are working on it.
Naresh_R_1
Hi Qiujiao,
Thanks for the update.
When can we expect new release with the issues fixed?
Naresh
Qiujiao_W_Intel
Hi, Naresh, version 3.5.2 has been released, please try this version. NAT issue has been fixed in this version, please check if it works well in your environment.
Naresh_R_1
Hi Qiujiao,
Thanks for the update. do we still have to launch multiple webrtc_agents for nat issue with this release.
Naresh
Naresh_R_1
Hi Qiujiao,
I have installed v 3.5.2 in Nat Environment as mentioned in this topic first post, with out launching multiple webrtc_agents.and pointing public IP under [webrtc] as below
network_interfaces = [{name = "ens160", replaced_ip_address = "203.196.151.152"}]  # default: []
It is working from internet users connecting through public IP. but from Lan we get error ice procedure failed
Naresh
Also as you mentioned below steps for Nat Issue
1. set ipsp to "internal" in Release-v3.5.1/webrtc-agent/agent.toml and other internal network settings and launch webrtc agent 1
2. copy webrtc-agent, bin, package.json in Release-3.5.1 to a new folder test, and then set ipsp to "external" in test/webrtc-agent/agent.toml  and other external network settings, then launch webrtc agent 2
3. user 1 in internal network call createToken with setting isp to "internal" in preference option and then join room
4. user 2 in external network call createToken with setting isp to "external" in preference option and then join room
Then internal and external network should work well, you can deploy 2 portal with the same isps setting as webrtc agent
Where do we set preference option what will be the configuration under portal and webrtc agents under ISP
Naresh
Qiujiao_W_Intel
For users, before they join room, they need to call createToken API to get token, please refer to this API js sdk document, you can specify internal isp for internal users when calling createToken, then internal users connection will be scheduled to internal isp portal and webrtc agent. For external users, please specify external isp info in createToken and their connection will be scheduled to external isp portal and webrtc agent
Naresh_R_1
Hi Qiujiao,
I can specify in webrtc_agent.toml file like the below? and ask client to to call this internal or external create token API?
[capacity]
#The ISP list this agent tends to handle
isps = ["internal"] #default: [], which means all ISPs.
#The region list this agent tends to handle
regions = [] #default: [], which means all regions.
Also do we have to launch multiple portals??
Naresh
Qiujiao_W_Intel
Yes, you need specify internal in both webrtc and portal toml files, so you need launch at least 2 webrtc agents, one for internal connection, one for external connection; 2 portal, one for internal, one for external. Then internal clients call createToken with internal isp option, and external clients call createToken with external isp option, then both external and internal clients can connect to MCU.
Naresh_R_1
Hi Qiujiao,
How can we launch 2 portals in a single machine? the solution seems to be only for cluster deployment.
For customers with minimum number of calls cluster deployment will not be ideal solution. we need mcu to be run in a single standalone server with all components together
Naresh
Qiujiao_W_Intel
You can copy portal folder and package.json file to a different folder in the same machine just like running 2 webrtc agents in one single standalone server
Naresh_R_1
Confused..... ;) i have to use separate hostname for both portals?
Cant Nat issue fixed with standalone service with out launching multiple agents
Naresh
Qiujiao_W_Intel
Naresh, this is a workaround tor current release if you want both internal and external clients connect to MCU in NAT, we will fix it with standalone service in the future release.
