Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
1151 Discussions
No support for: subscribe with audio/video only option
Owais_A_
Hello all!
I am curious that if during a multi-party video conference, one of the participant's network deteriorates and his video quality suffers.
Does Intel CS support:
  • Dynamic change in video fps and resolution?
  • Fall back to audio-only for the participant if his network is too bad for video upload/download?
Owais
Lei_Z_Intel1
1. As WebRTC client, it will auto adjust the sending video fps/resolution/bitrate according to the network bandwidth. For subscribed mix stream, the bitrate will do auto adjustment, and resolution need to be switched manually through MCU multi-streaming, but fps is fixed for each resolution now.
2. You can manually enable/disable local video stream and notify MCU to play/pause video stream to achieve audio only chat if you found network quality is bad through network stats API.
