Hi, I got Noise in one of my android device after subscribe remoteStream, even if I did pulish stream, and the other device in the some room is disable local audio.
Here is my log during subscribe remoteStream:
11-23 20:05:08.173 2049-2397/system_process I/DynamicPManagerService: Current Scense:normal
11-23 20:05:08.174 9933-17369/com.sona.appmeeting D/IntelWebRtc: My client Id: gX0Zph60WsKpd_ymAAHM
11-23 20:05:08.182 9933-17251/com.sona.appmeeting I/SoftAAC2: Reconfiguring decoder: 0->48000 Hz, 0->2 channels
11-23 20:05:08.190 9933-17369/com.sona.appmeeting D/IntelWebRtc: onStreamAdded: streamId = 5a169564d35f180030ef015b-common, from
11-23 20:05:08.191 9933-17369/com.sona.appmeeting D/IntelWebRtc: onStreamAdded: streamId = 440688006927572030, from BzcdojZYcsavnJRwAAG3
11-23 20:05:08.223 9933-17231/com.sona.appmeeting D/sona.IntelWebRtc.java: line:1028_handleMessage__flow remoteStream instanceof RemoteMixedStream
11-23 20:05:08.224 9933-17231/com.sona.appmeeting W/org.webrtc.Logging: WebRtcAudioTrack: setSpeakerMute(true)
11-23 20:05:08.226 9933-17369/com.sona.appmeeting D/WooGeen-SocketClient: reconnection ticket will be refreshed in 600s
11-23 20:05:08.227 9933-17231/com.sona.appmeeting D/WooGeen-ConferenceClient: Subscribe 5a169564d35f180030ef015b-common
11-23 20:05:08.284 1643-1676/? I/[Gralloc]: ion_alloc from ion_client:19 via heap type DMA(mask:16) for 92928 Bytes uncached buffer successfully, usage = 0x00000f02
11-23 20:05:08.287 1643-2043/? I/[Gralloc]: ion_alloc from ion_client:19 via heap type DMA(mask:16) for 92928 Bytes uncached buffer successfully, usage = 0x00000f02
11-23 20:05:08.288 1643-2043/? I/[Gralloc]: ion_alloc from ion_client:19 via heap type DMA(mask:16) for 92928 Bytes uncached buffer successfully, usage = 0x00000f02
11-23 20:05:08.349 9933-17037/com.sona.appmeeting D/WooGeen-PCFactory: Create PeerConnection.
11-23 20:05:08.411 9933-10286/com.sona.appmeeting V/RenderScript: 0xce582000 Launching thread(s), CPUs 4
11-23 20:05:08.527 9933-17396/com.sona.appmeeting D/WooGeen-PeerConnectionChannel: Create Offer
11-23 20:05:08.543 9933-17042/com.sona.appmeeting D/WooGeen-PeerConnectionChannel: SDPObserver ---- onCreateSuccess
11-23 20:05:08.551 9933-17042/com.sona.appmeeting D/WooGeen-PeerConnectionChannel: Found h264 rtpmap 125, prefer at m=video 9 UDP/TLS/RTP/SAVPF 96 98 100 127 125 124 97 99 101 104 106
11-23 20:05:08.551 9933-17042/com.sona.appmeeting D/WooGeen-PeerConnectionChannel: Change media description: m=video 9 UDP/TLS/RTP/SAVPF 125 96 98 100 127 124 97 99 101 104 106
11-23 20:05:08.604 9933-17042/com.sona.appmeeting D/WooGeen-PeerConnectionChannel: PC Observer ---- onSignalingChange: HAVE_LOCAL_OFFER
11-23 20:05:08.609 9933-17040/com.sona.appmeeting I/org.webrtc.Logging: NetworkMonitor: Start monitoring from native observer -461307200
11-23 20:05:08.641 2049-4437/system_process D/ConnectivityService: requestNetwork for Request from uid/pid:1000/9933 for NetworkRequest [ id=74, legacyType=5, [ Transports: CELLULAR Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN] ]
11-23 20:05:08.648 2049-3331/system_process D/WIFI: got request NetworkRequest [ id=74, legacyType=5, [ Transports: CELLULAR Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN] ] with score 0
11-23 20:05:08.649 2049-3331/system_process D/WIFI_UT: got request NetworkRequest [ id=74, legacyType=5, [ Transports: CELLULAR Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN] ] with score 0
11-23 20:05:08.649 2049-3610/system_process D/Ethernet: got request NetworkRequest [ id=74, legacyType=5, [ Transports: CELLULAR Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN] ] with score 0
11-23 20:05:08.665 2049-25202/system_process D/ConnectivityService: listenForNetwork for Listen from uid/pid:1000/9933 for NetworkRequest [ id=75, legacyType=-1, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN] ]
11-23 20:05:08.692 9933-17445/com.sona.appmeeting I/org.webrtc.Logging: NetworkMonitorAutoDetect: Network becomes available: 100
11-23 20:05:08.711 9933-17042/com.sona.appmeeting D/WooGeen-PeerConnectionChannel: SDPObserver ---- onSetSuccess
11-23 20:05:08.729 9933-17042/com.sona.appmeeting D/WooGeen-PeerConnectionChannel: PC Observer ---- onSignalingChange: STABLE
11-23 20:05:08.733 9933-17041/com.sona.appmeeting D/AudioTrackJni: InitPlayout@[tid=17041]
11-23 20:05:08.733 9933-17041/com.sona.appmeeting I/org.webrtc.Logging: WebRtcAudioTrack: initPlayout(sampleRate=44100, channels=1)
11-23 20:05:08.733 9933-17041/com.sona.appmeeting I/org.webrtc.Logging: WebRtcAudioTrack: byteBuffer.capacity: 882
11-23 20:05:08.733 9933-17041/com.sona.appmeeting D/AudioTrackJni: OnCacheDirectBufferAddress
11-23 20:05:08.734 9933-17041/com.sona.appmeeting D/AudioTrackJni: direct buffer capacity: 882
11-23 20:05:08.734 9933-17041/com.sona.appmeeting D/AudioTrackJni: frames_per_buffer: 441
11-23 20:05:08.735 9933-17041/com.sona.appmeeting I/org.webrtc.Logging: WebRtcAudioTrack: AudioTrack.getMinBufferSize: 6156
11-23 20:05:08.745 9933-17041/com.sona.appmeeting I/org.webrtc.Logging: WebRtcAudioTrack: AudioTrack: session ID: 10, channels: 1, sample rate: 44100, max gain: 1.0
11-23 20:05:08.745 9933-17041/com.sona.appmeeting I/org.webrtc.Logging: WebRtcAudioTrack: AudioTrack: buffer size in frames: 3078
11-23 20:05:08.745 9933-17041/com.sona.appmeeting D/AudioManager: IsCommunicationModeEnabled()
11-23 20:05:08.746 9933-17041/com.sona.appmeeting D/AudioTrackJni: StartPlayout@[tid=17041]
11-23 20:05:08.746 9933-17041/com.sona.appmeeting I/org.webrtc.Logging: WebRtcAudioTrack: startPlayout
11-23 20:05:08.748 9933-17463/com.sona.appmeeting I/org.webrtc.Logging: WebRtcAudioTrack: AudioTrackThread@[name=AudioTrackJavaThread, id=1406]
11-23 20:05:08.763 9933-17042/com.sona.appmeeting D/WooGeen-PeerConnectionChannel: onIceConnectionChange:CHECKING
11-23 20:05:08.770 2049-2049/system_process D/BackgroundManagerService: reload bgmusic list: [com.sona.appmeeting]
11-23 20:05:08.771 9933-17042/com.sona.appmeeting D/WooGeen-PeerConnectionChannel: onAddTrack
11-23 20:05:08.772 9933-17042/com.sona.appmeeting D/WooGeen-PeerConnectionChannel: PC Observer ---- onAddStream
11-23 20:05:08.772 9933-17042/com.sona.appmeeting D/WooGeen-ConferencePeerConnectionChannel: audio1 video1
11-23 20:05:08.773 9933-17042/com.sona.appmeeting D/WooGeen-PeerConnectionChannel: onIceGatheringChange:GATHERING
11-23 20:05:08.776 9933-17042/com.sona.appmeeting D/WooGeen-PeerConnectionChannel: onIceCandidate
11-23 20:05:08.777 9933-17042/com.sona.appmeeting D/WooGeen-PeerConnectionChannel: SDPObserver ---- onSetSuccess
11-23 20:05:08.783 10090-10344/? V/audio_hw_primary: out_set_parameters: routing=2
11-23 20:05:08.783 10090-10344/? V/audio_hw_primary: out_set_parameters, line: 1568
11-23 20:05:08.783 10090-10344/? V/audio_hw_primary: >>>>>>>> adev->mode:3,adev->out_device is: 2, val is : 2
11-23 20:05:08.785 9933-17042/com.sona.appmeeting D/WooGeen-PeerConnectionChannel: onIceGatheringChange:COMPLETE
11-23 20:05:08.795 10090-10344/? V/audio_hw_primary: start_output_stream, line: 1230
11-23 20:05:08.796 10090-10344/? D/audio_hw_primary: >>>>>> select_device
11-23 20:05:08.796 10090-10344/? V/audio_hw_primary: active_output, ****LINE:1050,FUNC:select_device, adev->out_device:2
11-23 20:05:08.796 10090-10344/? V/audio_hw_primary: ****LINE:1056,FUNC:select_device, headset_on:0, headphone_on:0, speaker_on:2, earpiece_on:0, bt_on:0
11-23 20:05:08.796 10090-10344/? V/audio_hw_primary: ****LINE:1083,FUNC:select_device, output_device_id:6
11-23 20:05:08.796 10090-10344/? V/audio_hw_primary: select_device, line: 1104
11-23 20:05:08.796 10090-10344/? V/audio_hw_primary: start_output_stream: card:0, port:0, rate:44100, period_count:3, period_size:1024
11-23 20:05:08.797 10090-10344/? V/audio_hw_primary: do not use out resampler
11-23 20:05:08.868 9933-17042/com.sona.appmeeting D/WooGeen-PeerConnectionChannel: onIceConnectionChange:CONNECTED
11-23 20:05:08.868 9933-17042/com.sona.appmeeting D/WooGeen-ConferencePeerConnectionChannel: Change State=CONNECTED
//end of log
Thanks!
- Tags:
- HTML5
- JavaScript*
Could you please provide the problem detail android phone devices information and detail reproduce steps ?
Greetings Yanbin Z,
I use two android device, device A is my custom device with the sound card info below:
root@tulip-d1:/ # cat /proc/asound/pcm
00-00: SUNXI-CODEC codec-aif1-0 : : playback 1 : capture 1
00-01: bb Voice codec-aif2-1 : : playback 1 : capture 1
00-02: bb-bt-clk codec-aif2-2 : : playback 1 : capture 1
00-03: bt Voice codec-aif3-3 : : playback 1 : capture 1
And device B is a mobile phone make by Huawei.
In my test, two device joined in the same room. Device A just subsribe remote stream, and didnot publish stream.And device B publish local stream, device A got Noise all the time even if device B is disable local audio.
By the way, I have played music or other voice call on device A, it didn't show noise.
Thank you!
In the v 3.5 SDK, I can't get raw audio data (uncompressed PCM audio data) of a remote media stream, if I can do that, I will save the audio data for some more detail analyze to check whether is the data is error or my media decoder is error.
Hi,how's the progress?
Thanks!
Hi Lee
Did device A subscribe a RemoteMixedStream or a RemoteCameraStream published by device B?
How did you disable device B local audio? And were there any other streams published in the same room?
Hank Zhang (Intel) wrote:
Hi Lee
Hi Hank Zhang
Device A just subscribe a RemoteMixedStream. I used the api "LocalCameraStream.disableAudio()" on device B. And there are just two device in the meeting.
