Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
Not able to publish video
Naresh_R_1
Hi Chunbo,
We are facing new issue from one of the network provider, when we are trying to establish connection from that network we are not able to publish video regardless of firewall, with out firewall and from open network.
MCU is on direct static ip with out Firewall
Mode: Hybrid Conference Mode
Here is an extract of the server side log:
2016-05-12 09:18:58,418  - DEBUG: WebRtcConnection - Setting VIDEO CANDIDATE
PROCESS CAND { type: 'candidate',
  candidate:
   { sdpMLineIndex: 0,
     sdpMid: 'audio',
     candidate: 'a=candidate:3078610798 1 udp 1686052607 124.123.184.30 51949 typ srflx raddr 192.168.1.6 rport 51949 generation 0 ufrag QFp1ZRpCo6o5F0Mm' } }
2016-05-12 09:18:58,419  - DEBUG: WebRtcConnection - Adding remote Candidate a=candidate:3078610798 1 udp 1686052607 124.123.184.30 51949 typ srflx raddr 192.168.1.6 rport 51949 generation 0 ufrag QFp1ZRpCo6o5F0Mm, mid audio, sdpMLine 0
2016-05-12 09:18:58,419  - DEBUG: WebRtcConnection - Setting VIDEO CANDIDATE
2016-05-12 09:18:59,203  - INFO: NiceConnection - video - NICE State Changing from 1 to 2 0x31490e0
2016-05-12 09:19:01.347  - DEBUG: ErizoJS - KeepAlive from ErizoController
2016-05-12 09:19:06.349  - DEBUG: ErizoJS - KeepAlive from ErizoController
2016-05-12 09:19:11.350  - DEBUG: ErizoJS - KeepAlive from ErizoController
After the nice state change, transport is not getting update.
And these logs are from the C++ execuable of webrtc_mcu, so we are not able to debug it.
Outcome of our debugging on the client side:
1. After the ice candidate gethering, the iceconnection state change is not happening.
2. Add stream function is not properly getting executed and the create offer function is failing, this is what leading to the failure in ice connection state change.
PS: client side log is attached
Please advise on this.
We are facing this issue with only one particular internet service provider.
Thanks & Regrads,
Naresh P
Chunbo_H_Intel1
Hi Naresh,
Could you give us more information about this "network provider"? And where is the client log?
Thanks!
Naresh_R_1
Hi Chunbo,
Attached is Browser and webrtc internals logs
Naresh
Chunbo_H_Intel1
Thanks!
Naresh_R_1
Hi Lei,
We based on India, we are now facing the above said issue with multiple ISP providers, we have checked with servers hosting is different locations but the issue still exists
If you can check the logs attached above and  find any issues.
Also we can provide the access of the client machine if you can check with the issue
Naresh
Naresh_R_1
Hi Lei,
But remaining solutions like Licode, Intel P2P is working fine with the same network
Naresh
Lei_Z_Intel1
Which Intel CS for WebRTC version are you using?
Naresh_R_1
Hi Lei,
We have used all the Intel CS WebRTC versions v3.1 , v3.1.1 , v3.2. MCU is deployed on on direct Public IP and also we used Coturn as a Turn Server and all the ports are opened on both MCU and Turn server
Naresh
Lei_Z_Intel1
So can you please share the error log on the latest v3.2 version?
