Some times I see some infinite logs going on after a webrtc session is ended.
The logs are attached at the end.
If this infinite logging is happening. The next time webrtc connects, the webrtc will crash internally. It throws a Fatal signal 11 SIGSEGV.
Do you guys happen to know what needs to be done to release and clean things up properly?
If a filter for my own app is applied. I see these two logs getting logged repeatedly.
- 01-23 18:08:28.193 10842-11284/com.webrtc.demo.app W/ResourceType: No known package when getting name for resource number 0xffffffff
- 01-23 18:08:28.193 10842-11284/com.webrtc.demo.app I/org.webrtc.Logging: SurfaceViewRenderer: Dropping frame - Not initialized or already released.
At this point, the camera in other apps will not work properly. Audio stuff works, however.
- 01-23 18:08:28.133 272-12665/? D/QCameraParameters: int qcamera::QCameraParameters::getAETarget(void*, int*, int*) const lumaLowTarget=60, lumaHighTarget=60
- 01-23 18:08:28.133 272-12665/? D/QCameraParameters: int qcamera::QCameraParameters::getAEStatus(void*, int*, int*) const aecStabe=0, currentY=66
- 01-23 18:08:28.143 272-12665/? D/QCameraParameters: int qcamera::QCameraParameters::getAwbGain(void*, int*) const awbgain r_gain = 1, b_gain = 2
- 01-23 18:08:28.143 272-12665/? D/QCameraParameters: int qcamera::QCameraParameters::getRealGain(const void*, float*) const real_gain = 11.782760
- 01-23 18:08:28.143 272-12665/? D/QCameraParameters: int32_t qcamera::QCameraParameters::getBrightness(const void*, int*) const: new brightness value : 3
- 01-23 18:08:28.143 272-12665/? D/QCameraParameters: int qcamera::QCameraParameters::getFlashStatus(const void*, int*) const *flashStatus = 0
- 01-23 18:08:28.143 272-12665/? D/QCameraParameters: int qcamera::QCameraParameters::getActualExposure(const void*, int*) const exp = 19
- 01-23 18:08:28.143 272-12665/? D/QCameraParameters: int qcamera::QCameraParameters::getFocusAreas(int*, int*, int*, int*) x=0, y=0, w=0, h=0
- 01-23 18:08:28.143 301-12659/? E/AEC_PORT: aec_port_send_exif_info_update: exp_index:341, line_count:1989, real_gain:11.782760, target_luma:60, cur_luma:62, settled:1
- 01-23 18:08:28.143 301-12659/? E/AEC_PORT: aec_port_save_update:real_gain:11.782760 linecnt:1989 exp_idx:341 cur_luma:62 led_est:0
- 01-23 18:08:28.143 272-12665/? D/QCameraParameters: int qcamera::QCameraParameters::setAETarget(void*, int, int) aeBrightnessLow = 3.000000, aeBrightnessHigh = 3.000000
- 01-23 18:08:28.143 272-12665/? V/QCameraParameters: int qcamera::QCameraParameters::setAETarget(void*, int, int): No brightness value changed.
- 01-23 18:08:28.143 272-12665/? I/IppAlgoSmartAE: doSmartAEAlgo() exit
- 01-23 18:08:28.143 272-12665/? D/mm-camera-intf: mm_stream_qbuf: VIDIOC_QBUF buf_index 1,stream type 1,frame_idx 4941,queued cnt 5
- 01-23 18:08:28.153 10842-11284/com.webrtc.demo.app W/ResourceType: No known package when getting name for resource number 0xffffffff
- 01-23 18:08:28.153 10842-11284/com.webrtc.demo.app I/org.webrtc.Logging: SurfaceViewRenderer: Dropping frame - Not initialized or already released.
- 01-23 18:08:28.153 301-12670/? E/AEC_PORT: aec_port_send_exif_info_update: exp_index:341, line_count:1989, real_gain:11.782760, target_luma:60, cur_luma:62, settled:1
- 01-23 18:08:28.153 301-12659/? E/mm-camera-sensor: port_sensor_handle_aec_update:993 g 11.782760 lux idx 337.775574
- 01-23 18:08:28.163 272-12657/? D/mm-camera-intf: mm_stream_read_msm_frame: VIDIOC_DQBUF buf_index 5, frame_idx 4942, stream type 7, queued cnt 7
- 01-23 18:08:28.163 272-12664/? V/QCamera2HWI: static void qcamera::QCamera2HardwareInterface::metadata_stream_cb_routine(mm_camera_super_buf_t*, qcamera::QCameraStream*, void*): iso_value:1100, exp_time:0.050039, mean_y:66
- 01-23 18:08:28.163 272-12664/? V/QCamera2HWI: static void qcamera::QCamera2HardwareInterface::metadata_stream_cb_routine(mm_camera_super_buf_t*, qcamera::QCameraStream*, void*) pMetaData->ae_params.settled = 1
- 01-23 18:08:28.163 272-12664/? D/mm-camera-intf: mm_stream_qbuf: VIDIOC_QBUF buf_index 5,stream type 7,frame_idx 4942,queued cnt 8
- 01-23 18:08:28.163 301-12670/? E/mm-camera: invalid stats mask. Return back
- 01-23 18:08:28.183 301-12645/? D/mm-camera: cpp_hardware_process_frame:1035] stream_status:0xb8e5c41c, iden:0x20002, cur_frame_id:4943
- 01-23 18:08:28.183 272-12657/? D/mm-camera-intf: mm_stream_read_msm_frame: VIDIOC_DQBUF buf_index 0, frame_idx 4943, stream type 1, queued cnt 4
- 01-23 18:08:28.183 272-12665/? V/QCamera2HWI: static void qcamera::QCamera2HardwareInterface::preview_stream_cb_routine(mm_camera_super_buf_t*, qcamera::QCameraStream*, void*) scanline:480, stride:640, frame_len:462848, rawSize:460800
- 01-23 18:08:28.183 272-12665/? D/QCamera2HWI: isTargetTrackingOn = 0
- 01-23 18:08:28.183 272-12665/? V/QCamera2HWI: static void qcamera::QCamera2HardwareInterface::preview_stream_cb_routine(mm_camera_super_buf_t*, qcamera::QCameraStream*, void*): mAutoSceneDetect not run!!!
- 01-23 18:08:28.183 272-12665/? V/QCamera2HWI: static void qcamera::QCamera2HardwareInterface::preview_stream_cb_routine(mm_camera_super_buf_t*, qcamera::QCameraStream*, void*), smartae_enable:true, scene_mode:auto, panorama:(null)
- 01-23 18:08:28.193 301-12659/? E/AEC_PORT: aec_port_send_exif_info_update: exp_index:341, line_count:1989, real_gain:11.782760, target_luma:60, cur_luma:59, settled:1
- 01-23 18:08:28.193 301-12659/? E/AEC_PORT: aec_port_save_update:real_gain:11.782760 linecnt:1989 exp_idx:341 cur_luma:59 led_est:0
- 01-23 18:08:28.193 272-12665/? D/mm-camera-intf: mm_stream_qbuf: VIDIOC_QBUF buf_index 5,stream type 1,frame_idx 4942,queued cnt 5
- 01-23 18:08:28.203 301-12670/? E/AEC_PORT: aec_port_send_exif_info_update: exp_index:341, line_count:1989, real_gain:11.782760, target_luma:60, cur_luma:59, settled:1
- 01-23 18:08:28.213 301-12659/? E/mm-camera-sensor: port_sensor_handle_aec_update:993 g 11.782760 lux idx 338.816620
- 01-23 18:08:28.213 272-12657/? D/mm-camera-intf: mm_stream_read_msm_frame: VIDIOC_DQBUF buf_index 6, frame_idx 4943, stream type 7, queued cnt 7
- 01-23 18:08:28.213 272-12664/? E/QCameraParameters: bool qcamera::QCameraParameters::needProcessHDRData() const KEY_SCENE_MODE:auto
- 01-23 18:08:28.213 272-12664/? V/QCamera2HWI: static void qcamera::QCamera2HardwareInterface::metadata_stream_cb_routine(mm_camera_super_buf_t*, qcamera::QCameraStream*, void*): iso_value:1100, exp_time:0.050039, mean_y:64
- 01-23 18:08:28.213 272-12664/? V/QCamera2HWI: static void qcamera::QCamera2HardwareInterface::metadata_stream_cb_routine(mm_camera_super_buf_t*, qcamera::QCameraStream*, void*) pMetaData->ae_params.settled = 1
- 01-23 18:08:28.213 272-12664/? D/mm-camera-intf: mm_stream_qbuf: VIDIOC_QBUF buf_index 6,stream type 7,frame_idx 4943,queued cnt 8
- 01-23 18:08:28.213 301-12670/? E/mm-camera: invalid stats mask. Return back
- 01-23 18:08:28.233 301-12645/? D/mm-camera: cpp_hardware_process_frame:1035] stream_status:0xb8e5c41c, iden:0x20002, cur_frame_id:4944
- 01-23 18:08:28.233 301-12659/? E/AEC_PORT: aec_port_send_exif_info_update: exp_index:341, line_count:1989, real_gain:11.782760, target_luma:60, cur_luma:58, settled:1
- 01-23 18:08:28.233 301-12659/? E/AEC_PORT: aec_port_save_update:real_gain:11.782760 linecnt:1989 exp_idx:341 cur_luma:58 led_est:0
- 01-23 18:08:28.243 272-12657/? D/mm-camera-intf: mm_stream_read_msm_frame: VIDIOC_DQBUF buf_index 1, frame_idx 4944, stream type 1, queued cnt 4
- 01-23 18:08:28.243 272-12665/? V/QCamera2HWI: static void qcamera::QCamera2HardwareInterface::preview_stream_cb_routine(mm_camera_super_buf_t*, qcamera::QCameraStream*, void*) scanline:480, stride:640, frame_len:462848, rawSize:460800
- 01-23 18:08:28.243 272-12665/? D/QCamera2HWI: isTargetTrackingOn = 0
- 01-23 18:08:28.243 272-12665/? V/QCamera2HWI: static void qcamera::QCamera2HardwareInterface::preview_stream_cb_routine(mm_camera_super_buf_t*, qcamera::QCameraStream*, void*): mAutoSceneDetect not run!!!
- 01-23 18:08:28.243 272-12665/? V/QCamera2HWI: static void qcamera::QCamera2HardwareInterface::preview_stream_cb_routine(mm_camera_super_buf_t*, qcamera::QCameraStream*, void*), smartae_enable:true, scene_mode:auto, panorama:(null)
- 01-23 18:08:28.243 272-12665/? D/mm-camera-intf: mm_stream_qbuf: VIDIOC_QBUF buf_index 0,stream type 1,frame_idx 4943,queued cnt 5
- 01-23 18:08:28.243 10842-11284/com.webrtc.demo.app W/ResourceType: No known package when getting name for resource number 0xffffffff
- 01-23 18:08:28.243 10842-11284/com.webrtc.demo.app I/org.webrtc.Logging: SurfaceViewRenderer: Dropping frame - Not initialized or already released.
- 01-23 18:08:28.253 301-12670/? E/AEC_PORT: aec_port_send_exif_info_update: exp_index:341, line_count:1989, real_gain:11.782760, target_luma:60, cur_luma:58, settled:1
- 01-23 18:08:28.253 301-12659/? E/mm-camera-sensor: port_sensor_handle_aec_update:993 g 11.782760 lux idx 339.349396
- 01-23 18:08:28.263 272-12657/? D/mm-camera-intf: mm_stream_read_msm_frame: VIDIOC_DQBUF buf_index 7, frame_idx 4944, stream type 7, queued cnt 7
- 01-23 18:08:28.263 272-12664/? V/QCamera2HWI: static void qcamera::QCamera2HardwareInterface::metadata_stream_cb_routine(mm_camera_super_buf_t*, qcamera::QCameraStream*, void*): iso_value:1100, exp_time:0.050039, mean_y:63
- 01-23 18:08:28.263 272-12664/? V/QCamera2HWI: static void qcamera::QCamera2HardwareInterface::metadata_stream_cb_routine(mm_camera_super_buf_t*, qcamera::QCameraStream*, void*) pMetaData->ae_params.settled = 1
- 01-23 18:08:28.263 272-12664/? D/mm-camera-intf: mm_stream_qbuf: VIDIOC_QBUF buf_index 7,stream type 7,frame_idx 4944,queued cnt 8
- 01-23 18:08:28.263 301-12670/? E/mm-camera: invalid stats mask. Return back
- 01-23 18:08:28.283 301-12645/? D/mm-camera: cpp_hardware_process_frame:1035] stream_status:0xb8e5c41c, iden:0x20002, cur_frame_id:4945
- 01-23 18:08:28.283 301-12659/? E/AEC_PORT: aec_port_send_exif_info_update: exp_index:341, line_count:1989, real_gain:11.782760, target_luma:60, cur_luma:58, settled:1
- 01-23 18:08:28.283 301-12659/? E/AEC_PORT: aec_port_save_update:real_gain:11.782760 linecnt:1989 exp_idx:341 cur_luma:58 led_est:0
- 01-23 18:08:28.283 272-12657/? D/mm-camera-intf: mm_stream_read_msm_frame: VIDIOC_DQBUF buf_index 5, frame_idx 4945, stream type 1, queued cnt 4
- 01-23 18:08:28.283 272-12665/? V/QCamera2HWI: static void qcamera::QCamera2HardwareInterface::preview_stream_cb_routine(mm_camera_super_buf_t*, qcamera::QCameraStream*, void*) scanline:480, stride:640, frame_len:462848, rawSize:460800
- 01-23 18:08:28.283 272-12665/? D/QCamera2HWI: isTargetTrackingOn = 0
- 01-23 18:08:28.283 272-12665/? V/QCamera2HWI: static void qcamera::QCamera2HardwareInterface::preview_stream_cb_routine(mm_camera_super_buf_t*, qcamera::QCameraStream*, void*): mAutoSceneDetect not run!!!
- 01-23 18:08:28.293 272-12665/? V/QCamera2HWI: static void qcamera::QCamera2HardwareInterface::preview_stream_cb_routine(mm_camera_super_buf_t*, qcamera::QCameraStream*, void*), smartae_enable:true, scene_mode:auto, panorama:(null)
- 01-23 18:08:28.293 272-12665/? D/mm-camera-intf: mm_stream_qbuf: VIDIOC_QBUF buf_index 1,stream type 1,frame_idx 4944,queued cnt 5
- 01-23 18:08:28.293 10842-11284/com.webrtc.demo.app W/ResourceType: No known package when getting name for resource number 0xffffffff
- 01-23 18:08:28.293 10842-11284/com.webrtc.demo.app I/org.webrtc.Logging: SurfaceViewRenderer: Dropping frame - Not initialized or already released.
- 01-23 18:08:28.303 301-12670/? E/AEC_PORT: aec_port_send_exif_info_update: exp_index:341, line_count:1989, real_gain:11.782760, target_luma:60, cur_luma:58, settled:1
- 01-23 18:08:28.313 272-12657/? D/mm-camera-intf: mm_stream_read_msm_frame: VIDIOC_DQBUF buf_index 0, frame_idx 4945, stream type 7, queued cnt 7
- 01-23 18:08:28.313 272-12664/? E/QCameraParameters: bool qcamera::QCameraParameters::needProcessHDRData() const KEY_SCENE_MODE:auto
- 01-23 18:08:28.313 272-12664/? V/QCamera2HWI: static void qcamera::QCamera2HardwareInterface::metadata_stream_cb_routine(mm_camera_super_buf_t*, qcamera::QCameraStream*, void*): iso_value:1100, exp_time:0.050039, mean_y:63
- 01-23 18:08:28.313 272-12664/? V/QCamera2HWI: static void qcamera::QCamera2HardwareInterface::metadata_stream_cb_routine(mm_camera_super_buf_t*, qcamera::QCameraStream*, void*) pMetaData->ae_params.settled = 1
- 01-23 18:08:28.313 272-12664/? D/mm-camera-intf: mm_stream_qbuf: VIDIOC_QBUF buf_index 0,stream type 7,frame_idx 4945,queued cnt 8
- 01-23 18:08:28.313 301-12670/? E/mm-camera: invalid stats mask. Return back
- 01-23 18:08:28.333 301-12645/? D/mm-camera: cpp_hardware_process_frame:1035] stream_status:0xb8e5c41c, iden:0x20002, cur_frame_id:4946
- 01-23 18:08:28.333 301-12659/? E/AEC_PORT: aec_port_send_exif_info_update: exp_index:342, line_count:1989, real_gain:12.135149, target_luma:60, cur_luma:55, settled:0
- 01-23 18:08:28.333 301-12659/? E/AEC_PORT: aec_port_save_update:real_gain:12.135149 linecnt:1989 exp_idx:342 cur_luma:55 led_est:0
- 01-23 18:08:28.333 272-12657/? D/mm-camera-intf: mm_stream_read_msm_frame: VIDIOC_DQBUF buf_index 0, frame_idx 4946, stream type 1, queued cnt 4
- 01-23 18:08:28.333 272-12665/? V/QCamera2HWI: static void qcamera::QCamera2HardwareInterface::preview_stream_cb_routine(mm_camera_super_buf_t*, qcamera::QCameraStream*, void*) scanline:480, stride:640, frame_len:462848, rawSize:460800
- 01-23 18:08:28.333 272-12665/? D/QCamera2HWI: isTargetTrackingOn = 0
- 01-23 18:08:28.333 272-12665/? V/QCamera2HWI: static void qcamera::QCamera2HardwareInterface::preview_stream_cb_routine(mm_camera_super_buf_t*, qcamera::QCameraStream*, void*): mAutoSceneDetect not run!!!
- 01-23 18:08:28.333 272-12665/? V/QCamera2HWI: static void qcamera::QCamera2HardwareInterface::preview_stream_cb_routine(mm_camera_super_buf_t*, qcamera::QCameraStream*, void*), smartae_enable:true, scene_mode:auto, panorama:(null)
- 01-23 18:08:28.333 272-12665/? I/IppAlgoSmartAE: doSmartAEAlgo() enter
- 01-23 18:08:28.333 272-12665/? D/QCameraParameters: int qcamera::QCameraParameters::getAETarget(void*, int*, int*) const lumaLowTarget=60, lumaHighTarget=60
- 01-23 18:08:28.333 272-12665/? D/QCameraParameters: int qcamera::QCameraParameters::getAEStatus(void*, int*, int*) const aecStabe=1, currentY=58
- 01-23 18:08:28.343 272-12665/? D/QCameraParameters: int qcamera::QCameraParameters::getAwbGain(void*, int*) const awbgain r_gain = 1, b_gain = 2
- 01-23 18:08:28.343 272-12665/? D/QCameraParameters: int qcamera::QCameraParameters::getRealGain(const void*, float*) const real_gain = 11.782760
- 01-23 18:08:28.343 272-12665/? D/QCameraParameters: int32_t qcamera::QCameraParameters::getBrightness(const void*, int*) const: new brightness value : 3
- 01-23 18:08:28.343 272-12665/? D/QCameraParameters: int qcamera::QCameraParameters::getFlashStatus(const void*, int*) const *flashStatus = 0
- 01-23 18:08:28.343 272-12665/? D/QCameraParameters: int qcamera::QCameraParameters::getActualExposure(const void*, int*) const exp = 19
- 01-23 18:08:28.343 272-12665/? D/QCameraParameters: int qcamera::QCameraParameters::getFocusAreas(int*, int*, int*, int*) x=0, y=0, w=0, h=0
- 01-23 18:08:28.343 272-12665/? D/QCameraParameters: int qcamera::QCameraParameters::setAETarget(void*, int, int) aeBrightnessLow = 3.000000, aeBrightnessHigh = 3.000000
- 01-23 18:08:28.343 272-12665/? V/QCameraParameters: int qcamera::QCameraParameters::setAETarget(void*, int, int): No brightness value changed.
- 01-23 18:08:28.343 272-12665/? I/IppAlgoSmartAE: doSmartAEAlgo() exit
- 01-23 18:08:28.343 272-12665/? D/mm-camera-intf: mm_stream_qbuf: VIDIOC_QBUF buf_index 5,stream type 1,frame_idx 4945,queued cnt 5
- 01-23 18:08:28.353 10842-11284/com.webrtc.demo.app W/ResourceType: No known package when getting name for resource number 0xffffffff
- 01-23 18:08:28.353 10842-11284/com.webrtc.demo.app I/org.webrtc.Logging: SurfaceViewRenderer: Dropping frame - Not initialized or already released.
- 01-23 18:08:28.363 301-12670/? E/AEC_PORT: aec_port_send_exif_info_update: exp_index:342, line_count:1989, real_gain:12.135149, target_luma:60, cur_luma:55, settled:0
- 01-23 18:08:28.363 272-12657/? D/mm-camera-intf: mm_stream_read_msm_frame: VIDIOC_DQBUF buf_index 1, frame_idx 4946, stream type 7, queued cnt 7
- 01-23 18:08:28.363 272-12664/? V/QCamera2HWI: static void qcamera::QCamera2HardwareInterface::metadata_stream_cb_routine(mm_camera_super_buf_t*, qcamera::QCameraStream*, void*): iso_value:1200, exp_time:0.050039, mean_y:55
- 01-23 18:08:28.363 301-12659/? E/mm-camera-sensor: port_sensor_handle_aec_update:993 g 12.135149 lux idx 340.440796
- 01-23 18:08:28.363 272-12664/? V/QCamera2HWI: static void qcamera::QCamera2HardwareInterface::metadata_stream_cb_routine(mm_camera_super_buf_t*, qcamera::QCameraStream*, void*) pMetaData->ae_params.settled = 0
- 01-23 18:08:28.363 272-12664/? D/mm-camera-intf: mm_stream_qbuf: VIDIOC_QBUF buf_index 1,stream type 7,frame_idx 4946,queued cnt 8
- 01-23 18:08:28.363 301-12670/? E/mm-camera: invalid stats mask. Return back
- 01-23 18:08:28.383 301-12645/? D/mm-camera: cpp_hardware_process_frame:1035] stream_status:0xb8e5c41c, iden:0x20002, cur_frame_id:4947
- 01-23 18:08:28.383 301-12659/? E/AEC_PORT: aec_port_send_exif_info_update: exp_index:342, line_count:1989, real_gain:12.135149, target_luma:60, cur_luma:54, settled:0
- 01-23 18:08:28.383 301-12659/? E/AEC_PORT: aec_port_save_update:real_gain:12.135149 linecnt:1989 exp_idx:342 cur_luma:54 led_est:0
- 01-23 18:08:28.383 272-12657/? D/mm-camera-intf: mm_stream_read_msm_frame: VIDIOC_DQBUF buf_index 1, frame_idx 4947, stream type 1, queued cnt 4
- 01-23 18:08:28.383 272-12665/? V/QCamera2HWI: static void qcamera::QCamera2HardwareInterface::preview_stream_cb_routine(mm_camera_super_buf_t*, qcamera::QCameraStream*, void*) scanline:480, stride:640, frame_len:462848, rawSize:460800
- 01-23 18:08:28.383 272-12665/? D/QCamera2HWI: isTargetTrackingOn = 0
- 01-23 18:08:28.383 272-12665/? V/QCamera2HWI: static void qcamera::QCamera2HardwareInterface::preview_stream_cb_routine(mm_camera_super_buf_t*, qcamera::QCameraStream*, void*): mAutoSceneDetect not run!!!
- 01-23 18:08:28.383 272-12665/? V/QCamera2HWI: static void qcamera::QCamera2HardwareInterface::preview_stream_cb_routine(mm_camera_super_buf_t*, qcamera::QCameraStream*, void*), smartae_enable:true, scene_mode:auto, panorama:(null)
- 01-23 18:08:28.383 272-12665/? D/mm-camera-intf: mm_stream_qbuf: VIDIOC_QBUF buf_index 0,stream type 1,frame_idx 4946,queued cnt 5
- 01-23 18:08:28.393 10842-11284/com.webrtc.demo.app W/ResourceType: No known package when getting name for resource number 0xffffffff
- 01-23 18:08:28.393 10842-11284/com.webrtc.demo.app I/org.webrtc.Logging: SurfaceViewRenderer: Dropping frame - Not initialized or already released.
- 01-23 18:08:28.413 301-12670/? E/AEC_PORT: aec_port_send_exif_info_update: exp_index:342, line_count:1989, real_gain:12.135149, target_luma:60, cur_luma:54, settled:0
- 01-23 18:08:28.413 301-12659/? E/mm-camera-sensor: port_sensor_handle_aec_update:993 g 12.135149 lux idx 341.000000
- 01-23 18:08:28.413 272-12657/? D/mm-camera-intf: mm_stream_read_msm_frame: VIDIOC_DQBUF buf_index 2, frame_idx 4947, stream type 7, queued cnt 7
- 01-23 18:08:28.413 272-12664/? E/QCameraParameters: bool qcamera::QCameraParameters::needProcessHDRData() const KEY_SCENE_MODE:auto
- 01-23 18:08:28.413 272-12664/? V/QCamera2HWI: static void qcamera::QCamera2HardwareInterface::metadata_stream_cb_routine(mm_camera_super_buf_t*, qcamera::QCameraStream*, void*): iso_value:1200, exp_time:0.050039, mean_y:54
- 01-23 18:08:28.413 272-12664/? V/QCamera2HWI: static void qcamera::QCamera2HardwareInterface::metadata_stream_cb_routine(mm_camera_super_buf_t*, qcamera::QCameraStream*, void*) pMetaData->ae_params.settled = 0
- 01-23 18:08:28.413 272-12664/? D/mm-camera-intf: mm_stream_qbuf: VIDIOC_QBUF buf_index 2,stream type 7,frame_idx 4947,queued cnt 8
- 01-23 18:08:28.413 301-12670/? E/mm-camera: invalid stats mask. Return back
- 01-23 18:08:28.433 301-12645/? D/mm-camera: cpp_hardware_process_frame:1035] stream_status:0xb8e5c41c, iden:0x20002, cur_frame_id:4948
- 01-23 18:08:28.433 301-12659/? E/AEC_PORT: aec_port_send_exif_info_update: exp_index:342, line_count:1989, real_gain:12.135149, target_luma:60, cur_luma:56, settled:0
- 01-23 18:08:28.433 301-12659/? E/AEC_PORT: aec_port_save_update:real_gain:12.135149 linecnt:1989 exp_idx:342 cur_luma:56 led_est:0
- 01-23 18:08:28.433 272-12657/? D/mm-camera-intf: mm_stream_read_msm_frame: VIDIOC_DQBUF buf_index 5, frame_idx 4948, stream type 1, queued cnt 4
- 01-23 18:08:28.433 272-12665/? V/QCamera2HWI: static void qcamera::QCamera2HardwareInterface::preview_stream_cb_routine(mm_camera_super_buf_t*, qcamera::QCameraStream*, void*) scanline:480, stride:640, frame_len:462848, rawSize:460800
- 01-23 18:08:28.433 272-12665/? D/QCamera2HWI: isTargetTrackingOn = 0
- 01-23 18:08:28.433 272-12665/? V/QCamera2HWI: static void qcamera::QCamera2HardwareInterface::preview_stream_cb_routine(mm_camera_super_buf_t*, qcamera::QCameraStream*, void*): mAutoSceneDetect not run!!!
- 01-23 18:08:28.433 272-12665/? V/QCamera2HWI: static void qcamera::QCamera2HardwareInterface::preview_stream_cb_routine(mm_camera_super_buf_t*, qcamera::QCameraStream*, void*), smartae_enable:true, scene_mode:auto, panorama:(null)
- 01-23 18:08:28.443 272-12665/? D/mm-camera-intf: mm_stream_qbuf: VIDIOC_QBUF buf_index 1,stream type 1,frame_idx 4947,queued cnt 5
- 01-23 18:08:28.443 10842-11284/com.webrtc.demo.app W/ResourceType: No known package when getting name for resource number 0xffffffff
- 01-23 18:08:28.443 10842-11284/com.webrtc.demo.app I/org.webrtc.Logging: SurfaceViewRenderer: Dropping frame - Not initialized or already released.
- 01-23 18:08:28.463 301-12670/? E/AEC_PORT: aec_port_send_exif_info_update: exp_index:342, line_count:1989, real_gain:12.135149, target_luma:60, cur_luma:56, settled:0
- 01-23 18:08:28.463 301-12659/? E/mm-camera-sensor: port_sensor_handle_aec_update:993 g 12.135149 lux idx 339.890686
- 01-23 18:08:28.463 272-12657/? D/mm-camera-intf: mm_stream_read_msm_frame: VIDIOC_DQBUF buf_index 3, frame_idx 4948, stream type 7, queued cnt 7
- 01-23 18:08:28.463 272-12664/? V/QCamera2HWI: static void qcamera::QCamera2HardwareInterface::metadata_stream_cb_routine(mm_camera_super_buf_t*, qcamera::QCameraStream*, void*): iso_value:1200, exp_time:0.050039, mean_y:56
- 01-23 18:08:28.463 272-12664/? V/QCamera2HWI: static void qcamera::QCamera2HardwareInterface::metadata_stream_cb_routine(mm_camera_super_buf_t*, qcamera::QCameraStream*, void*) pMetaData->ae_params.settled = 0
- 01-23 18:08:28.463 272-12664/? D/mm-camera-intf: mm_stream_qbuf: VIDIOC_QBUF buf_index 3,stream type 7,frame_idx 4948,queued cnt 8
- 01-23 18:08:28.463 301-12670/? E/mm-camera: invalid stats mask. Return back
- 01-23 18:08:28.483 301-12645/? D/mm-camera: cpp_hardware_process_frame:1035] stream_status:0xb8e5c41c, iden:0x20002, cur_frame_id:4949
- 01-23 18:08:28.483 272-12657/? D/mm-camera-intf: mm_stream_read_msm_frame: VIDIOC_DQBUF buf_index 0, frame_idx 4949, stream type 1, queued cnt 4
- 01-23 18:08:28.483 272-12665/? V/QCamera2HWI: static void qcamera::QCamera2HardwareInterface::preview_stream_cb_routine(mm_camera_super_buf_t*, qcamera::QCameraStream*, void*) scanline:480, stride:640, frame_len:462848, rawSize:460800
- 01-23 18:08:28.483 272-12665/? D/QCamera2HWI: isTargetTrackingOn = 0
- 01-23 18:08:28.483 272-12665/? V/QCamera2HWI: static void qcamera::QCamera2HardwareInterface::preview_stream_cb_routine(mm_camera_super_buf_t*, qcamera::QCameraStream*, void*): mAutoSceneDetect not run!!!
- 01-23 18:08:28.483 272-12665/? V/QCamera2HWI: static void qcamera::QCamera2HardwareInterface::preview_stream_cb_routine(mm_camera_super_buf_t*, qcamera::QCameraStream*, void*), smartae_enable:true, scene_mode:auto, panorama:(null)
- 01-23 18:08:28.493 272-12665/? D/mm-camera-intf: mm_stream_qbuf: VIDIOC_QBUF buf_index 5,stream type 1,frame_idx 4948,queued cnt 5
- 01-23 18:08:28.493 912-1099/? D/HwWifiStateMachine: handleMessage: E msg.what=131155
- 01-23 18:08:28.493 912-1099/? D/HwWifiStateMachine: processMsg: ConnectedState
- 01-23 18:08:28.493 912-1099/? D/HwWifiStateMachine: processMsg: L2ConnectedState
- 01-23 18:08:28.493 301-12659/? E/AEC_PORT: aec_port_send_exif_info_update: exp_index:342, line_count:1989, real_gain:12.135149, target_luma:60, cur_luma:59, settled:1
- 01-23 18:08:28.493 301-12659/? E/AEC_PORT: aec_port_save_update:real_gain:12.135149 linecnt:1989 exp_idx:342 cur_luma:59 led_est:0
- 01-23 18:08:28.493 10842-11284/com.webrtc.demo.app W/ResourceType: No known package when getting name for resource number 0xffffffff
- 01-23 18:08:28.493 10842-11284/com.webrtc.demo.app I/org.webrtc.Logging: SurfaceViewRenderer: Dropping frame - Not initialized or already released.
- 01-23 18:08:28.503 1242-1242/? E/wpa_supplicant: RSSI=-49;LINKSPEED=86;NOISE=9999;FREQUENCY=2437;
- 01-23 18:08:28.503 912-1099/? E/WifiHW: wifi_send_command cmd:IFNAME=wlan0 SIGNAL_POLL;
- 01-23 18:08:28.503 912-1099/? D/HwWifiStateMachine: handleMessage: X
- 01-23 18:08:28.513 301-12670/? E/AEC_PORT: aec_port_send_exif_info_update: exp_index:342, line_count:1989, real_gain:12.135149, target_luma:60, cur_luma:59, settled:1
- 01-23 18:08:28.513 301-12659/? E/mm-camera-sensor: port_sensor_handle_aec_update:993 g 12.135149 lux idx 339.292084
- 01-23 18:08:28.513 272-12657/? D/mm-camera-intf: mm_stream_read_msm_frame: VIDIOC_DQBUF buf_index 4, frame_idx 4949, stream type 7, queued cnt 7
- 01-23 18:08:28.513 272-12664/? E/QCameraParameters: bool qcamera::QCameraParameters::needProcessHDRData() const KEY_SCENE_MODE:auto
- 01-23 18:08:28.513 272-12664/? V/QCamera2HWI: static void qcamera::QCamera2HardwareInterface::metadata_stream_cb_routine(mm_camera_super_buf_t*, qcamera::QCameraStream*, void*): iso_value:1200, exp_time:0.050039, mean_y:65
- 01-23 18:08:28.513 272-12664/? V/QCamera2HWI: static void qcamera::QCamera2HardwareInterface::metadata_stream_cb_routine(mm_camera_super_buf_t*, qcamera::QCameraStream*, void*) pMetaData->ae_params.settled = 1
- 01-23 18:08:28.513 272-12664/? D/mm-camera-intf: mm_stream_qbuf: VIDIOC_QBUF buf_index 4,stream type 7,frame_idx 4949,queued cnt 8
- 01-23 18:08:28.513 301-12670/? E/mm-camera: invalid stats mask. Return back
- 01-23 18:08:28.533 301-12645/? D/mm-camera: cpp_hardware_process_frame:1035] stream_status:0xb8e5c41c, iden:0x20002, cur_frame_id:4950
- 01-23 18:08:28.533 301-12659/? E/AEC_PORT: aec_port_send_exif_info_update: exp_index:342, line_count:1989, real_gain:12.135149, target_luma:60, cur_luma:59, settled:1
- 01-23 18:08:28.533 301-12659/? E/AEC_PORT: aec_port_save_update:real_gain:12.135149 linecnt:1989 exp_idx:342 cur_luma:59 led_est:0
- 01-23 18:08:28.543 272-12657/? D/mm-camera-intf: mm_stream_read_msm_frame: VIDIOC_DQBUF buf_index 1, frame_idx 4950, stream type 1, queued cnt 4
- 01-23 18:08:28.543 272-12665/? V/QCamera2HWI: static void qcamera::QCamera2HardwareInterface::preview_stream_cb_routine(mm_camera_super_buf_t*, qcamera::QCameraStream*, void*) scanline:480, stride:640, frame_len:462848, rawSize:460800
- 01-23 18:08:28.543 272-12665/? D/QCamera2HWI: isTargetTrackingOn = 0
- 01-23 18:08:28.543 272-12665/? V/QCamera2HWI: static void qcamera::QCamera2HardwareInterface::preview_stream_cb_routine(mm_camera_super_buf_t*, qcamera::QCameraStream*, void*): mAutoSceneDetect not run!!!
- 01-23 18:08:28.543 272-12665/? V/QCamera2HWI: static void qcamera::QCamera2HardwareInterface::preview_stream_cb_routine(mm_camera_super_buf_t*, qcamera::QCameraStream*, void*), smartae_enable:true, scene_mode:auto, panorama:(null)
- 01-23 18:08:28.543 272-12665/? I/IppAlgoSmartAE: doSmartAEAlgo() enter
- 01-23 18:08:28.543 272-12665/? D/QCameraParameters: int qcamera::QCameraParameters::getAETarget(void*, int*, int*) const lumaLowTarget=60, lumaHighTarget=60
- 01-23 18:08:28.543 272-12665/? D/QCameraParameters: int qcamera::QCameraParameters::getAEStatus(void*, int*, int*) const aecStabe=1, currentY=59
- 01-23 18:08:28.543 272-12665/? D/QCameraParameters: int qcamera::QCameraParameters::getAwbGain(void*, int*) const awbgain r_gain = 1, b_gain = 2
- 01-23 18:08:28.543 272-12665/? D/QCameraParameters: int qcamera::QCameraParameters::getRealGain(const void*, float*) const real_gain = 12.135149
- 01-23 18:08:28.543 272-12665/? D/QCameraParameters: int32_t qcamera::QCameraParameters::getBrightness(const void*, int*) const: new brightness value : 3
- 01-23 18:08:28.543 272-12665/? D/QCameraParameters: int qcamera::QCameraParameters::getFlashStatus(const void*, int*) const *flashStatus = 0
- 01-23 18:08:28.543 272-12665/? D/QCameraParameters: int qcamera::QCameraParameters::getActualExposure(const void*, int*) const exp = 19
- 01-23 18:08:28.543 272-12665/? D/QCameraParameters: int qcamera::QCameraParameters::getFocusAreas(int*, int*, int*, int*) x=0, y=0, w=0, h=0
- 01-23 18:08:28.553 272-12665/? D/QCameraParameters: int qcamera::QCameraParameters::setAETarget(void*, int, int) aeBrightnessLow = 3.000000, aeBrightnessHigh = 3.000000
- Tags:
- HTML5
- JavaScript*
Hi Zhen,
could you please provide us with the reproduce procedure? and device information on which this issue happend.
thanks.
We upgraded to the 3.3 from the 3.2 release and the above issue (which occurred pretty reliably on the 5th call) has been replaced with a blank self view which occurs around the 21st call (no crash). Specifically the self view is blank and video is not transmitted to the other party but the other party's video is rendered.
I think the issue might be related to us or the library not correctly releasing resources as there are 42+ instances of WoogeenSurfaceRenderer if we take a memory dump after this has occurred.
Will update if we find anything.
What do you mean on the 5th and 21th call? Can you describe more? Conference mode or P2P mode call?
Hi John, i think you need to release WoogeenSurfaceRenderer yourself.
