Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
1152 Discussions
Participants are not leaving room if app fails or crashes or network disconnects
ANIL_K_3
HI,
Participants are not leaving the room in case app crashes or fails or network disconnects .Before in this case after 45 seconds MCU used to remove that participant from the room . Now once we rejoin into room the old stream of the participant is still visible.
MCU VERSION 4.0 (Hardware)
Qiujiao_W_Intel
You can adjust the timeout in portal/portal.tom reconnection_timeout option, current default timeout is 60s.
