Hi Chunbo,
I Have Installed MCU Server and it is working perfectly with no issues.
Were as Peer server when i configured it and try to open the URL it says Cannot GET..am i missing any configuration, i have not done any changes.
RTSP Issue:
In Mcu Server when i try to open RTSP URL,..the video is getting published which i can see in console but there is no video
is there any extra configuration for RTSP or is there any specific IP cameras will work
I am using Hikvision DVR with H.264 codec and works fine when with VLC with the same URL
Naresh
- Tags:
- HTML5
- JavaScript*
Hi Naresh,
Peer Server is a signaling server, which does not host HTML files. What you need might be the sample P2P Web Application?
Thanks!
Hi Naresh,
What version of Intel CS for WebRTC are you using? Btw - there is going to be some delay on responses to technical questions this week.
Elmer Amaya
Hi Elmer,
We are using 3.0 Version on IntelCS. I have configured MCU and Peer server in single machine and also checked installing peer server in separate machine also it says cannot GET
Also if MCU is Natted with Public IP and we are using Coturn Turn Server as Nat Traversal.
Problem which we are facing is each client is using 4 UDP ports. lets say for a 5 party call turnserver consuming about 30 UDP ports, which is not possible to open so many ports as per security
Do you suggest any turnserverfor IntelCS
Naresh
Hi Naresh,
Thanks for the information. I'm discussing this with our technical team and will get back to you shortly.
Elmer
Hi Naresh,
Here is what I got from our eng team -
- Peer Server is a signaling server and accept socket.io connection. Make sure the signaling server address configured on sample page is replaced with your peer server, please check CS_WebRTC_Client_SDK_JavaScript.v3.0\samples\p2p\peercall.html.
- For RTSP issue, please make sure you have followed the Conference Server User Guide to install the Open H.264 library correctly to handle H.264 streams for software-mode MCU.
- For TURN server, typically it can work well with any standard TURN server, what we are testing with is the rfc5766-turn-server version 3.2.3.6 from https://code.google.com/p/rfc5766-turn-server/
Let me know if this addresses your issue.
Elmer
Hi Elmer,
Thank you for your time
1. I have configured peer server as per the installation instructions also configured the ssl with our certificate. when i run node peerserver.js
it shows me Listening port: 8095/8096
when i opened the same in browser it says cannot GET
How can i check whether peerserver is running or not
2. For RTSP i will reconfigure and check the same.
Naresh
Hi Naresh,
Thanks!
Hi Chunbo,
Thank you for your reply, will check the same and let you know.
Naresh
Great to hear that from you!
Thanks!
