Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
1151 Discussions
Portal 问题 - “INFO: Main - portal lost.”
Lai__Jing
今天我们生产环境发现房间的 token 创建失败,我们看了nuve,portal,cluster-manager 的日志发现如下相关信息,请帮忙分析是哪里的问题。谢谢!
查看nuve log 发现有如下打印:
2019-05-06 03:22:11.337  - INFO: CloudHandler - Faild in scheduling portal, tokenCode: 39346759040 , keep trying.
2019-05-06 03:22:11.407  - INFO: CloudHandler - Faild in scheduling portal, tokenCode: 17439080317 , keep trying.
2019-05-06 03:22:11.472  - INFO: CloudHandler - Faild in scheduling portal, tokenCode: 54750202303 , keep trying.
2019-05-06 03:22:11.582  - DEBUG: RoomResource - Room  5ccfa78cfefb2301b55f0343  deleted for service  5cadcdcb4b4eaf37f269a6ca
2019-05-06 03:22:11.603  - DEBUG: RoomsResource - Room created: 95_V270466_2019-05-06 11:21:47 for service hc-mcu-3
2019-05-06 03:22:12.208  - INFO: CloudHandler - Faild in scheduling portal, tokenCode: 67086559039 , keep trying.
2019-05-06 03:22:12.243  - INFO: CloudHandler - Faild in scheduling portal, tokenCode: 29199007881 , keep trying.
2019-05-06 03:22:12.338  - INFO: CloudHandler - Faild in scheduling portal, tokenCode: 39346759040 , keep trying.
2019-05-06 03:22:12.408  - INFO: CloudHandler - Faild in scheduling portal, tokenCode: 17439080317 , keep trying.
2019-05-06 03:22:12.473  - INFO: CloudHandler - Faild in scheduling portal, tokenCode: 54750202303 , keep trying.
2019-05-06 03:22:13.210  - INFO: TokensResource - CloudHandler does not respond
2019-05-06 03:22:13.210  - DEBUG: Nuve - { Error: Failed to get portal
  status: 500,
  code: 1301,
  data: { error: { code: 1301, message: 'Failed to get portal' } } }
2019-05-06 03:22:13.211  - WARN: Nuve - { Error: Failed to get portal
  status: 500,
  code: 1301,
然后查看Portal的log,有“Unknown by cluster manager woogeen-cluster” 和 “INFO: Main - portal lost.” 打印
2019-05-06 03:21:12.891  - DEBUG: SocketIOServer - sendMessage, event: progress data: { id: '457673395273724200',
  status: 'error',
  data: 'Source stream loss' }
2019-05-06 03:21:12.891  - DEBUG: SocketIOServer - notify participant: ZGU70tsmFyWZv16DANl4 event: participant data: { action: 'leave', data: 'kRsz2Io0oVFbiw69ANl3' }
2019-05-06 03:21:12.891  - DEBUG: SocketIOServer - sendMessage, event: participant data: { action: 'leave', data: 'kRsz2Io0oVFbiw69ANl3' }
2019-05-06 03:21:12.891  - INFO: ClusterWorker - Unknown by cluster manager woogeen-cluster
2019-05-06 03:21:12.892  - DEBUG: Portal - participant leave: 1gsME5yDPjyEgiI0ANmg
2019-05-06 03:21:12.892  - DEBUG: SocketIOServer - onClientLeft, id: undefined
2019-05-06 03:21:12.892  - DEBUG: Portal - participant leave: q2N69BavUVUMFaJlANmz
2019-05-06 03:21:12.893  - DEBUG: Portal - participant leave: kRsz2Io0oVFbiw69ANl3
2019-05-06 03:21:12.893  - DEBUG: SocketIOServer - onClientLeft, id: undefined
2019-05-06 03:21:12.893  - DEBUG: Portal - participant leave: ZGU70tsmFyWZv16DANl4
2019-05-06 03:21:12.896  - INFO: Main - portal lost.
2019-05-06 03:21:13.069  - DEBUG: SocketIOServer - sendMessage, event: drop data: undefined
2019-05-06 03:21:13.069  - DEBUG: Portal - participant leave: K1_GbKo8TEzK7_DeAAAA
2019-05-06 03:21:13.069  - DEBUG: SocketIOServer - close it, client_id: undefined
继续跟踪cluster-manager 的日志,发现如下的打印:
2019-04-10 11:11:25.657  - INFO: ClusterManager - Run as candidate.
2019-04-10 11:11:25.852  - INFO: ClusterManager - Run as master.
2019-04-10 11:11:25.856  - INFO: ClusterManager - Cluster manager is in service as master!
2019-05-06 03:21:09.473  - INFO: ClusterManager - Worker portal-e20b205253512ef1f85e@hc-mcu-prod.ikandy.cn is not alive any longer, Deleting it.
2019-05-06 03:21:13.114  - WARN: ClusterManager - schedule failed, purpose: portal task: 67086559039 reason: No worker available, all in full load.
2019-05-06 03:21:13.168  - WARN: ClusterManager - schedule failed, purpose: portal task: 29199007881 reason: No worker available, all in full load.
2019-05-06 03:21:13.223  - WARN: ClusterManager - schedule failed, purpose: portal task: 39346759040 reason: No worker available, all in full load.
2019-05-06 03:21:13.322  - WARN: ClusterManager - schedule failed, purpose: portal task: 17439080317 reason: No worker available, all in full load.
2019-05-06 03:21:13.397  - WARN: ClusterManager - schedule failed, purpose: portal task: 54750202303 reason: No worker available, all in full load.
2019-05-06 03:21:14.115  - WARN: ClusterManager - schedule failed, purpose: portal task: 67086559039 reason: No worker available, all in full load.
2019-05-06 03:21:14.169  - WARN: ClusterManager - schedule failed, purpose: portal task: 29199007881 reason: No worker available, all in full load.
2019-05-06 03:21:14.225  - WARN: ClusterManager - schedule failed, purpose: portal task: 39346759040 reason: No worker available, all in full load.
Hr__Z
部分模块的机子没连上cluster
