Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
1151 Discussions
Ports are not releasing after executing "bin/stop-all.sh" script
Chandramouli_P
After executing "sudo bin/stop-all.sh" commands, ports are not releasing automatically that is used by MCU application. When we restart the MCU by executing "sudo bin/start-all.sh", it is throwing the errors that ports are already in use. To resolve this, we are restarting the server every time or kill the processes manually each and every time. I believe that this is the bad practice. How to avoid this scenario?
Hence, request you to help us to resolve the issue.
Thank you.
Chandramouli.
Chandramouli_P
Any update would be appreciated. Thank you.
Chandramouli.
Chandramouli_P
Any help would be appreciated.
Thank you.
Chandramouli.
Lei_Z_Intel1
Which MCU version are you using?
Chandramouli_P
Hello Lei Zhai,
We wish you a very happy new year. We are using Intel CS for WebRTC v4.1. Any help would be appreciated.
Thank you.
Chandramouli.
Qiujiao_W_Intel
Hi, Chandramouli, can you reproduce this issue? If yes, could you provide us the log file of portal? This situation may happen when portal process doesn't work well.
Chandramouli_P
Hello Qiujiao,
I faced this issue when we setup MCU along with MongoDB, RabbitMQ together in a single server. Now, I setup MCU and MongoDB in two different machines. Now, I am not getting this issue.
Thank you.
Chandramouli.
Qiujiao_W_Intel
Umm, that does not make sense. Another possibility for this issue may be that related log files have been removed before stopping all modules, since we need refer to related process id in log file.
