Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
RTMP issue MCU v 3.3
Naresh_R_1
Hi Lei,
We are testing MCU v 3.3 noticed RTMP/RTSP stream is not working
Server Details
 Intel(R) Core(TM) i7-4790S CPU @ 3.20GHz
CentOS 7.1 ( Since 7.2  with above server is not supporting Media server studio 2016)
Hardware Accelerated
Deployed ffmpeg with libfdk_aac
Below is the log error
INFO: stream 5885d0f7f176b87aa928991d VideoLayoutChanged
woogeen.sdk.js:8 ERROR: start external streaming failed: Not allowed to subscribe an already-subscribed stream
196woogeen.sdk.js:8 INFO: stream 5885d0f7f176b87aa928991d VideoLayoutChanged
Do we have to enable RTSP/RTMP some where is configuration since i did found any configuration file in access_agent
Version 3.2.1 is working fine with above configuration with H/W accelerated
Naresh
Lei_Z_Intel1
RTMP output? Can you please open the debug log for avstream node and send to us? We will diagnose after Chinese New Year holiday. Thanks for your patience.
Naresh_R_1
Hi Lei,
Can we stream a RTSP URL like below with Intel Basic Example
rtsp://mpv.cdn3.bigCDN.com:554/bigCDN/mp4:bigbuckbunnyiphone_400.mp4
Naresh
Naresh_R_1
Hi Lei,
You can also check with this IP camera URL which has no audio
Model: Hikvision DS-7208HVI-SH
rtsp://intel:password@203.196.151.179:554/h264/ch7/main/av_stream
Naresh
Lei_Z_Intel1
The basic sample of v3.3 has some defect on RTSP input, which by default enable neither video nor audio for RTSP source. As a workaround, you can either modify the source code of basic sample according to JS SDK guide on file <InstallFolder>/extras/basic_example/public/script2.js, or replace the script2.js with attached file, and use query string to control audio/video flag like https://x.x.x.x:3004/?url=xxxx&audio=false&video=true.
Naresh_R_1
Hi Lei,
I am able to connect the rtsp video but the video ouptut is like just a image, you can test with the above mentioned rtsp URL
Naresh
