Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
RTSP IP camera stream not working
Naresh_R_1
Hi Lei,
Configured MCU v 3.2 with MSS 2016 and enabled rtsp muxing in access agent.toml  , Testing with RTSP based ip camera with the basic example room with the below URL format
https://www.domain.com/?url=rtsp://admin:test@test123@203.196.151.179/h264/ch5/main/av_stream
we are using DVR HIKVISION DS7208HVI-SH Model
Its working very fine with VLC through network stream and it was working in last version of MCU but video gets stuck and  works like a slide show
I think in the present version ffmpeg library has been updated for rtsp based input
How can we check the RTSP based camera with basic example, is there any other configuration to work with
Also i want to know how rtsp muxing works
Naresh
Lei_Z_Intel1
Can you please share your zipped log folder to us, especially the avstream node log?
Naresh_R_1
Hi Lei,
Please find the attached log folder.
Naresh
Lei_Z_Intel1
From the log, your IP Camera has no audio, was your local stream created with audio : false?
Naresh_R_1
Hi Lei,
We are not creating any local stream, i am just working with basic example with below url
https://www.domain.com/?url=rtsp://test:test123@203.196.151.179/h264/ch5/main/av_stream
Naresh
Lei_Z_Intel1
The basic example is just a simple sample and not that complete. Look at the code, it will create stream based on the RTSP url without any audio/video attribute setting, so the backend will treat it as audio=true and video=true, but can't find audio. The complete logic should be the application know the stream attribute and set them explicitly during creating stream.
Naresh_R_1
Thanks Lei for the support
