Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
Recording in a room not working
Ravi_Prakash
Hi Team,
I am running MCU 4.3.1 on CentOS 7 on single intel server on Goolge cloud. I have successfully setup the system and able to create room, delete rooms, adding participants etc...
When I try to record a stream in the given room. It always throws an error:
1201, Failed to call cluster.
 However, cluster manager is working and the logs are as follows :
2020-12-11 13:29:10.810  - INFO: AmqpClient - Connecting to rabbitMQ server OK, options: { host: 'localhost', port: 5672, login: 'remoteuser' }
2020-12-11 13:29:10.816  - INFO: Main - Cluster manager up! id: 551853573
2020-12-11 13:29:10.817  - INFO: ClusterManager - Run as candidate.
2020-12-11 13:29:11.012  - INFO: ClusterManager - Run as master.
2020-12-11 13:29:11.017  - INFO: ClusterManager - Cluster manager is in service as master!
management_api.toml
[cluster]
name = "owt-cluster"
What can be the problem?
- Ravi
Ravi_Prakash
Hi Team,
Any updates on the above will be appreciated.
Ravi
Ravi_Prakash
Hi Team,
Any updates on this ticket will be appreciated.
Ravi
Ravi_Prakash
Can anyone tell me the reason for the same?
Ravi
Ravi_Prakash
Solved it by myself. It was config error for IP Adress.
