How many storage size needed by recording the mix mode per minute?My resolution is 640x480.
Thanks!
- Tags:
- HTML5
- JavaScript*
This depends on your mix stream default output bitrate, in latest v3.3 we have default quality level setting. See the following table for projected quality level and bitrate mapping.
Note: This will not be 100% accurate in run time, because system auto adjust the bitrate according to the system environment.
Topic Options
