Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
Regarding Quality level
Naresh_R_1
Dear Lei,
What is the bitrate parameters for various quality levels available
Best Quality, Better Quality, standard, betterspeed, bestspeed? are these parameters is applicable for only mixing?
How can i manually input bitrate for output video
Also how can i control bitrate for output video in forwarding stream
Naresh
Lei_Z_Intel1
Currently the quality setting is only designed for mix stream. Forward now only do the codec transcoding and follow the stream's original quality condition.
Naresh_R_1
Hi Lei,
Thanks for the reply.
How do i control input and output frame rate. how much ever the frame rate we input it takes high.
Also how do i control mixing video output to set only particular bandwidth
Naresh
Lei_Z_Intel1
Input frame rate can be controlled through local stream creation. Output fps can be set.
Mix video output bandwidth can be set through quality level option of subscription parameter.
Naresh_R_1
Hi Lei,
Whatever is the FrameRate set in the local stream creation chrome always taking default 30 fps, also does bandwidth required get reduces if i input less FrameRate?
If i control input bandwidth while creating forward stream does the output will be the same as specified in input?
My main concern here is i should be able to control bandwidth and run the application on lower bandwidths
Naresh
董_洪_
Hi Lei,
      I have the same problem, i can't control the subscription bitrate,  and the quality level option does't seem to work
Jianjun_Z_Intel
Hi Naresh,
Could you please provide more detailed information about how you create a LocalStream with specific fps? It should work on Chrome 60.
