Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
Remote View Orientation Problem in iOS.
K__Srujan
Начинающий
2 495Просмотр.
Hi Team,
Our iOS Application is using Landscape orientation, but when in Video call if I rotate my device to portrait, my local video in Stream View/  Remote View is also rotating, which is not an expected scenario. The orientation of my local video should also be locked, if I lock my orientation.
Please help us in solving the above issue.
Configuration:
1. Environment - iOS.
2. SDK - CS_WebRTC_Client_SDK_iOS.v4.1
0 баллов
10 Ответы
K__Srujan
Начинающий
2 495Просмотр.
Hi Team,
Any update would be appreciated!
YanbinZ_Intel
Сотрудник
2 495Просмотр.
Hi
 This is a known issue and already added to fix plan.It may take a while in consider of it’s urgent level . BTW, welcome contribute a fix to OMS if you has good solution:)
Yanbin
K__Srujan
Начинающий
2 495Просмотр.
Hi Yanbin,
Thanks for your response.
We have tried to install OMS Native Client using below link.
https://github.com/open-media-streamer/oms-client-native
But we are stuck at running your build.py scripts. Could you please help us out to generate SDK's for iOS, so that we can pitch in?
Below is the error log while installing.
$ python build.py
  File "build.py", line 24, in <module>
    import sdk_info
ImportError: No module named sdk_info
PS: It would be more useful if you provide a step by procedures. :)
K__Srujan
Начинающий
2 495Просмотр.
Hi Team,
Any update would be helpful!
Thank you.
Srujan K
YanbinZ_Intel
Сотрудник
2 495Просмотр.
Hi Srujan K
 Did you run 'gclient sync '  before above python scripts ?  And please make sure 'gclient sync ' finished successful without any error .
Yanbin
YanbinZ_Intel
Сотрудник
2 495Просмотр.
And. If  you want update configuration / parameters, please run 'python build.py --help ' to found detail parameters . Without parameters , it will use default parameters and configuration .
K__Srujan
Начинающий
2 495Просмотр.
Hi Yanbin,
We have done the above all suggested steps and still face the same issue.
Kindly, suggest a step by process so that it might be helpful for everyone.
Dabhi__Hardik
Начинающий
2 495Просмотр.
I am an ios mobile application developer.
I am working on webRTC based project.
Dabhi__Hardik
Начинающий
2 495Просмотр.
If you have a concern regarding webRTC mobile orientation for your local view I can help you.
Jincheng_S_Intel
Сотрудник
2 495Просмотр.
Bellow is our latest webRTC source code link:
https://github.com/open-webrtc-toolkit/owt-client-native.
You can refer to the readme doc to build it or follow bellow steps.
1. install depot_tools and add it to path
2. build OpenSSL 1.1.0l or higher
3. clone the source code to src dir
4. Create file named .gclient under the same directory of src dir, with below contents:
solutions = [
    "managed": False,
    "name": "src",
    "url": "https://github.com/open-webrtc-toolkit/owt-client-native.git",
    "custom_deps": {},
    "deps_file": "DEPS",
    "safesync_url": "",
target_os = ["mac", "ios"]
5. run "gclient sync" command in src dir
6. run build script "python scripts/build.py --arch x64,arm,arm64 --skip_tests --ssl_root ~/Documents/OpenSSL-for-iPhone --scheme release" in src dir
Ответить
