Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
Setting publicIP
Babis_H_
I have MCU running and i can access it from an internal ip address
I need to set the public IP to access it from outside
In which configuration file I can set this ?
I have 3.2.1 release and i don't have  woogen_config.js anywhere (and everything working internal)
Lei_Z_Intel1
Hi, Babis
Now MCU server has been divided to distributed components, like nuve, cluster-manager, portal, etc. Each component has its own configuration as toml format, rather than the unified woogen_config.js before. Details please check https://software.intel.com/en-us/documentation/webrtc-conference-server-guide/mcu-installation.
The public IP configuration you mentioned now is located at the [portal] section in portal/portal.toml.
Best wishes,
Zhai Lei
