Hello.
I'm using MCU v3.4 and Javascript SDK sample code, when i enable or disable Audio/Video streams the other peers doesn't receive the events.
The code I use to handle events :
['VideoEnabled', 'AudioEnabled', 'VideoDisabled', 'AudioDisabled'].map( function(event_name) { stream.on(event_name, function() { L.Logger.info('stream', stream.id(), event_name); }); });
And the other peer action was:
stream.disableAudio();
Anyone can help me? is there something wrong? Thanks!
- Tags:
- HTML5
- JavaScript*
Hi there!!! Anyone has any suggestion¿?
RemoteMixedStream.emit('VideoEnabled', evnet);
RemoteMixedStream.on('VideoEnabled', function(event) ;
This can, but only inform this client
Are you right. If you emit an event in RemoteStream of an user, you receive the event in RemoteStream of this stream, but its locally and don't make sense.
In the documentation says that this kind of events was reserved by MCU and triggers when the streams change.
void Woogeen.RemoteStream.on( string event, function listener )
This function registers a listener for a specified event, which would be called when the event occurred.
Remarks:
Reserved events from MCU:
Event Name | Description | Status |
VideoLayoutChanged |
Video layout of the mix (remote) stream changed | stable |
VideoEnabled |
Video track of the remote stream enabled | stable |
VideoDisabled |
Video track of the remote stream disabled | stable |
AudioEnabled |
Audio track of the remote stream enabled | stable |
AudioDisabled |
Audio track of the remote stream disabled | stable |
User-defined events and listeners are also supported, See stream.emit(event, data) method.
Reading this, I understand, when user disable audio in his LocalStream, the others users in the room must receive in their remoteStreams of that user an AudioDisabled event. It must works like this behavior? or i'm wrong
Remarks:
Event Name
Description
StatusVideoLayoutChanged
stableVideoEnabled
stableVideoDisabled
stableAudioEnabled
stableAudioDisabled
stableUser-defined events and listeners are also supported, See stream.emit(event, data) method.
Currently found only VideoLayoutChanged can receive the notice from the MCU, audio and video status can not be received, unless this bug. Now only through the send way to broadcast messages to achieve
Remarks:
Event Name
Description
stableVideoEnabled
stableVideoDisabled
stableAudioEnabled
stableAudioDisabled
me be you can try 'StateChange', from to SDK 'update_stream'
Hi Marçal,
disableAudio/disableVideo only disables audio/video tracks on you local machine. It does not send message to remote side.
Then I don't understand when the events fires, i tried tons of modifications but Enable/Disable Video/Audio events never triggers.
Other thing I can't understand it's: when you emit an event through an RemoteStream only the user that fires the event receive this event :S
Has been modified by modifying the updateStream audio and video status changes
session_agent/session.js
n.updateStream = function(e, o, r, n) {log.info("updateStream:", e, r,o),g("room", "all", "update_stream", {event: "StateChange",id: e,state: r,type:o}), i ? (i.updateStream(e, o, r), n("callback", "ok")) : n("callback", "error", "Controller is not ready")}
woogeen.sdk.js
j.socket.on("update_stream", function(a) {//if(void 0 !== j.remoteStreams[a.id]) return void e.Logger.warning("stream already added:", a.id);var b = j.remoteStreams[a.id];if(a.event == 'StateChange') {c = new d.StreamEvent({type: "stream-update",stream: b,msg:a.state,avType:a.type});j.dispatchEvent(c);} else {b && b.emit(a.event, a.data)}})conference.on('stream-update', function(event)
