Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
Test Intel MCU example
dennis_n_
Hello
I installed the MCU server v2.1.1 on a public Internet server. Now I try to test the sample that comes with the version.
When I start the example I get in the browser console an error message "timeout".
Any idea?
TURN server is required ?
I am using Firefox 38 to test the sample.
Attached, I send an image from my browser.
Thanks for your help
Chunbo_H_Intel1
So, what I get now is that you have a MCU server on public network, which makes sense. But how do you connect to the server? Via client device on public network as well, or some clients behind NAT/Firewall?
dennis_n_
Hello
I think that I'm on a public network. I'm using a public Vodafone network. My IP is 2.202.X.X. Also, I review the following web sites
https://www.whatismyip.com/es/
and my public IP address matches my IP address.
Now I'm only testing the technology
In the future I want to make an application in which users might be behind a NAT.
TURN server is required ? How I can configure TURN server? I can not find information in the MCU server User Guide.
Attached, I share my log file.
Thanks for your help.
Farrukh_M_
We are using rfc5766 free open source TURN server. Please goto this link and you will find in the left column, how to setup TURN for webrtc.
https://code.google.com/p/rfc5766-turn-server/
dennis_n_
Hello Farrukh and CHUNBO
Thanks for your time
Today I followed the instructions in the link and I could install the TURN server rfc5766-turn-server version 3.2.5.7 on the same server where I have installed the MCU server.
The TURN server works well. I tested using the tool "turnutils_uclient".
Then I made the following changes to the woogeen_config file to configure the TURN server.
config.erizoController.turnServer.url = 'turn:X.X.X.X:3478?transport=udp'; // default value: null
config.erizoController.turnServer.username = 'username'; // default value: null
config.erizoController.turnServer.password = 'password'; // default value: null
Then, I tested the example that comes in the Intel MCU server but I get the same error in the browser console "timeout".
Also, I tested changing the example code that comes with the Intel MCU server. I added the following line of code in the file Script2.js
conference.setIceServers([{url: "turn:X.X.X.X:3478?transport=udp",username: "username",credential: "password"}]);
When I test the example, I get the same error in the browser console "timeout".
My questions are now:
Can I configure the intel MCU server to work with TURN server.?
How can I configure the basic example to work with TURN server.?
Farrukh_M_
check your router logs to see if all required ports are open to your MCU server.  Can you run the following command on MCU server
netstat -an | grep LISTEN
paste the result.
Also try using ?tcp instead of udp as sometimes its blocked.
Farrukh_M_
Below are the required steps to install TURN server:
1) Install turn server as mentioned in below URL
http://blog.knoldus.com/2013/10/24/configure-turn-server-for-webrtc-on-amazon-ec2/
Once it is installed, and ports are open, don't do step 4 and 6 on his blog. Follow below directions
2) create a cert/key using openssl command. I copied it in /usr/local/etc but you can use choose any folder where turn server has PATH mentioned.
openssl req -x509 -nodes -days 365 -newkey rsa:2048 -keyout mysitename.key -out mysitename.crt
3) Copy paste below to a "turnserver.conf" and place it under "/usr/local/etc/
tls-listening-port=443
#Internal Amazon Private IP
listening-ip=172.31.X.X
#Internal Amazon Private IP, same as above
relay-ip=172.31.X.X
#External / Elastic IP from Amazon
external-ip=52.24.X.X
lt-cred-mech
#User:Password
user=User1:Password1
#Enable FingerPrinting
fingerprint
realm=ec2-52-X-X-X.us-west-2.compute.amazonaws.com
cert=/usr/local/etc/cert.crt
pkey=/usr/local/etc/key.key
4) Start the server using --> nohup turnserver  &
5) Start /bin/restart-all.sh
Hope it helps....
Chunbo_H_Intel1
Q: Can I configure the intel MCU server to work with TURN server.?
A: Sure, look into woogeen_config.js file:
config.erizoController.turnServer = {}; // default value: undefined
config.erizoController.turnServer.url = 'turn:X.X.X.X:4478?transport=tcp'; // default value: null
config.erizoController.turnServer.username = 'you'; // default value: null
config.erizoController.turnServer.password = 'master'; // default value: null
Q: How can I configure the basic example to work with TURN server.?
A: Yes, ConferenceClient has API as following:
                url: "turn:X.X.X.X:4478?transport=tcp",
                credential: "master",
                username: "you"
                url: "turn:X.X.X.X:443?transport=tcp",
                username: "you"
yongtao_x_
大家好: V3.3 已经找不到 woogeen_config.js  ,该怎么去配置  TURN server 呢,谢谢
