Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
URGENT: Chrome 74+ is not compatible. ICE failure. fix needed.
Stephen_-_
Chrome 73 works fine, Chrome 74+ does not. Here is the error shown in the console for the basic example: https://i.imgur.com/IlmzSpQ.png
It happens when you try to broadcast your camera on the 4.1.1 conference server, it will not let you broadcast. I have not tried other versions.
Chrome 74 is estimated to release in LESS THAN 4 weeks.
Please confirm that the team is looking into a fix as 95% of our users use Chrome and not being able to broadcast from it would be devastating.
Narayanan__Vishnu
Hi ,
We are using 4.0 Version and also facing the same issue. Please let us know.
Lei_Z_Intel1
Issue received. Thanks a lot for reporting this. Will fix it in coming 4.2 release around early April.
tk__sruthin
We are facing same issue.Please let us know once it fixed
Mark_d_10
With this fix, will Edge also still work?
Lei_Z_Intel1
Should not have impact to Edge compatibility.
Narayanan__Vishnu
Thank you. When you release the fix, we need to upgrade the whole infrastructure or are you planning any patch fix for users who are using versions like 3.4 or 4.0? Thanks
Stephen_-_
It's been 2 weeks now I'm starting to get nervous! <2 weeks until doomsday. Any progress update?
Naresh_R_1
4.2 version is released please download from https://software.intel.com/en-us/webrtc-sdk/download
Naresh
Redlof__Markus
Hi folks. Did someone found already a FAST way to make 4.1 work with Chrome 74+ ? Patch? Or do we really have to completely update to 4.2?    I´m writing this cause our chief engineer should have holidays and now this Chrome issue pops up. By the way, we heavily use this awesome project in production scenarios and are very thankful for this. Thank you all.
Stephen_-_
From my testing so far, it appears that Chrome 74 and 75 were updated to work with plan-B again and thus 4.1 is compatible (please check yourself) . So as long as they don't flip it back, I think everything is okay, but as I have users who like to occasionally use chrome beta I'm glad 4.2 uses unified-plan as default, as I suspect Chrome will flip support on and off for plan-b on beta's from now on.
Jianjun_Z_Intel
The reason for this failure is Chromium tried to remove DTLS 1.0, TLS 1.0 and TLS 1.1 support from M74. However, this change was reverted before M74 release.
