Environment details:
Operating System: Ubuntu-18.04.2
Model Name: Intel(R) Core(TM) 8th Gen i5-8400 CPU @ 2.80GHz (6 Cores)
RAM: 4 GiB DDR4
Intel OWT version: 4.2.1
When I am trying to build the Media Analytics plugins, I am getting the compilation errors that are related to source code. I installed all dependencies like Intel Media SDK, CMake, OpenVino, etc. Please find the below error message partially:
$ cd Release-v4.2.1/analytics_agent/plugins/samples
$ ./build_samples.sh
[ 66%] Linking CXX shared library ../intel64/Release/lib/libcpu_extension.so
[ 66%] Built target ie_cpu_extension
Scanning dependencies of target facedetectionplugin
[ 68%] Building CXX object face_detection_plugin/CMakeFiles/facedetectionplugin.dir/main.cpp.o
/home/chandramouli/Release-v4.2.1/analytics_agent/plugins/samples/face_detection_plugin/main.cpp: In member function ‘virtual InferenceEngine::CNNNetwork FaceDetectionClass::read()’:
/home/chandramouli/Release-v4.2.1/analytics_agent/plugins/samples/face_detection_plugin/main.cpp:151:61: error: ‘InferenceEngine::Data::dims’ is deprecated [-Werror=deprecated-declarations]
const InferenceEngine::SizeVector outputDims = _output->dims;
In file included from /opt/intel/openvino_2019.2.242/deployment_tools/inference_engine/include/ie_layers.h:20:0,
from /opt/intel/openvino_2019.2.242/deployment_tools/inference_engine/include/inference_engine.hpp:19,
from /home/chandramouli/Release-v4.2.1/analytics_agent/plugins/samples/face_detection_plugin/myplugin.h:15,
from /home/chandramouli/Release-v4.2.1/analytics_agent/plugins/samples/face_detection_plugin/main.cpp:15:
/opt/intel/openvino_2019.2.242/deployment_tools/inference_engine/include/ie_data.h:46:16: note: declared here
SizeVector dims;
Please find the full error messages in this URL: https://pastebin.com/CmSNLt4X
Also, as explained in the Intel official documentation, there is no folder with the name "computer_vision_sdk" in /opt/intel. After installing OpenVino latest versioin ("l_openvino_toolkit_p_2019.2.242.tgz"), I found "openvino" and "openvino_2019.2.242" folders inside the /opt/intel/.
I tried to build the plugins by changing the value of setvars_path variable from "computer_vision_sdk" to ""openvino" and "openvino_2019.2.242" in Release-v4.2.1/analytics_agent/plugins/samples build_samples.sh file. After running ./build_samples.sh, getting the same errors.
Hence, request you to suggest a solution.
Thank you in advance.
Chandramouli.
- Tags:
- HTML5
- JavaScript*
Hello Team,
Any update would be appreciated.
Thank you.
Chandramouli.
Hi Chandramouli P, looks like you need to setup OpenVino variables.
Open a terminal:
gedit ~/.bashrc
then add at end of file next line:
source /opt/intel/openvino/bin/setupvars.sh
Close terminal. Next time you open a terminal you will see:
[setupvars.sh] OpenVINO environment initialized
I hope this help you.
Hello Jorge,
I have already added as you said. Also, I am getting "OpenVINO environment initialized" message also on terminal. But, getting the errors. Any other suggestion?
Thank you.
Chandramouli.
Hello Team,
Thank you.
Chandramouli.
Hello Team,
Any help would be appreciated.
Thank you.
Chandramouli.
Hello Team,
Thank you.
Chandramouli.
Hello Team,
Thank you.
Chandramouli.
Hi,Chandramouli, our analytics currently works well with OpenVino 2018 R5, so please install this version on your environment and have a try.
Hello Qiujiao,
Thank you for your reply. Sure, As you suggested, I installed and there are no issues as of now.
Thank you, once again.
Chandramouli.
