Hello. We try to test new version.
We installed as in instaruction. Started separated erizo, nuve, mcu, and separate example app.
But when I try to test xxx:3001 -in logs I recieve
2016-01-24 03:33:29.929 - INFO: NuveAuthenticator - [Auth] Wrong credentials
I tryed to review code, but couldn't understand what credentalsa it is need to nuve and when and how browser should give it.
All logs and configuration files are in attachment
- Tags:
- HTML5
- JavaScript*
Hi Artem,
Please check the service key and id you used in the basic sample server. This is the key credentials for the NuveAuthenticator.
Another thing is that which version of Chrome you are using now?
Thanks!
You are right - I had wrang id in example. Now I made id equal
config.nuve.superserviceID = '56a38c8bddd0ce1f1ae2eb09'; // default value: ''
N.API.init( '56a38c8bddd0ce1f1ae2eb09' ,'c1d88bf3e2171e750ca2ecc94ae2ef00f63c137832483c2a8a725cec9e89e675a8f86d7fa481b78fa3463ce999e0abd1dc82b66db43574df80777bdef4cf312b68cb71141b8067dd82da67e604db945af668efa1a996248a75fddc003b17ca03d3cb843829ae695cb74bee019829b4f01961f2710fca11699402b098b15bff484436dad70f5401c169acedd09ce36963a8b8ef0fe54407422b09ba78549b68ba0e629de0000aefde281170a2' , 'http://localhost:3000/');
But the result is the same:
{ realm: 'http://marte3.dit.upm.es', signature_method: 'HMAC_SHA256', serviceid: '56a38c8bddd0ce1f1ae2eb09', cnonce: '2c4a7ea6e1ae2d8f', timestamp: '1453855407897', signature: 'Y2E5ODM1M2Y0MGQ4ZmRjNWNlYTM5NjlkMTNiMjBhODVjMmJkOTk3M2VlZTA0ZTJhMTEyYjA1ZTZjOTRmZjE3Mg==' } 3fOHzyrh4lkpTv+KrEVwXO2ldfzR00UvjD1AH6jQgdSrKa/4AeX9Lv0hrN5xmSSLooNy3ejJWxI7rIkN/Y8BqLkZFo8XsVBQCeSvvZcY5VXs9XO8gfHCNbp7mTQahUSfmUqo2xyRPGnLGHPD1GXC6R8dN9EOoJ4gp/lXjtvxbiA= r = MTNiZmE4ZjczNDgwOTNiMzIwNTVlZmMwNWQwZDUyNjgwYzlkN2M2NDE2NGJiZGQ1ZWY2OTczY2NlMWI2YmIyMw== 2016-01-27 03:43:27.959 - INFO: NuveAuthenticator - [Auth] Wrong credentials
Chrome is last version 48.0.2564.82 m.
Mozilla works in the same way, so I don't think that the browser issue
Hi Artem,
The NuveAuthenticator mainly checks the signature of incoming connection. So could you please check the service key in your basic server sample with the original value?
Thanks!
Here is my mongo collections. Config and sample values I posted in previous post
{ "name":"sampleService", "key":"b3e8a7f0a101597f69a2f1ef57a4a57be14a3d4b246c67299d3f65dbc0dbc272b2ed3e559887f689fd6e28e8b0e0cb97e5a3a37b8c0e17f9b67b1fcbf6f90f547793591d109665de8fd07b9e3bf396759f67e199e1ab2be470e5d3282622ef03a7faa30b2bb77c47b72d8521d949ada91f6ff75572e20e339a3a92ccbc77996a5b35fef652152fa15dd2ebf381ec0a77d0b2e32abc2272453143ac4655bd11bc460fb5fa2910f5d0301064a2", "encrypted":true, "rooms":[ ], "_id":ObjectId("56a38c8bddd0ce1f1ae2eb0a") }{ "name":"superService", "key":"c1d88bf3e2171e750ca2ecc94ae2ef00f63c137832483c2a8a725cec9e89e675a8f86d7fa481b78fa3463ce999e0abd1dc82b66db43574df80777bdef4cf312b68cb71141b8067dd82da67e604db945af668efa1a996248a75fddc003b17ca03d3cb843829ae695cb74bee019829b4f01961f2710fca11699402b098b15bff484436dad70f5401c169acedd09ce36963a8b8ef0fe54407422b09ba78549b68ba0e629de0000aefde281170a2", "encrypted":true, "rooms":[ { "name":"myRoom", "mode":"hybrid", "publishLimit":-1, "userLimit":-1, "mediaMixing":{ "video":{ "avCoordinated":0, "maxInput":16, "resolution":"vga", "multistreaming":0, "bitrate":0, "bkColor":"black", "layout":{ "base":"fluid", "custom":[ ] } }, "audio":null }, "enableMixing":1, "_id":ObjectId("56a38ffd307277bc1c8ddc3d") } ], "_id":ObjectId("56a38c8bddd0ce1f1ae2eb09") }
That issue was fixed in 3.0.1
OK. Great to hear that.
