Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
Where to find "sioclient_tls.lib"?
sanghoon_K_
Hi...
Recently, I downloaded the Intel Collaboration Suite for WebRTC Client SDK for Windows.
But, I have a problem.
I cannot compile because sioclient_tls.lib.
The sioclient_tls.lib is being referenced by the sample project, I cannot find this library.
Thank you.
招学_余_
有关sioclient_tls.lib,如有需要请联系我
顺别也跟你交流下我碰到的问题,对我的问题看看能否有解
谢谢
Chunbo_H_Intel1
Hi sanghoon,
We do not provide the siocket_tls.lib in our release package. If you need it, please compile it from the source code.
Thanks!
Martin_A_1
Hi, in this docs you're saying that
The sioclient_tls.lib included in release package has been enhanced to verify server's certificate. Handshake fails if the server is using an invalid certificate.
https://software.intel.com/sites/products/documentation/webrtc/windows/index.html
I didn't find any sioclient libs in the latest release.
Please, give us a hand here, where can we find this lib files?? If the docs are wrong, please fix them , but it'll be great if we can have this as part of the release.
Regards.
M.
Rohlof__Markus
Hi, I have the same problem as Martin A.
You mention in the documentation that there are modifications in sioclient_tls.lib but the file is not part of the release. Is it possible to give a hint what modifications where made so that I can compile the library from source?
Thanks and best regards
Markus
song__philip
this is a problem of socket.io-client-cpp, check the github code https://github.com/socketio/socket.io-client-cpp/blob/master/CMakeLists.txt#L49-L51, if you install openSSL, then sioclient_tls.lib will be built.
