HI,
Our Woogeeb_webrtc node instance utilising more that 90% CPU we are having only two mix conference room with 4 participants each . As per our debug we came to know that lot of woogeen_webrtc process are running from long time more than 900 hours too even tcp ports are not releasing after call hangup this is known issue . But the process also running from long time is this is related with current ports release issue and as expected ?
Please find the attached screen captures for process not releasing and ports not release
MCU version we are using was 3.5.2 Ubuntu Edition
- Tags:
- HTML5
- JavaScript*
Hi, ANIL, we improved a lot in stability for webrtc agent in version 4.0, please have a try.
Thank you . Above issue was fixed in 4.0
