Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
an issue in intel cs 3.0.1
han_x_
I deploy intel cs 3.0.1 in a virtual machine (Ubuntu 14.04.2 64bit),it works ok.
I want to know the max user number,so i open the url (https://192.168.1.103:3004/?mix=false) one by one in a chrome.
The 1~5 chrome tab is ok,every tab have five images. When i open the sixth tab,an error has occurred.Then,the 1-5 tab lost other tab's image,left only one.If refresh the 1-5 tab in turn,it can resume.So the mcu is not crash。
I do the same test repeatedly,the max user number (or the max tab number) no more than 5 (with mixer=false and default configuration).
But i do the same test in 2.8.1 in a same VM server,the max user number can reach 15.
Do you know what happened in the new version 3.0.1?
thanks!
PS:    woogeen_mcu log in attachment.
Chunbo_H_Intel1
Did you use the same client to connect to MCU with both 2.8.1 and 3.0.1? If there is any other difference in machine confiuration, please let us know.
Another thing is that what's your server configuration in your VM?
Thanks!
han_x_
我在之前部署3.0.1的Ubuntu 14.04虚拟机上,部署3.1(只运行bin/init.sh --deps 和 bin/start-all.sh,其余不变,都是之前3.0.1的环境)。在3.0.1上出现的问题没有了。不混流情况下,在Chrome上打开15个标签页,依然没有崩溃。
另外,我测试2.8.1、3.0.1、3.1用的虚拟机配置完全相同。
Chunbo_H_Intel1
请问你使用的Chrome版本是多少? 都是一样的版本么?
谢谢!
han_x_
用的是我自己编译的chromium,版本 46.0.2490.71。
有时也用官方的chrome 46、47进行对比测试,测试效果和自己编译的chromium没明显差别。
Chunbo_H_Intel1
Hi Han,
因为WebRTC的实现在Chrome里在持续更新,请使用最新版本的Chrome浏览器来进行测试。
谢谢!
