Android studio1.5 build android P2pSample Error:
Error:Execution failed for task ':src:sample:p2pSample:transformClassesWithDexForDebug'.
> com.android.build.api.transform.TransformException: com.android.ide.common.process.ProcessException: org.gradle.process.internal.ExecException: Process 'command '/usr/java/jdk1.8.0_73/bin/java'' finished with non-zero exit value 2
UNEXPECTED TOP-LEVEL EXCEPTION:
com.android.dex.DexException: Multiple dex files define Lorg/webrtc/VideoCapturerAndroid$CameraErrorHandler;
at com.android.dx.merge.DexMerger.readSortableTypes(DexMerger.java:594)
at com.android.dx.merge.DexMerger.getSortedTypes(DexMerger.java:552)
at com.android.dx.merge.DexMerger.mergeClassDefs(DexMerger.java:533)
at com.android.dx.merge.DexMerger.mergeDexes(DexMerger.java:170)
at com.android.dx.merge.DexMerger.merge(DexMerger.java:188)
at com.android.dx.command.dexer.Main.mergeLibraryDexBuffers(Main.java:439)
at com.android.dx.command.dexer.Main.runMonoDex(Main.java:287)
at com.android.dx.command.dexer.Main.run(Main.java:230)
at com.android.dx.command.dexer.Main.main(Main.java:199)
at com.android.dx.command.Main.main(Main.java:103)
build.gradle:
apply plugin: 'com.android.application' android { compileSdkVersion 15 buildToolsVersion "19.1.0" defaultConfig { applicationId "com.intel.webrtc.p2p.sample" minSdkVersion 15 targetSdkVersion 15 } buildTypes { release { minifyEnabled false proguardFiles getDefaultProguardFile('proguard-android.txt'), 'proguard-rules.txt' } } packagingOptions{ exclude 'AndroidManifest.xml' } } dependencies { compile('io.socket:socket.io-client:0.7.0') { // excluding org.json which is provided by Android exclude group: 'org.json', module: 'json' } compile files('libs/woogeenbase.jar') compile files('libs/woogeenp2p.jar') compile files('libs/libjingle_peerconnection.jar')}
- Tags:
- HTML5
- JavaScript*
android sdk3.1 have two org.webrtc .
Jar package structure:
META-INF
org.webrtc
woogeenbase.jar
com.intel.webrtc.base
META-INF
org.webrtc
Is it right?
Delete
is OK。
p2p sample running is ok now.
OK. Great to see the problem solved!
