Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
client call web only once and then MCU crash
hi
when I use the linphone call web,the first time it will be successfull ,but if I hangup and call the web second time ,it will be failed! why?
and after I restart the MCU ,renovating the web,it will need several times to show the right frame ! why ?
please give me assistance ! Thank you !
Tags (2)
Highlighted
Do you mean Gateway server
Do you mean Gateway server for SIP? As we described in guide, for softphone, we just conducted test with Jitsi, not Linphone. Did this error only exist with Linphone? If true, can you please describe your setting with Linphon? Then we will try to reproduce it.
Not only the linphone ,I have try Ekiga and jitsi or  other terminals,the appearance is same,I think  the issue is MCU occured,have you see the capture screenshot? when I hangup and dial again ,it will be failed! If only I restart  the MCU,then it will be successful again!   what's the reason?
         You can see the capture screenshot from the attachments.
PS:Do you think the pnotify will influence the connection?            I use MCU.v3.2 and chrome46 ,the sip server is asterisk
Please give me help! thank you!
Highlighted
Close this topic since it's
Close this topic since it's duplicated with https://software.intel.com/en-us/forums/intel-collaboration-suite-for-webrtc/topic/700120
