Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
deviceId member variable not working in Ics.Base.VideoTrackConstraints
                 If we give deviceId of a camera source then the camera never switch. i have configure device id using the following
let videoConstraintsForCamera = new Ics.Base.VideoTrackConstraints(Ics.Base.VideoSourceInfo.CAMERA);
videoConstraintsForCamera.deviceId = '4535529bf3d84145da39f3d64ce9e95bc5ce786d4ca26f2ffba91267d2c6c916';
but it never switch the camera
I have find out the issue
in ics.js(library file) the following condition never satisfy
e.video.deviceId instanceof String && (n.video.deviceId = e.video.deviceId)
The instanceof String condition not satisfy so the result n.video.deviceId remains null;
2)Again i changed the code like this
videoConstraintsForCamera.deviceId = new String('4535529bf3d84145da39f3d64ce9e95bc5ce786d4ca26f2ffba91267d2c6c916');
this time the instanceof String condition satisfy but the camera not switched because navigator.mediaDevices.getUserMedia(n) never taking the string object version of deviceId
3)Again i just edited the sdk like the following
true && (n.video.deviceId = e.video.deviceId)  ( instanceof String condition replaced to true - always pass)
and pass deviceId like this videoConstraintsForCamera.deviceId = '4535529bf3d84145da39f3d64ce9e95bc5ce786d4ca26f2ffba91267d2c6c916';
Now i can successfully switch the camera using device id,  But it is not a proper way to edit sdk. please suggest me most reliable option
intel webrtc version : 4.0
server :  centos 7
browser : google chrome latest version
client side app : javascript and html ( no frameworks )
Thank you,
Webrtc Nodejs engineer +919809888818 skype: nithinj2e
Tags (2)
Highlighted
Thanks Nithin for reporting
Thanks Nithin for reporting this issue, we are working on it and will get back to you when it's fixed
