I tried to build conference sample in The Intel CS for WebRTC Client Windows SDK, but got many LNK 2019 errors as below. (64 bit in windows 7).
I had built the boost in 64 bit, and socket.io-client-cpp by cmake and vs 2017, but It seems socket.io-client-cpp only 32 bit version.
did I miss something?
thanks,
1>ics-debug.lib(conferencesocketsignalingchannel.obj) : error LNK2019: unresolved external symbol "public: __cdecl sio::client::client(void)" (??0client@sio@@QEAA@XZ) referenced in function "public: __cdecl ics::conference::ConferenceSocketSignalingChannel::ConferenceSocketSignalingChannel(void)" (??0ConferenceSocketSignalingChannel@conference@ics@@QEAA@XZ)
1>ics-debug.lib(conferencesocketsignalingchannel.obj) : error LNK2019: unresolved external symbol "public: __cdecl sio::client::~client(void)" (??1client@sio@@QEAA@XZ) referenced in function "public: virtual __cdecl ics::conference::ConferenceSocketSignalingChannel::~ConferenceSocketSignalingChannel(void)" (??1ConferenceSocketSignalingChannel@conference@ics@@UEAA@XZ)
1>ics-debug.lib(conferencesocketsignalingchannel.obj) : error LNK2019: unresolved external symbol "public: class std::shared_ptr<class sio::socket> const & __cdecl sio::client::socket(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const &)" (?socket@client@sio@@QEAAAEBV?$shared_ptr@Vsocket@sio@@@std@@AEBV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@4@@Z) referenced in function "public: virtual void __cdecl ics::conference::ConferenceSocketSignalingChannel::Connect(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const &,class std::function<void __cdecl(class std::shared_ptr<class sio::message>)>,class std::function<void __cdecl(class std::unique_ptr<class ics::base::Exception,struct std::default_delete<class ics::base::Exception> >)>)" (?Connect@ConferenceSocketSignalingChannel@conference@ics@@UEAAXAEBV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@V?$function@$$A6AXV?$shared_ptr@Vmessage@sio@@@std@@@Z@5@V?$function@$$A6AXV?$unique_ptr@VException@base@ics@@U?$default_delete@VException@base@ics@@@std@@@std@@@Z@5@@Z)
1>ics-debug.lib(conferencesocketsignalingchannel.obj) : error LNK2019: unresolved external symbol "public: void __cdecl sio::client::set_reconnect_attempts(int)" (?set_reconnect_attempts@client@sio@@QEAAXH@Z) referenced in function "public: virtual void __cdecl ics::conference::ConferenceSocketSignalingChannel::Connect(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const &,class std::function<void __cdecl(class std::shared_ptr<class sio::message>)>,class std::function<void __cdecl(class std::unique_ptr<class ics::base::Exception,struct std::default_delete<class ics::base::Exception> >)>)" (?Connect@ConferenceSocketSignalingChannel@conference@ics@@UEAAXAEBV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@V?$function@$$A6AXV?$shared_ptr@Vmessage@sio@@@std@@@Z@5@V?$function@$$A6AXV?$unique_ptr@VException@base@ics@@U?$default_delete@VException@base@ics@@@std@@@std@@@Z@5@@Z)
1>ics-debug.lib(conferencesocketsignalingchannel.obj) : error LNK2019: unresolved external symbol "public: void __cdecl sio::client::set_reconnect_delay(unsigned int)" (?set_reconnect_delay@client@sio@@QEAAXI@Z) referenced in function "public: virtual void __cdecl ics::conference::ConferenceSocketSignalingChannel::Connect(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const &,class std::function<void __cdecl(class std::shared_ptr<class sio::message>)>,class std::function<void __cdecl(class std::unique_ptr<class ics::base::Exception,struct std::default_delete<class ics::base::Exception> >)>)" (?Connect@ConferenceSocketSignalingChannel@conference@ics@@UEAAXAEBV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@V?$function@$$A6AXV?$shared_ptr@Vmessage@sio@@@std@@@Z@5@V?$function@$$A6AXV?$unique_ptr@VException@base@ics@@U?$default_delete@VException@base@ics@@@std@@@std@@@Z@5@@Z)
1>ics-debug.lib(conferencesocketsignalingchannel.obj) : error LNK2019: unresolved external symbol "public: void __cdecl sio::client::set_socket_close_listener(class std::function<void __cdecl(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const &)> const &)" (?set_socket_close_listener@client@sio@@QEAAXAEBV?$function@$$A6AXAEBV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@@Z@std@@@Z) referenced in function "public: virtual void __cdecl ics::conference::ConferenceSocketSignalingChannel::Connect(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const &,class std::function<void __cdecl(class std::shared_ptr<class sio::message>)>,class std::function<void __cdecl(class std::unique_ptr<class ics::base::Exception,struct std::default_delete<class ics::base::Exception> >)>)" (?Connect@ConferenceSocketSignalingChannel@conference@ics@@UEAAXAEBV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@V?$function@$$A6AXV?$shared_ptr@Vmessage@sio@@@std@@@Z@5@V?$function@$$A6AXV?$unique_ptr@VException@base@ics@@U?$default_delete@VException@base@ics@@@std@@@std@@@Z@5@@Z)
1>ics-debug.lib(conferencesocketsignalingchannel.obj) : error LNK2019: unresolved external symbol "public: void __cdecl sio::client::set_fail_listener(class std::function<void __cdecl(void)> const &)" (?set_fail_listener@client@sio@@QEAAXAEBV?$function@$$A6AXXZ@std@@@Z) referenced in function "public: virtual void __cdecl ics::conference::ConferenceSocketSignalingChannel::Connect(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const &,class std::function<void __cdecl(class std::shared_ptr<class sio::message>)>,class std::function<void __cdecl(class std::unique_ptr<class ics::base::Exception,struct std::default_delete<class ics::base::Exception> >)>)" (?Connect@ConferenceSocketSignalingChannel@conference@ics@@UEAAXAEBV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@V?$function@$$A6AXV?$shared_ptr@Vmessage@sio@@@std@@@Z@5@V?$function@$$A6AXV?$unique_ptr@VException@base@ics@@U?$default_delete@VException@base@ics@@@std@@@std@@@Z@5@@Z)
1>ics-debug.lib(conferencesocketsignalingchannel.obj) : error LNK2019: unresolved external symbol "public: void __cdecl sio::client::set_reconnecting_listener(class std::function<void __cdecl(void)> const &)" (?set_reconnecting_listener@client@sio@@QEAAXAEBV?$function@$$A6AXXZ@std@@@Z) referenced in function "public: virtual void __cdecl ics::conference::ConferenceSocketSignalingChannel::Connect(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const &,class std::function<void __cdecl(class std::shared_ptr<class sio::message>)>,class std::function<void __cdecl(class std::unique_ptr<class ics::base::Exception,struct std::default_delete<class ics::base::Exception> >)>)" (?Connect@ConferenceSocketSignalingChannel@conference@ics@@UEAAXAEBV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@V?$function@$$A6AXV?$shared_ptr@Vmessage@sio@@@std@@@Z@5@V?$function@$$A6AXV?$unique_ptr@VException@base@ics@@U?$default_delete@VException@base@ics@@@std@@@std@@@Z@5@@Z)
1>ics-debug.lib(conferencesocketsignalingchannel.obj) : error LNK2019: unresolved external symbol "public: void __cdecl sio::client::set_open_listener(class std::function<void __cdecl(void)> const &)" (?set_open_listener@client@sio@@QEAAXAEBV?$function@$$A6AXXZ@std@@@Z) referenced in function "public: virtual void __cdecl ics::conference::ConferenceSocketSignalingChannel::Connect(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const &,class std::function<void __cdecl(class std::shared_ptr<class sio::message>)>,class std::function<void __cdecl(class std::unique_ptr<class ics::base::Exception,struct std::default_delete<class ics::base::Exception> >)>)" (?Connect@ConferenceSocketSignalingChannel@conference@ics@@UEAAXAEBV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@V?$function@$$A6AXV?$shared_ptr@Vmessage@sio@@@std@@@Z@5@V?$function@$$A6AXV?$unique_ptr@VException@base@ics@@U?$default_delete@VException@base@ics@@@std@@@std@@@Z@5@@Z)
1>ics-debug.lib(conferencesocketsignalingchannel.obj) : error LNK2019: unresolved external symbol "public: void __cdecl sio::socket::on(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const &,class std::function<void __cdecl(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const &,class std::shared_ptr<class sio::message> const &,bool,class sio::message::list &)> const &)" (?on@socket@sio@@QEAAXAEBV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@AEBV?$function@$$A6AXAEBV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@AEBV?$shared_ptr@Vmessage@sio@@@2@_NAEAVlist@message@sio@@@Z@4@@Z) referenced in function "public: virtual void __cdecl ics::conference::ConferenceSocketSignalingChannel::Connect(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const &,class std::function<void __cdecl(class std::shared_ptr<class sio::message>)>,class std::function<void __cdecl(class std::unique_ptr<class ics::base::Exception,struct std::default_delete<class ics::base::Exception> >)>)" (?Connect@ConferenceSocketSignalingChannel@conference@ics@@UEAAXAEBV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@V?$function@$$A6AXV?$shared_ptr@Vmessage@sio@@@std@@@Z@5@V?$function@$$A6AXV?$unique_ptr@VException@base@ics@@U?$default_delete@VException@base@ics@@@std@@@std@@@Z@5@@Z)
1>ics-debug.lib(conferencesocketsignalingchannel.obj) : error LNK2019: unresolved external symbol "public: void __cdecl sio::client::connect(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const &)" (?connect@client@sio@@QEAAXAEBV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@@Z) referenced in function "public: virtual void __cdecl ics::conference::ConferenceSocketSignalingChannel::Connect(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const &,class std::function<void __cdecl(class std::shared_ptr<class sio::message>)>,class std::function<void __cdecl(class std::unique_ptr<class ics::base::Exception,struct std::default_delete<class ics::base::Exception> >)>)" (?Connect@ConferenceSocketSignalingChannel@conference@ics@@UEAAXAEBV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@V?$function@$$A6AXV?$shared_ptr@Vmessage@sio@@@std@@@Z@5@V?$function@$$A6AXV?$unique_ptr@VException@base@ics@@U?$default_delete@VException@base@ics@@@std@@@std@@@Z@5@@Z)
1>ics-debug.lib(conferencesocketsignalingchannel.obj) : error LNK2019: unresolved external symbol "public: bool __cdecl sio::client::opened(void)const " (?opened@client@sio@@QEBA_NXZ) referenced in function "public: virtual void __cdecl ics::conference::ConferenceSocketSignalingChannel::Disconnect(class std::function<void __cdecl(void)>,class std::function<void __cdecl(class std::unique_ptr<class ics::base::Exception,struct std::default_delete<class ics::base::Exception> >)>)" (?Disconnect@ConferenceSocketSignalingChannel@conference@ics@@UEAAXV?$function@$$A6AXXZ@std@@V?$function@$$A6AXV?$unique_ptr@VException@base@ics@@U?$default_delete@VException@base@ics@@@std@@@std@@@Z@5@@Z)
1>ics-debug.lib(conferencesocketsignalingchannel.obj) : error LNK2019: unresolved external symbol "public: void __cdecl sio::socket::emit(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const &,class sio::message::list const &,class std::function<void __cdecl(class sio::message::list const &)> const &)" (?emit@socket@sio@@QEAAXAEBV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@AEBVlist@message@2@AEBV?$function@$$A6AXAEBVlist@message@sio@@@Z@4@@Z) referenced in function "public: virtual void __cdecl ics::conference::ConferenceSocketSignalingChannel::Disconnect(class std::function<void __cdecl(void)>,class std::function<void __cdecl(class std::unique_ptr<class ics::base::Exception,struct std::default_delete<class ics::base::Exception> >)>)" (?Disconnect@ConferenceSocketSignalingChannel@conference@ics@@UEAAXV?$function@$$A6AXXZ@std@@V?$function@$$A6AXV?$unique_ptr@VException@base@ics@@U?$default_delete@VException@base@ics@@@std@@@std@@@Z@5@@Z)
1>ics-debug.lib(conferencesocketsignalingchannel.obj) : error LNK2019: unresolved external symbol "public: void __cdecl sio::client::close(void)" (?close@client@sio@@QEAAXXZ) referenced in function "public: <auto> __cdecl `public: <auto> __cdecl `public: virtual void __cdecl ics::conference::ConferenceSocketSignalingChannel::Connect(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const &,class std::function<void __cdecl(class std::shared_ptr<class sio::message>)>,class std::function<void __cdecl(class std::unique_ptr<class ics::base::Exception,struct std::default_delete<class ics::base::Exception> >)>)'::`1'::<lambda_3>::operator()(void)const '::`1'::<lambda_2>::operator()(class sio::message::list const &)const " (??R<lambda_2>@?0???R<lambda_3>@?0??Connect@ConferenceSocketSignalingChannel@conference@ics@@UEAAXAEBV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@V?$function@$$A6AXV?$shared_ptr@Vmessage@sio@@@std@@@Z@7@V?$function@$$A6AXV?$unique_ptr@VException@base@ics@@U?$default_delete@VException@base@ics@@@std@@@std@@@Z@7@@Z@QEBA?A?<auto>@@XZ@QEBA?A?<auto>@@AEBVlist@message@sio@@@Z)
1>C:\dependencies\socket.io-client-cpp\Debug\sioclient_tls.lib : warning LNK4272: library machine type 'x86' conflicts with target machine type 'x64'
- Tags:
- HTML5
- JavaScript*
Any help would be appreciated.
Thank you.
Chandramouli.
