while i set on the console for sip info,and i had apply it。then when i /start-all.sh the owt,my sip-portal have no fail link to agent
The attachment is the log, can evenry one help me to solve the problem? thanks very much!
2019-09-06 22:26:46.224 - INFO: AmqpClient - Connecting to rabbitMQ server OK, options: { host: 'localhost', port: 5672, login: 'admin' }
2019-09-06 22:26:46.306 - INFO: SipPortal - sip-portal up!
2019-09-06 22:26:46.418 - INFO: SipPortal - initSipRooms ok
2019-09-06 22:26:51.542 - WARN: SipPortal - Allocate sip Erizo fail: Failed to get sip agent:
2019-09-06 22:26:51.543 - INFO: SipPortal - Try to allocate after 5 s.
2019-09-06 22:26:59.405 - INFO: SipErizoHelper - Successully schedule sip node sip-ee42b0a4e8efeda8c96f@192.168.1.158_0 for { room: '5d722e7d78f2be082bab9eb6',
task: '5d722e7d78f2be082bab9eb6' }
while i open the log debug the info like next
2019-09-06 23:25:24.064 - DEBUG: AmqpClient - Connecting to rabbitMQ server: { host: 'localhost', port: 5672 }
2019-09-06 23:25:24.370 - INFO: AmqpClient - Connecting to rabbitMQ server OK, options: { host: 'localhost', port: 5672, login: 'admin' }
2019-09-06 23:25:24.415 - DEBUG: AmqpClient - Exchange owtRpc is open
2019-09-06 23:25:24.428 - DEBUG: AmqpClient - Reply queue for rpc client amq.gen-vovkIuZd9ANY5E4iPaTOUw is open
2019-09-06 23:25:24.438 - DEBUG: AmqpClient - Exchange owtRpc is open
2019-09-06 23:25:24.447 - DEBUG: AmqpClient - Request queue for rpc server sip-portal is open
2019-09-06 23:25:24.450 - INFO: SipPortal - sip-portal up!
2019-09-06 23:25:24.450 - DEBUG: SipPortal - Start to get SIP rooms
2019-09-06 23:25:24.547 - WARN: SipPortal - --->0Get sip rooms from: [ { roomId: '5d722e7d78f2be082bab9eb6',
sip: { sipServer: '192.168.1.158',
username: '1005',
password: 'c38cf78fad' } } ]
2019-09-06 23:25:24.548 - DEBUG: SipPortal - --->2SIP rooms [ { roomId: '5d722e7d78f2be082bab9eb6',
username: '1005',
2019-09-06 23:25:24.549 - DEBUG: SipPortal - ----------��createSipConnectivity Sip info �� 5d722e7d78f2be082bab9eb6 192.168.1.158 1005 12345
2019-09-06 23:25:24.549 - INFO: SipPortal - ----3initSipRooms ok
2019-09-06 23:25:24.557 - DEBUG: AmqpClient - remoteCall, corrID: 0 to: owt-cluster method: schedule
2019-09-06 23:25:24.565 - DEBUG: AmqpClient - New message received { data: 'error',
corrID: 0,
type: 'callback',
err: 'Failed in scheduling sip worker, reason: No worker available, all in full load.' }
2019-09-06 23:25:24.565 - DEBUG: AmqpClient - Callback callback - error
2019-09-06 23:25:24.566 - DEBUG: SipErizoHelper - Failed in scheduling a sip agent, keep trying.
2019-09-06 23:25:24.766 - DEBUG: AmqpClient - remoteCall, corrID: 1 to: owt-cluster method: schedule
2019-09-06 23:25:24.770 - DEBUG: AmqpClient - New message received { data: 'error',
corrID: 1,
type: 'callback',
2019-09-06 23:25:24.770 - DEBUG: AmqpClient - Callback callback - error
2019-09-06 23:25:24.770 - DEBUG: SipErizoHelper - Failed in scheduling a sip agent, keep trying.
2019-09-06 23:25:24.971 - DEBUG: AmqpClient - remoteCall, corrID: 2 to: owt-cluster method: schedule
2019-09-06 23:25:24.973 - DEBUG: AmqpClient - New message received { data: 'error',
corrID: 2,
type: 'callback',
2019-09-06 23:25:24.973 - DEBUG: AmqpClient - Callback callback - error
2019-09-06 23:25:24.973 - DEBUG: SipErizoHelper - Failed in scheduling a sip agent, keep trying.
2019-09-06 23:25:25.174 - DEBUG: AmqpClient - remoteCall, corrID: 3 to: owt-cluster method: schedule
2019-09-06 23:25:25.176 - DEBUG: AmqpClient - New message received { data: 'error',
corrID: 3,
type: 'callback',
2019-09-06 23:25:25.177 - DEBUG: AmqpClient - Callback callback - error
2019-09-06 23:25:25.177 - DEBUG: SipErizoHelper - Failed in scheduling a sip agent, keep trying.
2019-09-06 23:25:25.376 - DEBUG: AmqpClient - remoteCall, corrID: 4 to: owt-cluster method: schedule
2019-09-06 23:25:25.379 - DEBUG: AmqpClient - New message received { data: 'error',
corrID: 4,
type: 'callback',
2019-09-06 23:25:25.379 - DEBUG: AmqpClient - Callback callback - error
2019-09-06 23:25:25.379 - DEBUG: SipErizoHelper - Failed in scheduling a sip agent, keep trying.
2019-09-06 23:25:25.580 - DEBUG: AmqpClient - remoteCall, corrID: 5 to: owt-cluster method: schedule
2019-09-06 23:25:25.583 - DEBUG: AmqpClient - New message received { data: 'error',
corrID: 5,
type: 'callback',
2019-09-06 23:25:25.583 - DEBUG: AmqpClient - Callback callback - error
2019-09-06 23:25:25.583 - DEBUG: SipErizoHelper - Failed in scheduling a sip agent, keep trying.
2019-09-06 23:25:25.783 - DEBUG: AmqpClient - remoteCall, corrID: 6 to: owt-cluster method: schedule
2019-09-06 23:25:25.786 - DEBUG: AmqpClient - New message received { data: 'error',
corrID: 6,
type: 'callback',
2019-09-06 23:25:25.786 - DEBUG: AmqpClient - Callback callback - error
- Tags:
- HTML5
- JavaScript*
Have you checked the logs 'sip-xxxx.log'?
It seems that there're some problems starting sip-agent, so sip-portal cannot find them
hello,thanks, the Attachments is my start log,i see the log has a error where start,
sip log sip-portal.stdout is next ,all the log in attachments
2019-09-10 17:52:53.489 - DEBUG: SipErizoHelper - Failed in scheduling a sip agent, keep trying.
2019-09-10 17:52:53.692 - DEBUG: SipErizoHelper - Failed in scheduling a sip agent, keep trying.
2019-09-10 17:52:53.893 - WARN: SipPortal - Allocate sip Erizo fail: Failed to get sip agent:
2019-09-10 17:52:53.893 - INFO: SipPortal - Try to allocate after 5 s.
2019-09-10 17:52:58.896 - DEBUG: SipPortal - ----------��createSipConnectivity Sip info �� 5d722e7d78f2be082bab9eb6 192.168.1.158 1005 12345
2019-09-10 17:52:58.907 - INFO: SipErizoHelper - Successully schedule sip node sip-bd4d5001cf846ac6e624@192.168.1.158_0 for { room: '5d722e7d78f2be082bab9eb6',
2019-09-10 17:52:58.907 - DEBUG: SipPortal - allocateSipErizo { id: 'sip-bd4d5001cf846ac6e624@192.168.1.158_0',
addr: '192.168.1.158' }
2019-09-10 17:52:58.913 - DEBUG: SipPortal - Sip node init successfully.
when i see the freeswitch ,the owt sip room has register in the freeswitch
