Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
how to select a audio stream into a conference?
ttom1
hi,
I use the Windows version SDK. The PC has several audio streams and I want to select one of the streams to a conference, how should i do?
thanks.
Lei_Z_Intel1
If that's audio device capture mode, the WebRTC SDK will choose system default audio device. No selection channel.
You can use Windows SDK customized input API to feed you prepared audio stream. Use your own application to open the preferred the audio device and feed it into WebRTC pipeline.
