Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
iOS Portrait
zhao_w_
Hello, I use the webrtc 3.4 version of the SDK, how can I force the camera output data are vertical screen, thank you.I found that I'll direction of equipment modification videoOrientation don't take effect
//            AVCaptureVideoOrientation orientation = av.videoOrientation;
//            switch (orientation) {
//                case UIInterfaceOrientationPortraitUpsideDown:
//                    if(av.videoOrientation != AVCaptureVideoOrientationPortraitUpsideDown) {
//                        dispatch_async(dispatch_get_global_queue(0, 0), ^{
//                            [session beginConfiguration];
//                            av.videoOrientation = AVCaptureVideoOrientationPortraitUpsideDown;
//                            [session commitConfiguration];
//                    break;
//                case UIInterfaceOrientationLandscapeRight:
//                    if(av.videoOrientation != AVCaptureVideoOrientationLandscapeRight) {
//                            av.videoOrientation = AVCaptureVideoOrientationLandscapeRight;
//                    break;
//                case UIInterfaceOrientationLandscapeLeft:
//                    if(av.videoOrientation != AVCaptureVideoOrientationLandscapeLeft) {
//                            av.videoOrientation = AVCaptureVideoOrientationLandscapeLeft;
//                    break;
//                case UIInterfaceOrientationPortrait:
//                    if(av.videoOrientation != AVCaptureVideoOrientationPortrait) {
//                            av.videoOrientation = AVCaptureVideoOrientationPortrait;
//                    break;
//                default:
//                    break;
Jianjun_Z_Intel
Hi zhao,
Did you try locking orientation?
zhao_w_
HI Jianjun Z
  How to locking , user may close device orientation lock
